Chrylser 300C Oil
Any ideas of a good oil to use in the 5.7L Hemi?
Regular or Synthetic and a good brand name?
So, operating upon the above factoid, I would only go with a full synthetic oil as there is no way I would trust a conventional (or even semi-synthetic for that matter) 0W-20 oil. Specific to the brand, I've been using Mobil 1 (which can be had as a 0W-20) for over twenty years and been impressed with the longevity of my engines (and turbochargers when I've had engines with forced induction) as well as the incredible internal engine cleanliness that Mobil 1 seems to foster. Granted I've never used 0W-20 and that my experience is anecdotal, however, if you check around you will find volumes of data that support what I've said.
Let us know what you decide. ;-)
Best Regards,
Shipo
Thanks for the immediate response. I have been doing some research on synthetics. I have a 92 Vette that calls for Mobil 1 in the user manual. I have had no problems with it. I am leaning towards the Mobil 1 5W-20W that is what the manual calls for. It takes 7 quarts. I never heard of that in a passenger car. A little costly but I do my own oil changes and so it won't be too bad Thanks again.
Hemied
Both of my six cylinder BMWs called for 7 quarts, I believe there are a few Mercedes-Benz cars that need more as do some (all?) Porsches. I wouldn't be at all surprised to see more cars adopt a larger oil sump as folks want longer and longer maintenance intervals on their new cars.
Best Regards,
Shipo
Hmmm, I've been toying with the idea of buying an old 1967 Cuda and dropping in one of the new Hemis, and your comments got me to thinking. I just looked up what the Mopar Direct Connection folks are getting for crate Hemis for use in vintage cars, and their complete fuel-injected "Plug and Play" crate motor (meaning that all of the engine management electronics and wiring harnesses are included as well) ,part number P4510593, can be had for only $7,500. Not too shabby.
Best Regards,
Shipo
Regarding the transmissions; I've never learned how to drive an automatic, so I'll have to stick with the New Process 4-Speed. :shades:
Best Regards,
Shipo
I do like the specs though, 360 HP and 360 lb-ft of torque out of the box. Not too shabby.
http://www.mopar.com/muscle/whatshot1002.htm
Best Regards,
Shipo
Best Regards,
Shipo
No, they aren't. It's an iron block with aluminum heads.
Moderator: It's Chrysler not "Chrylser".
What does the metallurgy of the block and the heads have to do with engine efficiency?
Best Regards,
Shipo
FWIW, I'm thinking that you'd be hard pressed to find another car the size of a 300, and with as much power as the Hemi that is capable of getting fuel economy as good as the 300C.
Best Regards,
Shipo
Iron atomic mass= 55.85, Aluminum=26.98. Therefore an iron engine of the same volume weighs more than twice that of aluminum. Aluminum is more expensive.
1) I've been turning a wrench for lots of years, and I've yet to see any aluminum heads that have roughly the same volume of metal as a comparable iron head. Said another way, while I absolutely agree that an aluminum head capable of doing the same job as an iron head will weigh less, it will weigh in at well over half of the weight. Why? I suspect that you know this already, but I'll answer it anyway: Aluminum doesn't have the same structural integrity as does iron, and so more of it needs to be used to match the capabilities of the "smaller" iron head.
2) Implied in original post about the aluminum construction was that an aluminum engine would be more efficient than a comparable iron engine. I'm having a problem accepting that.
3) Given that aluminum can conduct more heat, aluminum engines have a tendency to draw considerably more heat out of the combustion chamber on every power stoke, and as such, engine efficiency has a tendency to drop. I remember first reading about this phenomena in a study prepared by GM back in the 1960s when they were developing their all-aluminum 427 for racing Corvettes. They performed the study because they were surprised when their new aluminum engine put out rather less power than the identical (from a bore, stroke, timing and cam profile) iron engine.
Best Regards,
Shipo
I wonder if, in a vehicle that is lighter because of an aluminum engine of the same size, that might be more efficient, even if the engine is not as efficient taken by itself. Not arguing, just wondering.
At least, that's how I recall the summation.
Best Regards,
Shipo
