The problem appears to be in the heater or AC hose. If I have it bled the sound goes a way for a while. Not I just live with it.
BTW I put a put an ARB front bumper with a 9000lb winch on after a little deer incident. Someday i post a link to some photos of my Montero.
Question Can I use the 1985 mits truck transmission for the Montero? It's about 300 bucks, where the montero tranny is expensive. It seems to me that the tranny could be the same.
any ideas
1995
Thanks...
Thanks...
BTW, the only other easily accessable repair manual that I can think of are the ones produced by Haynes. You can go to their website or just pick one up from any major auto parts store.
The fine print on the receipt says that "owner assumes risk for engine cleaning" so the carwash place is limited in their liability.
Thanks in advance!!
follow this link for how to fix it. it is simple, the only thing I would add is that the directions in the link state to pull the license plate assembly up and I had to push mine down, and to take off the license plate first. It is entirly possible that all you need to do is spray a lot of lub into the mechanism, use the red spot sprayer stick that is on most cans to get it inside the actuator and then let it sit for an hour and then try to open it, you may not need to remove the plate holder if this works. Good luck.
