Volvo XC70 Tire/Wheel Questions
Post your questions regarding tire and wheel issues on the XC70 here.
any thoughts or advice??
Looks like folks score the Pirelli a touch better intheWet and Dry performance ratings, while the Firestones have a slight edge in Winter and Comfort/Treadwear. If youlook at the number of people submitting survey results for each tire and the total miles reported in the surveys, the Firestone folks were reporting with an average of about 17,600 miles and the Pirelli users about 15,900 so I'm thinking you may get a few more mile out of the Firestones, although a lot of that is going to depend on driving conditions/styles. Sounds like you got decent mileage out of your last set. Looks like a close call with the biggest difference being price. Hope this helps a bit!
I am assuming its related to the transfer case which is notorious for this model.
Questions-how do I determine what is causing this?
If it is the transfer case should I attempt to buy a use one from the dismantler?
Signed, frustrated and about to cry... thanks
Does anyone have any info on whether the tires need to be replaced if worn on the very edges? [they seem to get fine traction].
Also, how long do brakes normally last?
Miatawilly
285mm and 305mm. what is the difference. I just need stock rotors for a 2001 xc70. I need answers asap. thank you
Albany, NY
Sharon
Sharon
I can hear the lawsuit now, you get in an accident and the otherside says the car would have responded better if it had the correctly engineered tires installed. As far as mileage is concerned, V rated tires because of their traction will wear faster than H rated tires and this is more pronounced in the Pirelli because if it's semi-aggressive design. Unfortunately the only tire available in the US that meets the manufacturers specification is the Pirelli.
