I didn't special order my car. They have exactly three standard versions of the 460L here in Southern California: Two at around 80K and the "everything" at 86K. Only the "everything" had the two features that I wanted, and that does include the park-o-matic. So far I've only tried it once in a big parking lot with lots of room. I found it is a little tricky (if I may use that Nixonian adjective) to set it up, but once I figured that out it worked perfectly; i.e. it backed into the exact space that I had selected. The challenge is to move the parking frame on the nav screen to the exact position in the rear camera view where you want to end up. Of course that is assuming that there is nothing wrong with the car.
Good luck with the 450h.
Renny
Didn't know you are a SOCAL person...where did you get it?
I'm not interested in price; rather would like to hear your take on dealers in this area re service, etc. I would rate Vista #1 (bought 2 there), Cerritos #2 (1 purchase), South Bay (My 460 was from them), and Keyes Van Nuys a DISTANT last place, unless one can start with the salesman who sold me my first 430. Comments?
Re park-o-matic...my mishap occurred when the system did not recognize a high curb and alert me to the presence of an obstacle which would clearly impact the fender skirt. Screen resolution is not adequate for my tired eyeballs to pick out details like curb height; dammit that is what sensors, servos, and warning chimes are for! I assume they understand the dynamics of trigonometry. However, in fairness to Lexus, they refunded my $700 when even they could not make it obey. Based on numerous comments with chat rooms, a New York Times automotive editor called me and we talked for a while about my experiences, and he included a snippet in his article regarding this feature.
What soured me on Tustin was that when I said to the service writer, "I read on the Internet that when you rotate the tires you should include the spare tire in order to get more wear out of your tires. Did you do that?" he said, "Oh yes, absolutely. We always do that." A month later I called back and said, "I just heard that you should not include the spare when rotating tires." That guy said, "That's right. With radial tires you have to keep them on the same side of the car. We know that."
But in fairness it is probably true that you can have good and bad experiences everywhere.
Any regrets after a few weeks or months?
Perhaps someone else here has a thought for you.
Normal
Comfort
Sport
The height increase/decrease is a separate adjustment. The car rides very smooth in all 3 and floats the best in comfort. Sport tightens everything up and improves handling but the ride is still luxuriously smooth and perfect. My car, which is a LWB, handles bumps beautifully and the bump has to be a pretty good sized one to even feel it in the car.
I don't understand what is so worth the money in those items.
Having moved into a GM product I am pleasantly surprised to find several options that work better than any of the 5 Lexi I have owned. Standard equipment on my new Buick is heated steering wheel, laminated glass all around, tilt mirrors that actually allow curb visibility for parking, logical seat deployment upon exit, and great seat heaters that allow a choice between seatback only or seatback and cushion. They cool the driver and passenger also, just like the Lexus.
I would give the advantage to Lexus for the NAV system and the ML stereo except the MP-3 port on the GM machine is much handier than the Lexus, which is placed in the rear of the center console in a black hole requiring a flashlight to find. Fit and finish is comparable and there is no need to look for those blasted fasteners Lexus uses on the engine covers which pop out and disappear whenever one must remove a cover to check what is underneath. Note also that Lexus techs are not too diligent in replacing those that are lost...holes are left empty, since most owners never raise the hood?
Finally, I cannot detect wind noise with the Buick...a frequent topic of complaint on this link.
This is my 10th Lexus. I wish to hell I had kept my LS430. I think this will be my last Lexus.
Now I am really :confuse:
I am thinking of getting a x5 as my future and next car but for reliability i am thinking getting a lexus as my next future car
but ur review is surprising
My 08 LS460 is the LWB. I do get the impression that the SWB version is less perfect. I gather yours is the SWB?
Renny
I wouldn't say they build bad cars some problems nothing very big or maybe the exceptional of the GS recall, still they do build better reliability than the european cars.
1. Sometimes driving this car is so sweet, I think I am dreaming. It can be smooth in acceleration through all gears and tons of power. At other times, usually at slower speeds, the care can rev a little between shifts, seems sluggish, and noisier than the time I drove it before. I call it my Jekel & Hyde car.
2. Of course there is the wind noise on the driver side window.
3. The brakes are hard to make a smooth stops.
4. The command center is too complex to work and is a joke. My new top of the line Chevy pickup truck shames this Lexus in its simplicity.
5. The car tends to catch groves in the street, pulling the car left or right, especially noticeable when braking.
6. It is difficult to hold the car precisely in curves.
7. Some time the high pressure injectors make alot of noise. Sometimes they make none.
When I take the car to the dealer complaining about any of this, they don't know what to do. My conclusion is that if you want a car that has exquisite fit and finish, goes fast in a straight line, and is smooth as glass doing it (most of the time), then buy an LS 460. If you want a car that goes pretty fast, can do just about anything the Lexus can do with more simplicity, and costs a lot less, buy a Buick or something else. Lexus has screwed this car up. I will not buy another.
P.S. - I drove both the big BMW and Mercedes before I bought the LS. All three of these cars have gone off the deep end on gadgets. It seems to be a battle of the whistles and bells instead of the ease of operation. I would say the Lexus still has a ways to go on everything but fit and finish when comparing to the other two. Of course, it is a little cheaper, for what that is worth.
I am looking at the Smoky Granite & black leather combination ...did you get any response good or bad on this color combo ?
That's really all I know about the matter.
No mention on the "L" having the same deal.
It looks like the 460's are finally coming down in price. That is GREAT news.
Now the LX570 needs to follow suit......
Lexus has spoiled me into thinking of the LS as being "fairly priced" in the high 50's, low 60's. Dealers have been trying to take advantage of the "ALL NEW LS!!" to "mercederize" their prices but I think that party is now coming to a close.
Aside from the greater HP, the difference between the 430 (selling at near invoice its last few years here in South Fla.) and the 460 just doesn't seem like enough to justify the price jumps dealers have been trying to sustain. The LS went from mid to high 50K "real world" sale prices to 70K on the 460. Lease prices jumped from 700 to 800 per month for 36 months to well over $1000 per month.
That's one of the problems with achieving near perfection -- what else can they do or add to these cars to make them pricier yet still appear to be a good value? The self parking gimmick was cute, but who really wants that and is willing to pay a premium for it?
I know this is totally subjective, but in my mind the LS has always been, and always should be, the nicer looking, more reliable, and much less expensive S class alternative.
Now that the newness is wearing off the 460 and the early adopters have had their fun, perhaps the car will now become more accessible to us regular folks.
In other words, perhaps my wife will let me get one now!
I'd appreciate any feedback from those that have experience with both.
I am not an audiophile by any means. I generally listen to contemporary, jazz, and 80,90's pop with the volume at around 30-40% of full strength.
To me, all three systems sound the same.
Better trained ears will beg to differ, I'm sure.
That nav bypass kit will come in handy -- don't know why Lexus lawyers don't allow full access even if it senses a person in the passenger seat.
Jim 9921... your best bet is to try out the stereos at the dealer and let your ears decide. Under normal listening conditions I really think that unless you have an affinity for pristine audiophonics you won't be able to tell much difference, if any. Perhaps if you load up a cd with lots of orchestral strings, guitars, etc. you might be able to hear a richer, crisper sound on the ML.
Let us know what you decide....
I am a longtime Lexus LS400 & LS430 owner ever since Toyota made the Lexus brand. I bought my second Lexus because of the Mark Levinson system. It is supposed to be the top of the line audio equipment.
However, I just had a very scary experience recently. When I started my LS430 (with the Mark Levinson system), there were a lot of loud popping sounds like gun shots. The radio came on very loud in between the popping sound. I tried to lower the volume and turn off the radio but neither one worked. I had to roll down the windows to avoid hurting my ears and stop the car. I started and stopped the car several times and finally the popping sound was gone. The Mark Levinson radio/CD system was completely dead.
My car has only 52,000 miles driven when this thing happened.
I took the car to the Lexus dealer for inspection. The technician wrote on the inspection report: 'Mark Levinson amplifier malfunctioning internally'.
To get my radio back to work, I paid $500.00 for a new Mark Levinson amplifier and $148.00 to install. Needless to say, I am very, very disappointed. I have been very proud of owning the top of the line Mark Levinson system but not any more.
2007 460 SWB
Fuel economy city 18-19 miles
Fuel economy Highway 27 miles
2008 460 SWB
Fuel economy city 16 miles
Fuel economy Highway 24 miles
Is this true? Any reason for this drop in fuel economy?
Wabends :surprise:
http://www.clublexus.com/forums/showthread.php?t=352398
blogs.cars.com/kickingtires/2008/09/lexus-ls-460-ge.html
Nothing new except AWD option.
Trade-In Private
Party Dealer
Retail
$38,935 $41,537 $43,500
for Albuquerque, NM
These days there is problem in everything, nothing is perfect.
Would welcome any insight.
By the way, I've started a new Discussion Title Thread called "2013 Lexus LS" with some questions of my own, but have not gotten a response yet, probably because, very little info about technical specifications and option packages have come out yet.
http://townhall-talk.edmunds.com/WebX/.f261cfc/0
I still have the '01 LS430, as well as an '04 LS430 (that was a nice upgrade), and an '08 LS460L, at least in the family. Everybody loves them.
Renny
http://www.automobilemag.com/reviews/driven/1208_2013_lexus_ls_460/
LF-CC:
http://www.lexus.com/concept/lfcc/index.html
LF-LC:
