Towing with a Honda Element
I have a 2004 Honda Element EX AWD and love it. I'd like to purchase a small trailer for it to separately transport a small 11-foot sailboat, a John Deere lawn tractor, or lumber, drywall, etc. My questions about towing with it are three-fold: 1) Is the 1,500 pound maximum noted in the owner's manual absolute?; 2) What has your experience been in towing with the Element?; and 3) What challenges, if any, have you experienced in purchasing a non-Honda towing kit and having it installed outside the Honda-dealer network? Thank you.
I'm looking for advice from someone concerning a long tow. I want to take my 670 lb motorcycle to Florida from NE Indiana. That's nearly 1100 pounds. I'll watch my tongue weight carefully even if I have to move my trailer axle a bit. The E turns about 3400 rpm at 70 mph and I can pull the grades in TN and KY in 4th if I have to. I need to weigh the entire gross package to ensure I am within the limits of the E.
comments are welcome. Soloboss
I wish that I would have known this before purchasing the E as we needed our 'new' car to be able to do double duty as the tow vehicle--I still would buy an Element because other than NOT being a good tow capable vehicle, it's a great car. I'll have to go back to the drawing board to find another vehicle with good gas mileage for towing the popup on those camping trips out West. Maybe a Suburu Outback??
Its not specifically the fault of the E, especially the 2wd version, that it is a poor choice for towing. Its no better or worse than any 4 cyl minivan for that purpose. My son owns an AWD E and I would highly recommend against towing with this vehicle. Its low HP, small brakes (fine for normal driving but not for towing), and unibody construction are all negatives for towing.
I hypermile with my 09 Outback and get great mpg. Its rated at 20/26, but I've averaged 29.7 for the first 37K miles, ranging from a low of 25 to a high of 34. But few people drive like this (I coast & rarely touch the brakes). If towing, and I would not recommend it for towing long distance, I would expect the mpg to drop like a rock (maybe 16-18 mpg). Remember that you must not tow in overdrive or without a trans cooler or you will cook your transmission. And it will be considered abuse - not covered under warranty.
I do not recommend towing with your E. But if you insist on doing it, then you can look into reducing the trailer tongue weight (weigh it first with a bathroom scale). The easiest way to do that is to move the trailer axle forward. But you have to be very careful because shifting the load may increase the tendency for the trailer to fish-tail. And you'll need to have an auxiliary transmission cooler installed at the very least and not use 5th gear.
