Jaguar XK-Series Electrical Problems
Mr_Shiftright
Member Posts: 64,481
in Jaguar
Have you had problems with switchgear, lighting, audio, etc. with your XK series car? Post questions or solutions right here!
Any ideas about what to do, or is it a "go into the dealership" thing?
I have a similar probelm with my 1997 XK8 convertible. Did you find the problem? Please let me know. My email address is tamirc@msn.com
Tamir
Hope this helps,
Tamir
Thanks for the advise. My problem is that the roof is latching OK but the 'Convertible Latch Fail' message stays on and the rear windows don't go up. I am wondering where the latch sensor is located.
By the way, any idea as to how to flush the fluid?
Also, what sort of lubricant did the garage use and did they only lubricate the latch mechanism?
Chris
I did not have the same problem as you are having, so I won't guess how to fix it. I don't know where the latch sensor is. I also don;t know how to flush the fluid myself, I would refer this to a qualified mechanic. The lubricant the mechanic used on the latch was just something like WD40.
Best of luck,
Tamir
i found the fuse box but the fuses are not marked
i don't have the manual
Did you get this resolved and how was it resolved? My XK8 has done exactly the same this week.
Matt
Have them test your battery.
I have a 2000 xk8 and it had a few funny electrical problems and I asked them to check.
BTW electrical engineer.
I am sorry about the late response. I had to have the top fixed by the shop. Apparently, one of the sensors were misaligned. Not sure which one it was but I guess it was the one on the back.
Chris
Interestingly when this happens there is distortion in the radio followed by no treble for 30-45 seconds. Given this there appears to be a disturbance of the electrical system under load.
The car had previously gotten some water on Coil #8 when the old owner washed the motor. The check engine light has not come back on since drying the coil but the rust seen on the #8 coil leads me to think it happened before and might be the culpret.
Anyone had this set of issues? Coils? Alternator?
Brent
I have a 99xk8 with exactly the same problem and symptoms. Did you fix it? What was the cause? Thanks.
If you don't have any misfire codes to point you in the right direction I would get one coil and start putting it in different positions until you find one that has a positive effect. Try the most rearward or the most rusty ones first.
Good luck,
Big D topless XKR
Brent
Any advice would be welcome,
Another longsuffering Jag owner seduced by a beautiful body, Will
New '09 XK Coupe owner. Does anyone know if when the passenger door or hatch is open, should there be a chime to go along with the IP notification. Driver's door chimes, not passenger or hatch...
my 98 xk8 conv, after setting all winter in the garage has developed a problem that the top will not open nor will the rear windows go up. the battery checks good but has a drag on it that runs the battery down with everything off. i detect a slight clicking sound when the roof down button is pressed but nothing happens, any ideas? could it be a relay? the fuses are all good
