Ford Escape Hybrid Engine Problems
If you're having a problem under the hood of your Escape hybrid, this is the place to discuss it and work out solutions.
My latest problem is a big one. The piston rod went through the engine on Christmas day. Suddenly without warning. No warning lights. This even though the car has been maintained by the dealership on a regular basis. I love this car, even though I have never gotten over 28 mpg, and I wonder if the new engine (replacement) will help?? I wonder if I will be able to trust it?
Under any circumstances is it possible to run on electric only such as below a certain speed etc? Being new to Hybrids, I would think they would be useful in an emergency situation such as fuel shut offs from the Middle East if that were possible. Given the world situation this could be an unthinkable reality some day.
Also not all hybrids even have full electric launch. Only the Toyotas and Ford/Mercury Hybrids allow for full electric launch.
Mark.
Thanks again for the speedy answer.
Floyd
For instance, if your vehicle is sufficiently warmed up and you take your foot off the gas at 50 mph or higher, then begin to coast (preferably on a downhill)- you can get the vehicle to operate in EV-only from 40mph on down. Lightly touch the gas pedal to maintain the proper speed 30 or 35 mph and you can go for a significant distance on only battery power.
Remember: the computer determines what power train configuration to use to propell the truck forward - from your inputs - one of which is how far and how fast you depress the gas pedal.
The Toyota and Ford hybrid systems start the vehicle out using only electric motors; the ICE kicks in at a certain speed or when the battery needs charging. Above certain speeds or if you floor the pedal, the ICE kicks in immediately.
The Honda and Saturn hybrids use the ICE at all times except when stopped at a stoplight. The electric motors only assist the ICE.
Mark.
Nissan entering the hybrid fray
for more info on the hybrid Altima.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Let's stick to the FEH engine issues here
I have started having the exact same problem with my 2005 escape hybrid. I would get the stop safety soon message and have to coast to the shoulder like you said. The dealership said my car needed a special part (something having to do with a cooling mechanism)and that it would take up to several weeks to get it in. They said my car was safe to drive, however. But no sooner than I picked it up, it happened again. My husband had to practically yell at them to give us a loaner car as it's not safe at all to drive! What has happened with your car since your post?
This is the message from their diagnosis:
Tech #18 verified concern, then checked for codes with IDS, Codes P0119 and P1289, Performed Pinpoint test, found faulty CHT sensor, ordered one.
Once the CHT sensor was replaced, it has not had the same problem. I'm hoping this was the last problem... however, one cannot predict the future
From reports on the first three years of production, these components seem to be the best engineered on the vehicle (the least reported problems). The only report I saw of battery replacement was from a fleet of FEH cabs that had been running continuously in SanFran for 3 years. The batteries didn't fail...they just (prematurely) reached the end of their life span.
No telling what the market will be for replacement batteries in the future...(remanufactured, aftermarket, etc.) but for now the only ones available are brand new - made by Sanyo and purchased only through Ford and the pricing includes installation (labor) by the dealer. (>$5000).
The FEH only uses a very very shallow part of the battery capacity. it does not "deep discharge" the battery.
Google plugin hybrid toyota prius to get some info about this.
Mark.
Prius powertrain is only in its 2nd generation of production. There is no "third generation".
Escape Hybrid and Toyota Prius are basically at the same level right now. Ford and Toyota both use the SAME eCVT (electronic continually variable transmission) from Aisen. The eCVT is what makes the Ford and Toyota "full hybrids" as opposed to the mild hybrids offered by Honda and GM.
The eCVT is the only transmission I know of so far that allows power input from 2 different power sources at 2 different levels. Basically it allows the motors (gas and electric) to be connected to the drive shaft in parallel Honda and GM is a series connection to the wheels. Because of that series connection, the wheels cannot get power from the electric motor unless the gas motor is running also.
At this point Battery Replacement Costs are irrelevant. The warranty is 10 years or 150,000 miles in green and cross border states.
Mark.
Be careful with how you discuss the eCVTs. Toyota uses their design. The FEH uses a Ford/Volvo design. They both use Aisin as a manufacturer. You are correct in that they both follow a "power split" concept that is unique and essential to the similar but distinctly different Ford and Toyota Hybrid drive trains.
Only the second generation for vehicles available to the USA, but the third counting the original Japan-only Prius as Gen 1.
So from a technology and engineering standpoint, the current Prius is on the third generation.
It's only on the second generation if you only consider vehicles available to the USA.
See this page near the top:
some Prius history
And this page too:
More Prius history
This could be a serious error with the hybrid powertrain system. Every time it happens take it in to the dealer. If they can't fix it on the third try, go for a lemon law replacement.
Unless you want to live with the "chug,chug" for the entire length of your ownership...
I have since started tearing the engine apart myself. There is definitely a shattered piston in the pan. It is in numerous pieces. There is also a valve in the pan. The top of the piston pieces look like they slammed into the valve quite a lot. I think that the valve just fell out into the cylinder. This all happened without any overheating or warnings with the exception of a short blink of the oil light on the dash. I have a '99 ragner and the oil gage on that drops off all the time and comes back up again. Also, since i've taken the '06 engine apart, is is a lot less gummed up than the ranger engine is and the ranger engine runs like a top.
I think i'm going to write some letters to Ford and ask them what gives on that. The dealer was no help except to offer to install a new engine for 20% of the cost of the whole car. I have not yet ased about any technical assistance on replacing the engine.
I presume you mean you didn't do any maintenance on the car YOURSELF?
Besides normal oil changes & etc.?
Otherwise you have set a record for mileage between oil changes...
I have had several problems with this as well on my 2005 escape awd (twice) but the dealer said it was the trottle control chip which was replaced. It ran for quite a while with no problems with 45k for the total miles. The othe problem I have is the check engine light which is on more than off but has no effect on the cars performance. It says the gas cap is not on tight and then the emmisions warning indicator comes on, engine light comes on. I have had this gas tank refill tube replaced twice but the problem is still occuring but both the mpg and running of the engine seems normal and performance unaffected.
Roy.
Is anyone has same issue as mine? What would be the problems? Any suggestion?
Thanks in advance,
I had a similar problem, my 06 Escape Hybrid engine seized on me a few weeks ago without any warning, no check engine or low oil pressure light. I had just changed the oil 2000 miles ago or so (no where near the 10,000 recommended interval) and it turns out somehow I was left with only 3/4 of a quart left. How this happened I don't know, no evidence of leaks or anything. I have 89,000 miles on it. This is over the powertrain warranty but within the 100,000 unique hybrid components warranty. Technically the engine is listed under the powertrain but this is a unique engine to the hybrids, brand new specifically for them and with a unique engine cycle (Atkinson). I've talked with the dealer and Ford engineering but they're only wiling to drop the price a little. I'm not happy with this situation and am putting this out as a warning to all other Hybrid escape owners to be careful of this issue.
So bottom line is that the seal between the engine and the transmission blew out.
I'm in contact with Ford Customer Service again.
Did you perform the oil change intervals mentioned in the owner's manual?
Sorry, I'm not that mechanically inclined.
Where did you get a hybrid engine? I believe they are different from the normal I4 Escape, being Atkinson cycle rather than Otto cycle...
On ebay, from a place in North Carolina, shipping was 1/2 the price of the engine. got it for $550. All the others I saw were more like 1700. 60 day warranty,
It started Wednesday night and I drove it around the block Thursday after bleeding the coolant. Not an easy thing to do either. I'll drive it a bit more today and see how it goes.
I have a 2007 Escape Hybrid with only under 10000 miles. The car is horrible, shuts off after 0 minutes of driving,the red triangle simbol cames on.I took it to 3 different ord dealers, and they charged me over $1000 for nothing.s fine. They just can't find the problem. I was suspected overheating, I checked radiator, radiator fan, everything if good. After 20 minutes of driving
it's just shuts off, then when cools off, then starts again.
we also have a ford hyride 2006 and we have exact the same prolems. As we live on Sint Maarten there is no knowledge and they told us that the car can't be repaired anymore. hope you can help us. I can not find your service bulletin on the ford site. can you send us a copy of it so we can go te garage with it.
The engine is hybrid specific, and when you get the replacement engine see if the computer that came with the engine is also available. In the 05/06 series there are 5 different ECMS used, Make sure if you are changing engines the ECM will work with the new engine. I do have a spare that came out when we changed a trans axle and it would not talk to the new one. tya2@4-fly.net
escape06
Thanks for your help.
Robert
Also, the CAT warms more quickly at higher idle speed as well.
