Ford Escape Hybrid Electrical & Lighting Problems
Discuss Escape hybrid electrical and lighting problems here.
Mark.
do you know what your problem is? taking it to the dealer tomorrow.
i'm having the same problem
Not quite. The traction battery also starts the engine by spinning it up via the electric generator.
One interesting thing about the FEH is that the 12v battery is only needed to supply power to the electronics (when starting the vehicle) - it does not actually provide startup power.
Well, I was hoping to clarify the manner in which the FEH starts. On most vehicles the 12v battery turns a starter motor; thus the 12v battery starts the car. On the FEH the main traction battery starts the vehicle. It is also why the FEH won't start in Neutral. I hope my original post was clear that the 12v only powers up the electronics.
Page 235 of my 2008 owners manual has a procedure for jump starting the high voltage battery from the 12v battery, but there is no means to provide a jump start TO the 12v battery, an interesting omission.
Are you positive that the dealer did not install an after market alarm? These are not permitted on the FEH, but I have read of some dealers installing them anyway, to generate money from the add-on.
From your description it sounds like a bad contact on the passenger door, but I just thought I'd mention the obvious.
Is it ok to charging the phone while the car is parked (engine off) ? i'm asking since it's still charging when the engine is off
thanks.,
But just to get this right... the dealer pulls the fuses, says, "These is OK", pulls the bulbs, finds out they're fine, stops at that and says he can't find anything wrong??
You might want to consider finding another service place if that's the case. That's sort of like saying, "The car won't start. I checked that there's gas in the tank and the battery has a charge... I can't find anything wrong"
Before you let anyone chase some imagined electrical gremlin, make sure they've checked the switch and the wiring that runs to it. Other than the connection to the power source, that circuit has no interaction with any other electrical system in the car. So it HAS to be a continuity problem in the circuit somewhere.
Since I got my '08 FEH back after getting a new water pump at 80k miles I have had the powertrain (lighted wrench) warning come on and stay on three times. The FEH runs fine and I pull it over, turn it off and on again and the warning light goes away.It has not happened in over a month.
The Ford dealer needs to put in the warranty request for the entire battery pack, which includes the fan. The fan is not supposed to be replaced by itself. If the dealer requests the warranty this way, it will be covered. If they just put in the fan stock number, the warranty coverage will be rejected. Many owners have had their similar problem fixed under the 10 year warranty.
warning lamp" came on along with a text message said to stop the immediately, which I did. I turned the engine off and restarted it. The warning was gone, so I resumed my trip home. The warning came on 2 more times in the 4 mi trip home. The error was reset when the engine was restarted. This is a scary warning! I researched this error on the internet and it appears there are many type of failures that can cause it (read: hard to fix). My research indicated this error strikes vehicles with 50K+ miles across all model years. I traded it in the next day. I don't want to deal with an intermittent catastrophic failure. I am normally 50-100 mi from home on the weekends in rural areas where there is little or no cell service. I lost my taste for hybrids.
:sick:
Good luck with your new ride! What did you get to replace your FEH?
I like the Escape, so I bought a 2012 v6 Escape. It gets significantly poorer MPGs, but I really like the extra power of the v6. It is a real highway cruiser.
Regards
That sounds like a great car for you. You might want to check in on the Escape forums to meet with others that have that drivetrain.
