Land Rover OBDII Codes
carl20carl20 Posts: 3
edited September 2014 in Land Rover
Hi - I have a 97 discovery. The service engine light came on, but rather than pay the dealer $100 to check it I bought a code reader. It shows p0430. This code indicates that the "catalyst system efficiency below threshold (bank II)" I just replaced one sensor not long ago (for $900!!!)- do others need to be replaced, or is a whole new catalytic converter needed? Is there any danger in driving it? thanks, Carl
  • Should not effect how it drives at all as this is just an emissions check. Sounds to me like your catalytic converter has finaly given up the ghost. Not unusualy on a 10 year old car.
  • I recently went through inspection in Wash.DC and was told that my Discovery (1997) needed repair on PO130 O2Sensor Circuit Malfunction (Bank 1 Sensor 1) P1317.. Can Anyone please :confuse: break that down in layman's terms 4 me and prices please if possible......Thanx">
  • Where is the port on the LR3? I'm curious as to what I can glean from my LR3 with an OBD2 reader...
    /DA
  • I found these OBDII code for Disco I's (up to 1998's) on another forum, posted by a factory technican. Repost here for future reference.
    ___________________________________________________________
    Trouble Code Chart
    DTC
    Fault Description
    P0101
    Mass Air Flow Sensor Signal Error Fault
    P0102
    Mass Air Flow Sensor Low out of Range Fault
    P0103
    Mass Air Flow Sensor High out of Range Fault
    P0111
    Air Temperature Signal Error Fault
    P0112
    Air Temperature Low out of Range Fault
    P0113
    Air Temperature High out of Range Fault
    P0116
    Engine Coolant Temperature Sensor Falling Temp Fault
    P0117
    Engine Coolant Temperature Sensor Low out of Range Fault
    P0118
    Engine Coolant Temperature Sensor High out of Range Fault
    P0121
    Throttle Position Sensor Output Signal Error Fault
    P0122
    Throttle Position Sensor Low out of Range Fault
    P0123
    Throttle Position Sensor High out of Range Fault
    P0125
    Engine Coolant Temp Sensor Warm Up Fault
    P0130
    Oxygen Sensor Cycle Fault *codes* A U
    P0131
    Oxygen Sensor Low Voltage *codes* A U
    P0132
    Oxygen Sensor High Voltage *codes* A U
    P0133
    Oxygen Sensor Slow response *codes* A U
    P0136
    Oxygen Sensor Cycle Fault *codes* A D
    P0137
    Oxygen Sensor Low Voltage *codes* A D
    P0138
    Oxygen Sensor High Voltage *codes* A D
    P0139
    Oxygen Sensor Slow response *codes* A D
    P0150
    Oxygen Sensor Cycle Fault *codes* B U
    P0151
    Oxygen Sensor Low Voltage *codes* BU
    P0152
    Oxygen Sensor High Voltage *codes* BU
    P0153
    Oxygen Sensor Slow response *codes* B U
    P0156
    Oxygen Sensor Cycle Fault *codes* B D
    P0157
    Oxygen Sensor Low Voltage *codes* BD
    P0158
    Oxygen Sensor High Voltage *codes* BD
    P0159
    Oxygen Sensor Slow response *codes* B D
    P0171
    Oxygen Sensor System Too Lean Fault Bank A
    P0172
    Oxygen Sensor System Too Rich Fault Bank A
    P0174
    Oxygen Sensor System Too Lean Fault Bank B
    P0175
    Oxygen Sensor System Too Rich Fault Bank B
    P0181
    Fuel Temperature Sensor Signal Error Fault
    P0182
    Fuel Temperature Sensor Low out of Range Fault
    P0183
    Fuel Temperature Sensor High out of Range Fault
    P0201
    Injector 1 Circuit Fault
    P0202
    Injector 2 Circuit Fault
    P0203
    Injector 3 Circuit Fault
    P0204
    Injector 4 Circuit Fault
    P0205
    Injector 5 Circuit Fault
    P0206
    Injector 6 Circuit Fault
    P0207
    Injector 7 Circuit Fault
    P0208
    Injector 8 Circuit Fault
    P0300
    Misfire on Multiple Cylinder
    P0301
    Misfire on Cylinder 1
    P0302
    Misfire on Cylinder 2
    P0303
    Misfire on Cylinder 3
    P0304
    Misfire on Cylinder 4
    P0305
    Misfire on Cylinder 5
    P0306
    Misfire on Cylinder 6
    P0307
    Misfire on Cylinder 7
    P0308
    Misfire on Cylinder 8
    P0326
    Continuous Knock Fault Bank A
    P0327
    Background Noise Low Fault Bank A
    P0328
    Background Noise High Fault Bank A
    P0331
    Continuous Knock Fault Bank B
    P0332
    Background Noise Low Fault Bank B
    P0333
    Background Noise High Fault Bank B
    P0335
    Crankshaft Position Sensor Signal Error Fault
    P0336
    Crankshaft Position Sensor Out of Range Fault
    P0340
    Camshaft Position Sensor Signal Error Fault
    P0420
    Catalyst Efficiency Low Fault Bank A
    P0430
    Catalyst Efficiency Low Fault Bank B
    P0441
    Evap. Purge Valve Incorrect Flow Fault
    P0442
    Evap System Small Leak Detected Fault
    P0443
    Evap. Purge Valve Open or Short Circuit Fault
    P0451
    Fuel Tank Pressure Sensor Signal Error Fault
    P0452
    Fuel Tank Pressure Sensor Low Out of Range Fault
    P0453
    Fuel Tank Pressure Sensor High Out of Range Fault
    P0461
    Fuel Tank Level Measurement Not Valid Fault
    P0500
    Vehicle Speed Sensor Signal Error Fault
    P0506
    Idle Speed Control Engine Speed Low Fault
    P0507
    Idle Speed Control Engine Speed High Fault
    P0560
    Battery Voltage Below minimum Fault
    P0562
    Measurement Circuit OK Battery Voltage Low Fault
    P0563
    Battery Voltage Above Maximum Fault
    P0605
    ECM Self Test Fault
    P1130
    Oxygen Sensor Fuel Trim at Limit *codes* A U
    P1131
    Oxygen Sensor Lean *codes* A U
    P1132
    Oxygen Sensor Rich *codes* A U
    P1137
    Oxygen Sensor Lean *codes* A D
    P1138
    Oxygen Sensor Rich *codes* A D
    P1150
    Oxygen Sensor Fuel Trim at Limit *codes* B U
    P1151
    Oxygen Sensor Lean *codes* B U
    P1152
    Oxygen Sensor Rich *codes* B U
    P1157
    Oxygen Sensor Lean *codes* B D
    P1158
    Oxygen Sensor Rich *codes* B D
    P1171
    Oxygen Sensor System too Lean Fault Banks A & B
    P1172
    Oxygen Sensor System too Rich Fault Banks A & B
    P1176
    Maximum Positive FMFR Correction Fault
    P1177
    Maximum Negative FMFR Correction Fault
    P1178
    Maximum Positive AMFR Correction Fault
    P1179
    Maximum Negative AMFR Correction Fault
    P1185
    Oxygen Sensor Heater Circuit Open Upstream
    P1186
    Oxygen Sensor Heater Circuit Short Upstream
    P1187
    P1188
    Oxygen Sensor Heater High Resistance Upstream
    P1189
    Oxygen Sensor Heater Type 1 Low Resistance Upstream
    P1190
    Oxygen Sensor Heater Type 2 Low Resistance Upstream
    P1191
    Oxygen Sensor Heater Circuit Open Downstream
    P1192
    Oxygen Sensor Heater Circuit Short Downstream
    P1193
    P1194
    Oxygen Sensor Heater High Resistance Downstream
    P1195
    Oxygen Sensor Heater Type 1 Low Resistance Downstream
    P1196
    Oxygen Sensor Heater Type 2 Low Resistance Downstream
    P1199
    Fuel Level Sensor Circuit Fault
    P1201
    Injector 1 Open Circuit or Ground Short Fault
    P1202
    Injector 2 Open Circuit or Ground Short Fault
    P1203
    Injector 3 Open Circuit or Ground Short Fault
    P1204
    Injector 4 Open Circuit or Ground Short Fault
    P1205
    Injector 5 Open Circuit or Ground Short Fault
    P1206
    Injector 6 Open Circuit or Ground Short Fault
    P1207
    Injector 7 Open Circuit or Ground Short Fault
    P1208
    Injector 8 Open Circuit or Ground Short Fault
    P1313
    Misfire Catalyst Damage Fault Bank A
    P1314
    Misfire Catalyst Damage Fault Bank B
    P1315
    Misfire Persistent Fault
    P1316
    Misfire Excessive Emissions Fault
    P1317
    ABS Rough Road Line Low Fault
    P1318
    ABS Rough Road Line High Fault
    P1361
    No Ignition Coil Activation Fault Coil 1
    P1362
    No Ignition Coil Activation Fault Coil 2
    P1363
    No Ignition Coil Activation Fault Coil 3
    P1364
    No Ignition Coil Activation Fault Coil 4
    P1371
    Early Ignition Coil Activation Fault Coil 1
    P1372
    Early Ignition Coil Activation Fault Coil 2
    P1373
    Early Ignition Coil Activation Fault Coil 3
    P1374
    Early Ignition Coil Activation Fault Coil 4
    P1440
    Evap System Purge Valve Stuck Open Fault
    P1441
    Evap System Purge Valve Flow 1 Fault
    P1442
    Evap System Purge Valve Blocked Fault
    P1447
    Evap System Purge Valve Open or Short Circuit Fault
    P1448
    Evap System Purge Valve Flow 2 Fault
    P1508
    Idle Speed Control Open Circuit Fault
    P1509
    Idle Speed Control Short Circuit Fault
    P1514
    Neutral Drive Load Fault
    P1516
    Neutral Drive Gear Change Fault
    P1517
    Neutral Drive Cranking Fault
    P1607
    Malfunction Indicator Lamp Short Circuit Fault
    P1608
    Malfunction Indicator Lamp Open Circuit Fault
    P1620
    Reprogramming Code Learn Fault
    P1621
    Serial Data Link Dead Fault
    P1622
    Repeated Wrong ECM Security Code Fault
    P1623
  • Message got truncated. Here are the rest of the codes:
    P1621
    P1622
    P1623
    P1701
    Transfer Box Line Fault
    P1703
    Transfer Box Line Open Circuit Fault
    P1708
    Transfer Box Line Short Circuit Fault
    P1775
    Gearbox Fault
    P1776
    Gearbox Ignition Retard Request Timeout Fault
    P1777
    Gearbox Ignition Retard Request Line Fault
  • plesterplester Posts: 3
    I have 2001 Discovery II, can anyone tell me where I can get these codes and how to reset them? The one dealer in my area is very, very expensive and I have a good foreign car mechanic but he does not know what it could be. He sees nothing wron except for this light that continuously stays on, however, the truck runs superbly. Any information would be greatly appreciated.
  • aurisauris Posts: 1
    Hello everyone. I have a DiscoII 02, And I would like to know if there is a compatible scan tool out there. So I can scan and also clear the codes on my Disco II. And which brand in the market are more reliable.. Thanks for the help..
  • bmack1bmack1 Posts: 1
    Have 1998 discovery 4.0 eng. The motor starts fine but will not rev -up. The engine will not rev above 1200 rpm cough and backfires in plenum Replaced spark plugs and spark plug wires. All the new plugs carbon fouled in 5 min. of running
    checked air cleaner, mass air flow sensor, fuel pressure is 40 psi. compression check 160 to 170 psi, spark is hot to each plug. No check engine light on but did check for fault codes. Codes were p 1194, p 1191, p 0158,p 0138, p 1138, p 0300, p0307, p 0302, p 0301, p 1316, p 1314, p 1313. Codes indicate miss fire to plugs, and o2 sensors. The engine acts like air intake leak but can't find any.
    o2 sensors should not have any effect untill the come up to temp.
    Any ideas?
  • fguzmanfguzman Posts: 1
    Hi I have a 2001 Mitsubishi Montero XLS and I have received the above codes; Fuel Trim too Rich (Bank 2) ; and Insufficient Coolant Temperature for Closed Loop Fuel Control;ECT Excessive Time to Closed Loop Fuel Control. Can anybody tell me how I fix this problems. Thank you.
  • Hi The obd11 port is in the drivers side footwell look up you will see it
  • Scan Gauge II work great. I use one in my 02 landy. http://www.scangauge.com
  • koolkris1koolkris1 Posts: 1
    I HAVE AN 2005 FREELANDER WITC DTC P1775 GEARBOX FAULT AND P1605 KEEP ALIVE MEMORY TEST FAILURE.....ANY IDEAS?
  • I have these codes come up in my scanner and dont know what they are for: 1412 and 1415. Can anyone help me?
  • I have been talking. I first got a p 1316 and replaced the plugs and wires. The water pump went out and I shortly after that got p1316 again and a p0301. I have to talk to my mechanic tonight but, talking to the locals it might be my 101,000 mile 99 could need a firing strip and/or a timing chain job, my mechanic often disagress with me though. I need to check to make sure the misfire in cylinder 1 is not the plug and go from there, fule injector etc. Common fixes on the scanner where: change plugs and wires. I did that and andnow I am doing the crank shaft positioning sensor. it cast less than 56.00 at advanced auto parts here in Florida. My Mechanic is good and cheap he will do that job for say about 50.So, grand total 100+ a little$.
    Timing chain job will be about as I see it from Atlanitc British a kit is 109+ shipping and labor I would think would be about 250-300$. Knowing Rodney.
Land Rover OBDII Codes - Car Forums at Edmunds.com
