Geo Metro Transmission Questions
I just purchased a 97 Geo Metro in August from a car dealer for $3500..I've owned the car 3 months, and went to get tabs for it and then licensing told me I had to go thru emissions..It failed..Catalyst System Efficiency Below Threshold Bank 1 was the code..Had appt at Pep Boys and went in..The were taking info from me as the Mechanic walked by and saw my slip and told me he would NOT work on my car cuz the problem was the catalytic converter was bad and that they didnt do that there. He recommended me go to Walts..Instead my dad recommended I go to Midas..Midas checked the catalytic converter and said it was fine and nothing wrong with it..I went back to Pep Boys and talked to another mechanic and he told me the same thing that it was the catalytic converter and I told him that I took it to Midas and they told me catalytic was good no problem..he told me to take it to Walts..I went to leave the parking lot and my car wouldnt go in reverse..Took few minutes of messing with gear..Finally backed up..Going home the driving gears didnt want to shift (automatic) so I made it home in low gear..My dad came over and checked transmission fluid and it was empty..He added fluid and now the car wouldnt go in reverse this morning but did once this evening long enough to back into the driveway..Car doesnt want to change driving gears, but does eventually..Is transmission going out or my dad thinks it could be clogged up and needs the transmission flushed out and new fluid added? Come someone help?
What is the easiest way to remove the automatic tranny from a 95 Metro? The book says from the bottom but a friend says from the top with engine. How hard is the tranny rebuild or should I go for the bone yard replacement. Any help is appreciated.
Al
P.S. I tried to use search but could not get any info.
Grumpyray
I filled this car before and know nothing has changed.
Can someone tell me where it is.
Also, what is the two wire sensor on top right end of gearbox looking from front?
Thanks to anyone and everyone who can help.
I have to confess that "I just can't drive 55"!! Interstate speed is 75 and I drove 80-85 when in that zone. I've been unaware at times and had "her" up to 90 at times. She doesn't like it that fast. She starts vibrating.
I don't know, but perhaps someone may have put a Governor on your car for some reason. Have you asked a mechanic about the possible causes? Interesting situation! Hope you find out the cause.
Sherry
I live in Puerto Vallarta, Mexico, and drive a 2000 2-door Tracker which I adore! We had lots of rain over the last few days, and now I can hear water sloshing around in the undercarriage when I drive it. I cannot find the drain hole in my owner's manual.
I need help, please, before the whole thing starts rusting...
Any help appreciated.
-Shawn
Measure resistance btn pin "21" and "22" light Grn & PPL wires is resistance 160 to 200 ohms, yes? measure resistance from "21" light Grn to Ground is resistance infinite, yes? measure resistance from "22" PPL to Ground is resistance infinite, yes? all tests are normal. Keep me posted
