Honda CR-V Sunroof and Water Leaks
hondagirl2001
Member Posts: 1
I have a 2001 Honda CR-V with a leakage problem. Originally it was coming into the passenger side. My father and I partially took apart the trim at the base of the windshield to see if we could find where the water was coming in, but found nothing. So we put it back together and oddly enough, no more wate came it. At least on that side. Now water comes in on the drivers side. When it rains hard, I actually have standing water in the car. We took off the wipers and completely removed the trim piece, then ran a hose on it. No water came in at all. So we put it back together, and the next time it rained, i had water inside again. I see inside where it looks like it is coming in. There are drops of water at the buttons for both the rear window and the lever for the hood. Like it is coming in there. Though my father looked behind those spots with a mirror and did not see anything. Does anyone have any ideas??? I would really appreciate it. Thanks!
If it was only in the channels, there are drain holes in these channels which direct water through tubes to under the vehicle. This is normal at times to expect some leakage.
If water leaked into the interior, then you have a problem.
Take it back to the dealer and ask him for a leak test.
I have owned an 02V and have an 07V, on occasion I have had moisture in the drain channels.
