Caravan/Voyager Accessories & Modifications
I need a hitch for my van, for simply attaching a bicycle carrier. The hitch needs to have either 1 1/4 or 2" opening. Any ideas for a good one? Very preferably, it will be fairly lightweight.
http://www.discountvantruck.com/rvvanseating/allvansofabedsseats.htm
http://www.superior-seats.com/VanSeating.htm
Gerard
Flowmaster Upgrade
link titlehttp://www.youtube.com/watch?v=UrvAiVUOKjYlink">
for roof rack for your van
I use foam bumpers attached to roof rack cross members to rest my kayak and never had any problems or rack/kayak breakage (my kayak weights some 50# ).
I don't think you will have any problems with water leakage, since rack mounts in roof channels designed for this.
You may find a new OEM roof rack at DodgeParts.com, or better yet , you may get a lot cheaper OEM rack at your local junkyard.
Hope this helps.
It worked fine... But be aware... Seen cases where too short a belt was used, inducing oil leakage at the crankshaft o-ring seal, cause the rubber o-ring have worn old, lost flexibility, hardening at the "relaxed" position. Also, this may happen with a new stronger OEM tensioner. It all depends on the car's age and your luck! But once this happens, you will have to replace the ring!!!
I can only guess that a worn 3.3 develops less "give" at the crankshaft o-ring.
Best of luck!
