Chevy Venture Electrical Problems
Does anyone know if and possibly where the fuses for all of the interior lights -courtesy inside rear. There are no lights going on and I can't seem to find any fuse for this problem in the fusebox under the hood. I checked the bulbs and they are good they just don't work. Any help will be greatly appreciated.
When he was younger, my grandson liked to mess with these switches and sometimes left the interior lights turned off.
John
Any other ideas?
John
Thanks, RP
Cheers,
RP
I have the same problem with my 01 Venture. I have checked the fan motors replaced the relays, checked the temp sensor, still the 1&2 cool fans dont work and the a/c compressor wont come on. If I figure this out I will let you know.
Any thoughts?
The Airbag warning light remains on after I start it up.
Also my temp gauge stops working sometimes.
It will start out working fine and after driving for about 10 miles or so it just goes down to "C" and stays there. I have an after market scan tool so I am able to see the actual temp of the coolant. I drove to work and the gauge stopped working on the way. When I returned home, both fans were running and the scan tool indicated the temp was 167 degrees. I found this strange because I had just driven 70 miles on the freeway.The intake gasket and the thermostat was just replaced the cooling system just flushed (3) times. I Did not use "Dexcool". A very good GM mechanic of mine which I trust with all of my cars (22 years GM Exp. with heavy repair) says that "Dexcool" crystalizes and plugs the cooling system. (You can see for yourself when you remove the cap on the radiator and overflow bottle.)I am wondering if there is something I can check to fix these problems. TIA
2002 Venture Van 3.4
Runs perfectly but occasionally lites come on and go away soon after.
Any thoughts?
Adam
Lagrange, IN
The 1st to appear was the door locks would unlock themselves repeatedly while driving or parked. Checked door locks and BCM (body control module)No luck.
The 2nd problem started a few weeks later. There is a sensor below the windshield that brightens the radio display in daylight and dims it at night. Now the radio is normal in daylight unlit at night.
I have heard mention of some troublesome connections/splices in the venture wiring under the carpet. Could this be the problem?
The interior lights do not come on when the doors open. They work, but only when I manually turn the lights on.
Is there some switch I need to hit to allow for them to come on automatically?
Also, the back seat overhead controls for the heat also do not seem to work, even when I put the front switch on "R"...any help greatly appreciated
Low voltage in any vehicle can make the electronics do weird things - if the supply voltage isn't right it gets everything "confused"
Good Luck - these alternators are a royal pain to replace. On the 2000+ years you rotate the engine forward to get to them, I believe before 2000 you get to it from the bottom by loosening or removing a frame part
I'll assume you're talking about the front HVAC blower. You may want to check your blower motor resistor - (its located right behind the blower motor in the passenger side wheel well) but typically when they fail you lose 1 or more speeds on your blower.
But I'm thinking that your fan speed selector switch is shot - sounds like its sending voltage to the resistor even when you put it in the off position. Its a pretty simple circuit so its got to be 1 or the other.
BTW - blower motor resistor failures are common on Ventures...just not sure its your problem in this case
I have a 2001 Chevy Venture that is behaving a little strangely.
It appears that the brake lights are not working at all. When we depress the brake pedal the intensity of the lights do not increase at all. I also took the lights out of the housing and noticed that the second filament does not light up when the brake is depressed.
I have replaced the bulbs with brand new ones.
What could be causing this issue? Is there something wrong in the electrical?
Thank you for any help ... if there is any information that I could add that would help, please let em know.
