Ford Escape Transmission Problems
1235»
  • steverstever Viva Las CrucesPosts: 50,068
    edited May 2012
    You could contact Ford and ask them to open a case for you. Maybe they'll have a tech inspect your Escape. Maybe there's something in their records that hasn't trickled down to the dealers yet.
    But I doubt that they'll do anything to extend the warranty since you have a 5/60 drivetrain warranty. What I would do is keep track of your receipts and your complaints and take it to the dealer for service until it does run out of warranty. Then if you have more problems with it, maybe you can get Ford to cover it.
    The Secret Warranty - Understanding After Warranty Assistance
    If it fails out of warranty and Ford won't cover it, your receipts and complaints may help if you go to small claims or your local consumer protection agency for some sort of implied warranty claim.
    Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
  • Wow, my wife and I were actually feeling guilty about filing a lemon law suit against Ford. But after reading some of these posts it is obvious that we are doing the right thing. Our Transmission started to slam into gear, even at high speed i.e. freeway driving. When I took the vehicle to Ford, I was promptly asked about my driving habits, do I come to a complete stop before taking off. When I mentioned it happened at high speed they then said they needed to re-key the chip in the transmission, but the problem continued. There is also a vibration that comes from the front drive axle, thought it was the cv boot or the oil pan, but was told that a part no specifics was needed and it was on order. It has been over two months. No more Fords for this family.
  • bill380bill380 Posts: 1
    My 2009 escape downshifts while in cruise when going down hills. the dealer said this condition is normal and nothing is wrong. this does not make sense to me. I never had a car that downshifted in cruise when going 70 mph down hill.
  • wwestwwest Posts: 10,706
    Historically most CC systems will only retard the engine timing if the car starts to overspeed a few miles above setpoint.
    But now we have this new full fuel cut technique to extend FE, engine FULLY starved of fuel during coastdown periods. If the gas pedal, even in CC, reaches the point of being fully released. At that point the transaxle will begin to be downshifted to keep the engine turning over above stall RPM.
    Fraught with peril in a FWD or F/awd IMMHO.
  • calguy1calguy1 Posts: 1
    Don't feel bad at all....I have considering the same. I have a 2010 Ford Escape and it is in the shop for its 3rd transmission!!! This after my 2007 Ford Fusion's transmission blew up 1,500 miles past the warranty - was actually stranded 250 miles from home and got towed to a Ford dealer....which is where I got this Ford. Wished I would have gotten towed to a Chevy dealer!!! I am looking into filing a lemon law claim myself....any guidance?
  • Sure- have everyone of your receipts- that show you bought the vehicle new- have taken it back to the selling dealer- they can't fix your suspected problem in 3 tries
    everything else falls into the catorgory of you and your dealer aren't comunicating properly
    so many crybabies- so few of ducumented cases where the dealer you bought your new vehicle from can't or won't fix your suspected defects to the point it is a defect in manufacturing- meaning- a factual documented case where you have one that doesn't perform/is bad/ isn't like what is manufactured
  • Hi bill380
    I was researching the 2009 Mercury Mariner, as my mother was looking to purchase a used one, and nearly did yesterday. That came to a complete halt when I came across a post on fordforumsonline.com re: 2009 - 2010 Ford Escape and Mercury Mariner + Fusion etc Customer Satisfaction Program 10b15-r10b15-1.pdf. In short Ford will reprogram the tranny and replace all parts includng clutch and anything else the tranny caused problems for.
    Entire link below:
    http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&ved=0CGAQ- FjAF&url=http%3A%2F%2Fwww.fordforumsonline.com%2Fforum%2Fattachments%2Fford-esca- pe%2F354-customer-satisfaction-program-10b15-r10b15-1-.pdf&ei=buHJUMGCJMfeiAL5nI- CgAg&usg=AFQjCNFAQyRncbhsgdef08vnksI-gA61oA&bvm=bv.1355325884,d.cGE
    The dealership that I sent this too said they came up with a blank page and couldn't get to it. Hope you have better luck. I also hope this info is not reaching you too late.
    Rosemary9
    Try this one. It's a pdf file.
  • I have a 03 escape 3.0 4wd. the problem i'm having is with the transmission. The truck works in all gears but drive. it wont engage in drive from the start. But i'm able to shift it into drive if i start out in 1st then 2nd and move it into Drive then it drives fine. From my understanding the filter is located in the transmission case and not in the pan, Is this true? i just picked this up and planed to replace the transmission anyway, but i dont want to waste money if i dont have to... Also do i have to replace the torque converter if i put in used transmission or rebuild it myself..
    thanks for any help you can give.....
    Also the o/d light will start flashing once i get upto 50mph.
    And no i'm not getting any transmission codes.
  • stevedebistevedebi LAPosts: 4,051
    "Sure- have everyone of your receipts- that show you bought the vehicle new- have taken it back to the selling dealer- they can't fix your suspected problem in 3 tries "
    Not sure of other states, but for accuracy, the Lemon Law in California only applies if you bought the car new, and within one year you had the vehicle in three times for the same problem, or the car was out of service for 30 days. It does not apply after that first year, or with a used car.
    Some states require as many as 5 trips and even if you win, the dealer may get one more try to fix it. Lemon laws need work. And they don't usually don't apply if you buy your car out of state. But there's always your local consumer protection agency or AG's office or your personal attorney could probably do a failure of warranty kind of claim.
  • hi guys i hv 2002 ford escape automatic wit 184k on cloak my promblem is it wont drive if i put th gear in D,1or 2 .it wil only reverse if i pt into R.i did an oil change smetime last year and i thnk i hv dne close t 10k since th.my uneducated ws it could b tht it needs another oil change bt i undrstand th filter is right inside th gearbox.ws wondering also if its possible t do a flush without openin th transmission.pliz smeone help.
  • yes, we here in Canada have had a lot of problems with tranny! mostly huge clunk sound when changing from 1 to 2nd. I am still trying to find the 6th gear.
  • Replaced solenoid pack in my 02 ford escape v6 said replace rad too spent 1400 o/d light flashing everything fixed runs great week later same problem towed it back to shop test drove it no slips no took it home Trans started to skip on highway o/d light flashing again everything same as before shut it off started back up no lights ran fine drove back to shop check engine light came on started to skip again o/d flashing read code p1744 shop says needs new granny but I drove it home fine what's going on?
  • my friend just had her tranny die on hers, and I went to the page you said Rosemary9 and yes the page is blank, but then there is a pop up with the info its 7 pages long. I printed it out for my friend so they don't give her a hard time about not coming up. thank you, I hope this helps.
  • most tranny or other engine parts give indication before stopping or dieing. If its not in Ford's system about screwups, they will ignore you. Or as my experience, 'we have never heard of that happening before', till you get on the web.
  • hi
    i have a problem with my mariner lincoln 2010 same you...
    fixed problem you ?
    thank for you help!!!!
  • I purchased this 35 days ago and the transmission is now gone. Would the dealer have known there was a problem when they sold it to me? Is there a way to cover up a problem like this? The transmission went out all at once, fine one day, gone the next.
  • I have an intermittent problem with our 2012 Escape Ltd on start up. The transmission will not shift out of park and as another symptom the radio display will show the radio is on but no volume. Similarly, the fan speed display will show I am increasing / decreasing the fan speed but the fan does not work. Seems all very strange for seemingly unrelated functions. The temporary fix I have found is to turn off the vehicle, open and close the car door and restart the vehicle. Much like rebooting a computer, not the way to fix your vehicle problem. Ford Service folks where not able to identify this problem but then it is intermittent and may only occur 1 - 3 times in a couple of months.
  • Hi i have a ford escape 2002 with 180k on clock.one day it couldnt drive it could only reverse.i opened th pump side of gearbox the forward friction and steel plates were burnt.the band had snaped on one side,the ban servo had worn out and the drum ws chewed up.i replaced all this including the pump which i suspected wasnt functioning wel which could hve caused the al ths.bt after al this trouble the car wont drive forward or reverse either someone hinted tht it could be a bad torque converter.i removed an oil pipe tht runs from th gearbox to radiator when th car is runnin and warmed up bt thy is oil cmin out frm th gear which makes me suspect tht th converter may b worn out.pliz hs anyone cme across ths problem an insight wil be welcome.
  • sandman_6472sandman_6472 Coral Springs, FLPosts: 3,598
    Am thinking of buying one in the morning. Should I be worried here??? Should I go through with this purchase or just hold off here? It is slightly used, 1830 miles, so almost like new. Love it and the color but just not sure as have heard horror stories about Fords. Not sure if I could actually live with one but I really really like it...a lot! So folks, yes or no!!!
    Sorry for the short notice here.
    The Sandman :) :sick: :shades:
    2015 Audi A3 (wife) / 2015 Golf TSI (me) / 2009 Nissan Versa SL Hatch (daughter #1) / 2008 Hyundai Accent GLS (daughter #2)
    Drove two different Escape SE's this week and one was great while the other was lousy. Think both had the larger 2.5 engine but the first was super loud and the second was pretty quiet though both had substantial road noise at speed...those mirrors are probably to blame, not too aerodynamic at all. The 2nd felt much more comfortable but it did have the nicer leather seats...come to think of it, the 2nd one could've been an SEL model to be honest with ya. Still glad I didn't buy the SE with the 1.6 turbo engine last month...nice enough vehicle but a bit too large for me and hated the engine and after reading the consumer reviews, was very glad. They did try to get me to come back though, mighty hard, but I had already bought my current vehicle by that time. I don't buy often and take my prep time but when I am ready to pull the trigger...I am ready! And I usually only give ya one try to get me to open my wallet so any sales person needs to do an outstanding job or I just walk. And it's always nice to be in the position where one doesn't really have to buy at that moment...and that's the point I was at, if it happened...great and if not...great also! Best way to purchase after one has done their due diligence and gathered all their information. We all should make an informed decision since these kind of large purchases are kept for awhile...usually. For some silly reason though, my wife thinks my new 2014 Tuscon will be gone within a short number of years for some reason. I love it so far except the low gas mileage but this should improve with more miles on the clock...hopefully!
    _The Sandman :) B) _
  • can 2005 ford escape hybrid be converted to normal transmission?"
    No. It requires the CVT for the hybrid parts to function.
  • my wifes 2014 escape with 70,000 miles has the transmission acting up. Dealer said it needs to be replaced and torn apart to the tune of $6000. Fords transmissions are junk never buy a Ford again.
    edited November 2015
    The Focus auto tranny is crap also and though the 2015 is not as bad, that stumbling issue is still there. Would never ever ever buy a Ford product even though I almost got a 2014 Escape before the wife said "no way in hell" would there ever be a Ford product in our garage. That auto tranny stumbling issue is something I've never felt in any other vehicle to the extent that the Ford's do it and working for Hertz, I drive a whole mess of Ford products especially Foci...our sister office is in the Ford dealership and we hear so many complaints and a high majority of renters swap out of their Foci within a day or two. Many even request on their reservations "no Focus or Fiesta"...so it's not only an issue I have. Do a "google search" on the topic and see what's out there. Have no clue why Ford can not get this issue right!
    And before folks start jumping on me here, I know all manufacturer's have issues but this one is a pretty serious one and can be a safety hazard when a vehicle will not accelerate properly to merge into traffic or just get up and go. Our couple of Lincoln's were nice vehicles, our 1966 and 1972, very nice vehicles which we loved. Our 1972 Ford Torino Sport was a problem from day 1 with the high compression engine...who buys a new car and it has to be towed back to the dealership not even 5 miles away? An issue from day 1 that was never truly resolved by Ford, they just basically threw up their hands and said "too bad" once the warranty was up. They sure did try to fix things before then but at 36001 on the clock, they basically said " [non-permissible content removed]! Thus after that treatment, we never ever would spend a nickel in their stores. We were scarred for life and no other member of our family ever bought a Ford product after that, immediate family and cousins!
    The Sandman :@ :( B)
  • trainmom60trainmom60 Posts: 1
    So driving home from work last Tuesday 2008, Escape about 100,000miles, I noted that the care seemed to be hesitating the RPM was higher than normal. As I was driving the wrench showed up on the dashboard, stopped at automotive place they connected under the dashboard and it read Gear 2 Incorrect Ratio...so I have spent most of the day reading what this means. I had many suggestions most about changing the transmission fluids, mine looks clean nothing floating in it. Anyone have any idea what kind of cost I could be looking at or idea of what this means, seems pretty soon for a new transmission, I don't drive crazy no a 4wd off road stuff. Looking for any ideas, or past experiences?
1235»
Ford Escape Transmission Problems - Page 5 — Car Forums at Edmunds.com
