Ford F-Series Stalling and No Start Problems
This truck is a 2000 model with the Triton V10, automatic transmission and only has 40,000.00 miles. Recently, while coming to a stop. The truck seems to lunge forward and stalls. The only way to get out of the situation is to put the truck in neutral, start it up and put it into drive. This will continue for a few times, but then goes away for days/weeks at a time. I’ve taken it to the Ford dealership, but they were not able to find anything wrong. I’m hoping that someone else might have had this type of issue before, so I can give a better explanation to the dealership to get it fixed. The feeling is similar when coming to a stop with a manual transmission and not pushing in the clutch.
If it isn't the IAC, then it could be the tranny. Just wondering if it would be better to take it a dedicated transmission shop instead of the dealer?
Thanks again for the reply. I will give an update once I find out what the issue is.
Mother has a 2005 ford 150 lariat. Engine dies. Auto fail safe light comes on. Has it at ford dealer, $500.00 plus dollars and they still can not find problem. Truck keeps dying on her. They have changed the crank shaft sensor, admission sensor, and both catalytic convertors.
Had diagnose ran on truck computer no codes ever come back, but check engine light does come on, I have changed the fuel filter and air filter.
I read that it can be a cam position sensor, my mechanic and auto parts store suggested I have something in the tank or that I should replace the high-pressure fuel pump. This could bleed my wallet, please help.
2 weeks ago it also stalled in a parking lot. My son said he has to put it into Reverse before Drive, and then it didn't stall. That was twice in one night, then nothing until yesterday. DOes this sound like what yours did? What was the diagnosis?
I had a 2002, F250 4x4 deisel. (The truck was new too) Same problem for months. Stop and stall, stop and stall, Dealer checked 7, yes 7 times and couldn't find the problem. Almost got killed twice. Even placed a Flight Recorder on the computer. When the problem occurred I would activate the recorder. Dealer still couldn't find the problem. (no codes would ever show) Finally pushed the lemon law on them and they refused. Got an attorney. Ford finally gave us ALL of our money back and paid attorney fees.
Ford also denied ever hearing of this problem before, Stalling or lunging, As you can see it seems rather common.
I wish you all the best and be careful. It was a real pain for us to finally get rid of that LEMON
Fox
It hasn't happened lately, but I did go to Ford. They did their "diagnostic" Claim to have checked the torque converter and did whatever it is they do. They found the IAC (idle air) was gummy and the duty cycle was at 58% which is high. I am replacing that today.
Will keep your suggestion in mind if it happen after the IAC is changed.
I can't do much repairs myself, so I bet that $65 part will be a lot to have done......
i have a huge problem on my truck
it is a disel f250 and when i start it up it makes lots of smoke and after that i find fule in my oil pin
any ideas???
Starts and idels fine but when you put it in drive it will not move and the instrument cluster dies.
Looked at the book and found Fuse 19 which is for:
Auxiliry Powertrain Control Module, Instrument Cluster, Overdrive Cancel Switch, Idle validation switch, overhead console, Diesel PCM via Clutch
I've changed the fuse 3 times and everytime it starts up good instrument pannel work but when I put it on drive or reverse the instrument pannel dies and when you give it gas it wont move.
Can anyone advice PLEASE????
I have had the carb rebuilt, full tune-up and it still needs to have the accelerator pumped and takes about 5 minutes to cold start. No starting problems when warmed up.
After shut off there is a strong fuel smell but no detectable leaks.
I have heard that this year had problems with the duel tank models.
Suggestions???
rcat
J
my email is quadgod12@hotmail.com and my name is trevor thanx
