Has happened to plenty of Ody owners.
Good Luck waiting on the solution. Honda has a reputation on their disgusting transmissions since 1995.
Too bad I found out after purchasing one.
Toyota sounds nice right a bout now.
I would definitely not pay $2000+ for Honda's engineering problem. And that's just the torque converter job.
I did read hear that the vehicle adapts over time to your driving style - can't say for sure if that is true or not - but it is plausible that the software adjusts based on whatever the last 'n' miles have been like. I decided to let it go for 1,000 miles, and then see.
After I waited, I do have a sense that it is fixed. I don't notice it anywhere near like I used to. My biggest concern at this point is that I don't have any confidence that it won't happen again. My reason for the concern is that I don't have the impression that it was a manufacturing problem, or wear and tear. I have the impression that it is a fundamental design problem.
I am very likely to get the extended warranty to address future problems since other than this we like the vehicle very much. Frustrating to have to spend more to protect yourself since one of the big Honda benefits for me over the years has been their extremely high reliability. But - cheaper than a new vehicle.
V-6 line. there is almost an identical TSB on the Acure MDX. I can't believe Honda has had the guts to keep building and selling what are truly vehicles with defectively designed transmissions. The should have to buy every one of them back and have to send them to salvage. But of course if the issue goes to class action all they will get is a scolding and the owners will get a warranty extension.
I was going to buy a new one, but mine is running so well I'm afraid of buying a dud.
Good luck to you all! :shades:
Wish me luck.
Will post results later.
http://townhall-talk.edmunds.com/direct/view/.f1085e1/237!keywords=#MSG237
Did the new software update work? Owners need to realize that while the shudder occurs damage is being done to the converter and transmission. Honda should be offering extended warranties.
I got two notices from Honda, one for a PCM update for lock-up clutch function, telling me I had to take my Honda back for improved software reprogramming. NOT GONNA DO IT! Already had the torque converter replaced and it's running like new, it failed only after they reprogrammed it the first time. That was very annoying. The second letter I got was for a SAFETY RECALL of the VCM. Will talk to a tech at honda before deciding if I need to do that one or not. I'm leery of letting them mess with it when it's running and stopping perfectly.
I am having a 07 Odyssey, couple of months back my TC was replaced, but I started having the judder problem, I took the van to the dealer couple of times, but they couldnt figure it out, so finally Honda had 2 other recalls about the soft brake and PCM update, after these are applied, looks ok, but still feel that, while slowing down, I feel little judder before I brake , and also when I am slowing down and pick up speed, I feel that the transmission isnt smooth, but when I take to the dealer, they are not able to identify the problems, I think unless Honda releases some fix for that, or atleast some software update, these dealers cannot fix those issues, hope fully some one in Honda are working on these issues.
Darla
Do you or anyone here have the product update link or a hardcopy for this second PCM update? I am trying to use an arbitration system in Canada to get HONDA to buy back their vehicle.
Here's the link:
http://www.in.honda.com/Rjanisis/pubs/SB/A09-053.PDF
Regarding the dealership experience. -- they were very quick I had the brake recall, The Judder and an oil change all in a little over an hour. On the negative side, I asked them to check the Transfer case and the rear engine mount. They said #1 there are no problems with those and the software update fixes all the problems. #2 he kind of said that many have had trouble with rear motor mount. but assumed I didn't have a problem. I insisted that Honda needs to check both. I had read many places that everyone who has the judder problem ultimately has problems with T/C and rear motor mount. When I called in I mentioned this too both times they down played the internet and said only very few people had that problem and implied no on the internet knows what they are talking about. I still don't know if they check either issues I mentioned and asked if they had only that it is not noted anything is wrong so they did. good luck with the fix.
just my thought, ask the dealer to inspect the front left and right axles, many dealers dont even pay attention of what the problem is, they just say everything is good.
Btw, tires are new, and alignment and balance are current.
coz, for me they found out the problem with axle.
I've been waiting for a real fix for the transmission vibration problem @1400rpm/about 45mph, but I haven't seen one yet.
43,000 miles gone, time for new tires.
This was my third but no more.
This problem is so common according to my mechanic and the pages and pages of internet info reporting the same problem support that. Honda refuses to acknowledge the issue and will not help the customer. I guess I know I can't buy a honda ever again. I do think a class action suit should happen. If you multiply the thousands of Odysseys on the road w/ this issue by the cost of repair that averages around $1000 I'm guessing there are plenty of lawyers out there willing pursue this.
It really makes me angry because I thought Honda was one of the last few auto makers that make quality products and support their customers. What options to I have?
BTW - my brakes have been grinding loudly for 20K miles now. The mechanic says they are fine, but its common problem w/ Odyssey's from 04-08. Eventually I'll need to over haul the breaks and hubs. Power steering is getting worse and worse...also a common problem on this year of Odyssey. Power steering gives out at low speeds. I'll likely need to over haul the power steering as well. All before 100K miles. How can this be? I have a Nissan Maxima with 280K miles and I still have not had these types of problems.
Anyway, when I took it in for service they diagnosed the broken engine mount. Both were repaired under warranty and both have been fine for about 10 months now -- or I should say that I have not noticed the symptoms.
I agree with those noting that they were shocked to experience such a thing from a Honda. I agree. I have owned many Hondas over the last 25 years and this, by far, is the worst mechanical issue I have seen. I was motivated to get the extended warranty as a result. I am equally motivated to look at other manufacturers when it comes time to replace the Ody.
The problem is the torque converter. Unfortunately, you will receive the same defective design when it gets replaced. And Yes it will fail again in another 50-75k miles.
Honda was replacing transmissions under the class action law suit with the same defective design - just rebuilt units. It was a smart strategy on their part because no money was spent on re-design or re-manufacturing.
Some day all of the hidden Honda "goodwill" repairs for major mechanical failures will eventually reach Consumer Reports and the public.
