Cadillac CTS Engine Problems
I have a friend with a 2004 CTS 3.6 Sedan with under 30K on it. The car recently started making a lot of engine knocking and shacking a good bit. At first I thought it was maybe some bad gas, so I added some fuel system treatment along with some fuel stabilizer, that did not seem to work. Then, since it is usually driven in the city, I took it on the highway to clear it out. That seemed to do the trick, but only temporarely. Yesterday my friend started up the car in the morning and the front end and motor just shook horribly, so he shut it down and had it towed to a local Cadillac dealership. When it got to the dealership it would not start. Upon further analysis they determined that there was not any oil in the engine, they said they checked the dipstick and cylinders, nothing. Now, in all fairness, my friend did tell me that there is a possibility he has not changed the oil in the car in about 2 years, but I am not sure if the car just ran out of oil and it burned it up over 2 years or what. So, long story, the engine seized up, the codes that came up were errors concerning the camshaft and such. The only time the engine light came on or any warning for that matter was right when it was started the last time, when it was towed. In short he is looking at a new engine for about $8,000.00. Cadillac stated this is not under warranty because my friend did not maintain the car as he should have. The claim is in dispute with GM right now. Any ideas please post.
thanks,
jfdcustom
thanks,
jfdcustom
I would really like any feedback please.
Thank You
Did you check the oil when you were first asked about this? Was there any? If not, taking it out to "clear it out" at highway speeds probably finished off what was left of the engine.
Many automotive scenarios have an exponential piece to them. The car may have only used a half a quart of oil over 3000 miles, but toward the end of a 30,000 mile situation, when the oil gets really low, the rate of consumption is going to go up in a big way.
Did this
moron, sorry, person have the vehicle serviced at any point in those 30K miles? Were records retained?I think I know the answer to both, but thought it best to ask anyway.
thanks.
Many BMW fans are beyond upset -- they check their oil weekly/monthly. Many of the enthusiasts among them change their own oil.
So. . .we have a car with the feature you're looking for driven by people who generally check their oil regularly vs. a car without it that comes with a perfectly good dipstick.
Everything is not idiotproof. . .yet.
Merry Christmas.
thanks for the reply though
Since your "friends" CTS is a 2004, it has the same sensor, which is extremely reliable. Apparently, your friend did not pay attention when the message came up.
While GM should be held responsible if the engine were defective, owners are responsible for routine maintenance and should accept the consequences for their negligence.
Thanks, Mark (mark@serieshybrid.com).
Did the car display a low oil warning? or was this feature malfunctioning?
Did the car display a warning to change the oil? or was this feature malfunctioning?
I doubt that both features malfunctioned. In any case, the owners manual should have stated that the oil needed changed on an annual basis, which I think is the case. Failure to maintain the car properly is not GM's fault.
By the way, synthetic oil is wonderful stuff, but it burns just as well as dino oil. My CTS burns about a quart in 3000 miles. At that rate I whould have junk in about 15,000 miles assuming it was not changed or topped off. I cannot imagine ignoring the change oil reminder for 2 years. Unbelievable. A good candidate for the 12 month lease.
This past weekend I had gone away with a rental and on Monday when I went to take my car to work the engine was making a strange clicking sound and idling higher than normal. I had to take my more reliable 1993 Ford Explorer to work that morning. I had my mechanic come over and look at it, since I did not want to move it and he is saying the it is in the top of the engine. Now, I drive my car less than 12,000 miles per year, to work 15 minutes away 3 days a week and store it in the winter (it was to go in storage this weekend). I have done all my oil changes on time, get tune ups and have the entire vehicle checked over every few months. I cannot believe that there is an engine problem. Now I have to worry about whether this is even covered under the 8 yr powertrain warranty that is still on the car. Anyone else ever have this problem? You'd think when you pay so much for a vehicle, it would last a little longer than 40,000 miles....needless to say, after it is fixed, it will be gone. Cadillac is no longer on my list of reliable vehicles.
I consuming about 1/2 quart every 3200mi
2004 cts with 84.345 miles.
The first two weeks it was exactly where it should be on the stick from the factory. Never moved.....I checked it several times in my garage in early December it was still very much on the stick in the center. I haven't checked it again until last night (almost 30 days later) and found the stick to be dry. It took almost 2 quarts to bring it back onto the stick in the center of the stick.
I'll attribute that to "breaking in"...but for those of you who choose to wait to check your oil until the change oil light comes on..........I wouldn't do that!!
One characteristic of the 2008 Oil gauge is that it always seems to peg out on 80 PSI when under load....it still did that even being 2 quarts low....kinda misleading. You would think pressure would go down as oil level went down. It didn't. I'd recommend you watch the oil in this new car as it breaks in.
If the worst happens ,the engine expires while under warranty , you will get a new ,latest version of DI 3.6. Don't worry just keep an eye on the oil level and keep GM notified.
Thanks in advance
My 3.5 liter uses 600ml every 6-7000 km a little less in summer normal. Yours sounds a little high ,you might have a small leak....
On the consumption issue, a quart in 5-6000 miles is nothing to worry about on any engine. I know some motors dont use any oil in 5000 miles, but that's not necessarily normal. I'd start wondering at about a quart in 3000 miles, and worrying at 1 qt in 1000 miles. If you boot the gas pedal alot, oil consumption goes up. High engine revs or load creates more heat and increases consumption of gas and oil. Long, high speed highway trips seem to burn more oil than puttering around town for a couple of months. Maybe you're old enough to remember 1968, when GTO meant gas, tires and oil. Because of lessons learned in those days, I have the habit of checking each car I own every week or two.
The oil life monitor on my son's BMW doesnt come on until about every 15,000 miles, so they have pretty good confidence in synthetic oil.
Like was said before by others, a double overhead cam engine does have more moving parts and produces more heat . If synethic oil isn't used carbon build up and varnish will deposit it self on the valve stem and mechanically valve train components reducing the effiency of the engine and leading to engine sludge. Plus these type of engines are engineered to superior and tighter tolerance than previous generations, thus requiring a synethic oil just like the Corvette and others.
Its a love hate relationship with this car, Im so used to Honda's and Toyotas...aye, crap!
Can anybody answer that one?
What do you think
your assumption for synthetic oil change intervals is also good.....all my cars run it and use that range..to include my 09 CTS.....however if you are using oil you will unfortunately have to replace it....
try another dealer as well.....its a documented issue but I dont know if there is a fix....you might want to do more research on other cadillac forums
