Mercedes-Benz C240 4matic
zhartley17
Member Posts: 3
I am looking at purchasing a 2003 C240 4 matic and I was wondering what people who have one thing of it and if they have had an problems with it since owning it, thanks Zach
The car gets consistently 22.4 mpg comblined between highway and city.
1. replaced front/rear engine mounts
2. replaced engine belt
3. power steering flush
4. brake fluid flush
5. coolant flush
6. replaced side seals
7. replaced air mass censor
Does this seem excessive? Because it cost a fortune & I'm wondering if I should consider getting rid of it.
I'd appreciate thoughts on this...........thx.
Everything else is typical car maintenece from what I can tell. The engine belt? Are we talking timing belt (in which case, 76k is early) or an accesory belt, like for your A/C?
This if my 1st Benz. Prior to this car, I had a Ford & never had to do any of this stuff however, I sold it @ 7 yrs. I was planning to keep this car for 100,000 or plus miles.
Just seemed like a lot of items needed attention all at once.
My question is how does the oil cooled piston get the lubrication it needs if there is no way for the oil to get to it?
I,ve posted in other forums to try to get this question answered and am hoping there is some mechanical genius out there that can help me out with this one.
Any and all help would be greatly appreciated.
uteoat :sick:
Let me recommend that you also post in our Technical Questions discussion. You might be more likely to find that mechanical genius there, but we'll see if one shows up here as well.
Good luck - hope we can help!
When car is cold (I live in the Northeast), there is loud brake scrunching noise when I step on the brake.
Also, is it normal for the sterring wheel to be tight at slow speeds? It requires "extra effort" to turn. I also have a Toyota and steering wheel is never that tight as my Benz.
Thx in advance. Ed
As far as the steering goes, it would make sense that if the fluid is really cold, it may take a little extra steering effort until the fluid warms up. I would think it would have to be real cold though. Here in seattle, it doesn't get that cold, so I haven't really experienced the problem you have. Hope this helps a little. I'm sure some other MB folks will chime in.
I have a 2001 c240 with the same problems the car has 130000 km and so far spend over $ 5500 and not finish yet i have to change the steering rack which cost another $ 2383 two outer tie rod ends and so on, I agree with you on the BIG MISTAKE part, NEVER MB AGAIN FOR ALL THE PEOPLE TO KNOW
2002 Mercedes C240
gracias!
I am considering buying a 2004 MB C240 4Matic with 43,000 miles on it.
What, if any, negative experiences have people had with this model?
What is the most frequent repair issue that has come up with this car?
All responses appreciated!
Why don't we just talk here on the boards?
New here...figured it would be an intelligent place...
Wife looking to buy a used (2004) AWD Sedan. Each has about 68,000 miles on it.
Prices are apparent differences, will deal with that later.
Looking at:
Mercedes c-240
AUDI A4 1.8 Quattro
Infinity G35x
BMW 325xi
Not looking for a 'race car'. Standard wife car; comfortable; good in snow. She likes these styles, so the Subarus are not a consideration.
Looking for opinions on each.
Maybe a quick summary that you may have on each.
Seeing that it is an Mercedes forum - please feel free to let me know why I should get her the Mercedes rather than the others.
I look forward to all your help.
Please be as lively and opinionated as you'd like to be !
Thank you !!!
Tooky
(Will post in the other forums also)
Very happy with it !
Sorry I wasn't much help to you...
.....but continue to have a great weekend !!!
The transmission fluid is cooled by the radiator. This past Monday (10/18/10) the transmission burnt out. The Mecedez dealer stated I need a new radiator, transmission and gear box, ($7,100.00). I'm looking to see if there has been any class action lawsuits filed for this design error.
I've been on line and have discovered the standard radiator "Valeo" will break down and allow glycol to mix with the transmission fluid.
I believe Mercedez should be liable for the correct repair for this car.
Mike
Now 30,000 miles later at 78,000 miles I had a glycol test performed and I had "LOTS" of glycol in my transmission. Unfortunately now my car is out of warranty!!
MB dealership finally changed the radiator, torque converter and flushed the system..and the service advisor said "I would fix it and sell it"!!
I was hoping to drive this car for another 10 years..it is in excellent shape!! However there is no guarantee that other parts of my tranny will give out!
I've seen many posts concerning this issue and to my knowledge no class action suit has been pursued! If anyone has any information to the contrary, please let me know. I feel a class action suit should be filed because us consumers are getting a very raw deal!!
How can you know the used cars have been reduced odometer? :confuse:
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
