I haven't gotten around to checkin the CEL with Fred's VAG, but I'll let you know how that turns out. Keep me posted on getting your thermo replaced...good luck to your hubby! David
Anyway, just be sure to not mix green and G12. Make sure you know for certain what is in there before adding anything other than water. If you are not the original owner you never know if a previous owner may have (unwisely) had the G12 flushed out and replaced with green.
Apparently there is now also G12+ that is purple.
I think the orange coolant is similar to G12 and some think it is okay to mix with G12. If it were me, I'd not take chances and would just stick with the official VW product, G12 even if it may cost a few extra bucks.
What else could be wrong? Could the 'day time running light' controller make the left low beam not work?
Anybody have this problem and fix it?
Any ideas?
- Jay
When i hook the battery cable up the alarm goes off for a while and the steering wheel wont unlock for nothing. I have jerked on the steering wheel pretty hard while trying to turn the key over...its stuck.
Is this an alarm issue? the guy i bought it from said he just parked it last year and hasnt ever had it do that to him.
i am thinking i may have received the wrong key??
I wouldn't think it is an alarm issue. I don't think that would result in the steering wheel not unlocking, I could be wrong, though.
if you have little expe....you can replace it your self and that will solve your
isue.one more thing..microswich is part of the door lock and you can only but
it as one unit.good luck.
I pass charge from other battery to mine because it was dead, at the moment when I turn on the car all the indicators in the dashboard turn on, at the time when I drove this indicators turn off but the brake and the ABS indicators still flashing and noising on an intermittent way. I sent my car to a VW service, the car was tested with the scanner and no problem code appears on the test result, the people in the agency told me that the computer are ok but they can´t give me a an answer to fix the issue.
Somebody can help me to have a guide to fix this issue?
Thanks in advance
A couple of weeks ago, maybe a month, my cars alarm system and automatic locks from certain key positions stopped working and my red indicator light does not show anything (normally it would blink red when activated), so i have been locking all my doors manually inside when out. Two nights ago i was going out to families and my passenger side door would not open so they climbed over from the drivers side. We just figured it was the cold and the lock was frozen when i hadn't been locking it at all and the door was not locked.
Last night was when my car was covered from the above story, when we went to get into my car i opened my drivers side door (which hadn't been locked) and the car alarm which hasn't been activated from about a month started going off when ever we opened my door or the hood and the luggage compartment would not open at all. We popped the hood which also activates the alarm. My alarm apparently voids my ignition so just to get my car started i needed to hot wire my car by bypassing the ignition system.
Now today, i went to try and fix the problem, and first thing was that i checked was if my drivers side door would open, it did, then i opened my door to pop the hood which should have set it off (the alarm shuts off after 4mins.) it didn't, so under the hood i taped up what i striped to hot wire it, then i opened my door a couple of times while slamming it and then it finally set off the alarm, since my side hadn't been working to lock the doors i went to the passengers side door to unlock all and it had shut the alarm off.
My question is first: Has anyone had a problem remotely close to this? Second: And if so, what did you do to fix it. And third: Was this possibly just a short out of my alarm system getting wet?
Does anyone have any ideas about what the real problem is. It has to be electrical?? It was suggested during the last repair that the climate control module may have to be replaced.....
HELP!
