Jeep Grand Cherokee PCM Module Replacement
I have a 2001 Jeep Grand Cherokee and the dealership told me I need a new PCM Module (Power train Control Module) at a cost of ~$850 plus tax and labor. I found the part on the internet for $336 but is this something I can replace myself? The service manager said this is basically a computer module. If I can replace a power supply on a PC it seems I could replace a PCM. Any advice? Thanks.
Ryan
located on pas side under hood on the fire wall behind coolent tank don't look to hard to change
I really appreciate any advice on this. Please click on my username and respond to my email. Thanks!
If we all went to email that would defeat the purpose of a Forum and deprive everyone else of valuable information!
SUVs and Smart Shopper
located on the pass side under hood in the fuse block under the cover cover should show which relay it is
Please help me?
Any help here is great!
thanks in advance!
Jeff
to check remove number 1ne spark plug put your finger on the spark plug hole and have some one turn over engine when you start to feel pressure on your finger stop turning over engine and then move it with fan belt to get to top dead center
remove dis cap and see if roter is pointing to where number 1ne plug wire is if so
try this stuff and get back to me
were you getting any spark at plug (should be a good blue white color)
Jeff
Jeff
I am reluctant to take my jeep into the dealer but have had no other choice. The jeep has a new battery for starters and cranks over, just does not start. The fuel gauge is not reading with the key in the on position. The dealer says they need 2-3 hours just to figure out what might be wrong. They are indicating maybe the PCM, TCM or the cluster.. they don't know. Currently he indicates he can't communicate with them. I have looked through a lot of information and it appears maybe the PCM is the problem. Two Questions
Given the symptons does any one have any advice?
Does any one know where to get a PCM other than the dealership that is legitimate and a decent price.
Any help would be great thanks.
Chris
The pcm is gone on this 2000 GTC 4.0l and the dealer indicates a skim module is also required (sentry module key). Is this true or can you just replace the PCM after it has been programmed for the vehicle? No one seems to want to give this information out they just want the 1000.00 for the pieces. Any help is appreciated.
Chris
The danged OEM (and aftermarket...) alarm systems have been known to go out & prevent starting.
There's also the ever popular ignition switch (not the key unit - the electrical switch itself), there's an interlock / latch relay, the fuel pump (has ya got's pressure???), the Neutral safety switch (NSS)...
Hmmm - NSS... Have you tried starting it while cycling thru the gears w/ your foot on the brake??? Just turn the key to start w/ one hand & use the other hand to go from Park to 1-2 & back up. (Keep yer foot on the brake!) The NSS, which is down below where the water from that boat launch was, could be full of water & gummed up. Fairly easy to remove & rebuild. (Article & 'how to' linkages on my website.) Crown Automotive online sells them for about $110, Don't even ask what the dealer charges...
Where is your website link? just in case I find the NSS to be the problem
I tell you I did the exact same thing after the PCM did not correct the issue (as directed by my dealership which cost me 300.00 bucks to diagnose) and the sensor fixed everything. For all those folks out there that have a similiar problem, change the sensor first - its cheaper and likely the cause.
Melissa
The crank position sensor solved all the problems and I didn't need a computer, the dealer was wrong. www.autotrans.com is where you can get reasonably priced parts.
i have 2001 jeep gran cheer and was having problems starting i did key trick and got code for crankshaft position sensor replaced and truck started.
after replacing and starting,truck started running ruff and stalling.did key again and got codes p0351,p0352,p0353.ignition coil.
changed ignition coil pack and code p0351 went away and p0352,p0353 are still there truck is idling ruff and still stalling code says dwell time not sure what to do if anyone with same problem or anyone who knows what to do please help trying to avoid dealer and costly unnessary inflated pricing for repair work.
please help!!!!
Jeff
if not see if getting spark out of coil (can test coil by omes meter )
do you have batt voltage to the neg side of coil (need to check when turnning engine over votl will go on and off as dis turns )
I have replaced all kinds of parts and have spark at coil but not at spark plugs.
(pull number one plug turn engine over with your finger covering plug hole when you feel pressure stop turning engine with starter and then move crank with socket till timing marks lign up look at roter and see if pointing to number one plug wire (bet it aint) could have two things wrong 1 timing chain worn out jumpted time there 2 dis drive gear pin seared
hope this helps
I have replaced pcm, crank position sensor, cap rotor and wire to no avail.
Coil wire will spark across 1/4" gaps easily.
Cam position sensor shows good.
Wonder if rebuilt PCM is bad?
Thanks,Jeff
Any ideas on a recource that I could take to the dealer about getting my 600.00 back from a poor job that they did?
Thanks again
Jeff!
