I am trying to change the water pump on my truck. does anyone have any tips on how to get the hose off of the back of the pump under the air conditioning unit, it seems like it is just about melted on to the back of the water pump?? Where does this hose go to and how far back does it go? if i had to change this hose how would i go about it? I have got all other hoses, bolts and fan off this is the only thing holding me up any help would be appreciated. oh and i have a haynes book that i have read cover to cover with no help about this hose. :sick: i have read all over the net and this hose is called the by pass hose but no one seems to have any tips on how to get the darn thing off ! !
If I keep the speed under 70, or slow to around 60 if it gets hot, it will immediately come down. Also if I exit the freeway it immediately drops temp. It never gets hot in traffic or idling. Also, turning on the heater does bring the temperature down.
I even tested by getting it hot, exiting the freeway on a side highway, dropped to 2nd and drove about a mile, mile and a half at 3000 to 3500 rpms. The temperature dropped to normal during that time.
The water pump was replaced (failed) in Feb 09. The thermostat was replaced in May 09. The dealer can't find anything definitive, but thinks the radiator is clogged, should be replaced or at least flushed.
It puzzles me, as I would think if it was the radiator, it would overheat at lower speeds. I don't want to spend several hundred on a radiator and have it not be the problem.
kcram - Pickups/Wagons Host
Sam
Its looking like the fan may be on backwards, for I did buy the truck used... thinking maybe someone did some repairs and installed fan backwards, but not sure...
Any idea's on what could be the problem is appreciated...
My Dodge Durango Hemi 2005, had been in the shop at the same time with a problem lunging and sputtering. After 6 trips to the dealer and over $1,600, I still had the same problem. Took it to a transmission place, had the transmission oil changed and no longer have the problem.
I would suggest to everyone to not take their cars to the Dodge dealerships, apparently they have no clue how to work on their own vehicles. Or maybe it is so you will have to buy a new one every 60,000-80,000 miles.
Would love feedback as this is getting extremely frustrating to troubleshoot.
I have a 95 Dodge Ram 5.9 L just like you but mine is a 4x4. I have the same type of leak but so far no issues with power. I found it when pressure testing the coolant system. I see a small stream of water making its way out the thermostat housing platform/engine block. Put in new thermostat and housing, gasket, sealant on both sides of the gasket, 17 lbs/sq.in. on bolts. Still leaks under pressure. How did you resolve your leak? it has been a while (2007) since your post but it is the only diagnostic question I could find just like mine. I was thinking of trying K-seal? Any help would be great. Thanks, Vin
why?
