Mazda MX-5 Miata Transmission Problems
I just bought a new 06 Miata Mx-5 one week ago. I love the way it handles and its' head-turning looks. There is one thing that REALLY bothers me though. When I am in 6th gear driving at about 60 mph it feels like I need to shift into 7th gear(which of course doesn't exist!) At 60 mph it's doing 3000 rpm on the tach. Is this normal? It is aproblem with the transmission? engine? I would really appreciate an answer either way.
I believe the automatic transmission spins at a lower RPM at the same speed, so don't be concerned if you happen to compare against an automatic transmission.
Since this is the MX-5 discussion, you probably won't get much feedback on your Saturn. You might want to stop by the Saturn S-Series Group to see if the folks there can answer your questions. Hope you get this solved soon :-)
Thanks for your suggestions
If that is traction control, no, I don't have that. Any suggestions?
Best winter tire is Nokia Hakkapeliita but it cost $$$. Michelin makes good tires for a little less.
I'm looking for a junk block and tranny case to mockup and see if this will work. I'm in Phila / NJ area and will pick up, not ship, the parts.
Anybody have experience with the swap???
Thanks for your time and interest. Victor
Also, how much damage do you think I did and how much do you think the car had when I got it? (I ask this because if I'm the one damaging it, I may just get a new car, because I don’t want to just turn around and replace it in another 5k.) Thanks for your help.
Speedy
Speedy
I'd avoid that one.
The '96 has a bigger, 1.8l engine with more torque, and should be a better match for the automatic.
Disclaimer: yours may be different, the engine changed in 94.
My 93 can't do it at all. Do you have a turbo or supercharger?
Sounds to me like you probably have much more than stock levels of power and you're letting the clutch absorb a lot of abuse.
Avoid hard starts and try to match revs when you downshift, I suppose.
Does it slip when you baby it, i.e. under normal (slow) starts?
I have a 99 5 spd miata and we got it used with about 40,000 gentle miles on it and no significant parts replaced
lately when I try to get up to a relatively higher speed (45ish), the rpms spin up to 5000 and stay there. the car will still hold the speed and I can accelerate but it feels like the car is working wayyyy to hard to do so, like it's super underpowered or something.
is this a sign of a slipped clutch? i havent done the parking break- 4th gear stall test yet but I thought I'd ask you guys and see if anybody had any input
thanks!
