The problem is that the Transmission Control Module (TCM) is not sending a signal to the transmission to make that final shift.Well the BIGGER problem is that Mazda no longer makes a TCM for this model,and I can't find any Electric shops in my area that can rebuild it.
If anyone can tell me where I can get my hands on a TCM for a 97' miata I sure would appreciate it. :sick:
When I had my 93 I'd visit the junk yard in CT near my in-laws' place once a year. I'd always find something I could use - a clip here, a latch there. Small stuff like that.
My question is this: Is there a way to modify the automatic in the 08 Miata to have firmer/ stronger shifts? I understand that the trans is computer controlled, so maybe there is a module or chip that can improve shift quality? Perhaps a different fluid type?
Last question: Who makes the Miata automatic tranny? Is a Mazda unit, or one of the other Japanese sub-contractors? (Asian-Warner, Jatco, etc....)
By the way, this is my first Miata and I LOVE IT!! My last Mazda was an RX3 Rotory sedan, and before that, I had a Mazda Cosmo Coupe (also a Rotory).
Thanks!! ARG
When the car is started cold and placed into drive or reverse there is a rattling noise . the noise is not present when the vehicle is in neutral / park. Once the vehicle is warmed up, the noise is not noticeable.
Perusing various other forums I have read this may be due to a problem with needle bearing in the torque converter. Has anyone here experienced this ?
Jim Adams
Without examining this firsthand I cannot say that the problem isn't coming from inside the torque convertor, but that IMO is one of the least likely sources that I would expect to find. Besides, if the needle bearing supporting the stator inside the torque convertor is failing you would have other symptoms that you would be describing on top of the noise. With a rattle cold in gear something like an exhaust shield would be a far more common source. The bottom line here is someone needs to get this in a bay and making the noise to find its source. Anything less than that is a guess.
