Nissan Pathfinder Fuel Problem
I have an 1988 nissan pathfinder. It's ran we'll for quite sometime till last week when i was driving and it felt a little hesitation. I didn't think much og it till it started getting worse and worse till now i step on the gas and it stalls. It will shut off, i have to keep stepping on the gas to stay on.
Does anyone know what it would be. I need to get it running asap.
Did you find water in the fuel tank when you drained it?
I've been to gas stations that take 15 minutes to fill, and I've been to others that take 3 minutes. Some shut off at the slightest back pressure from the filler neck, others don't care one way or the other.
When you fill up, put the nozzle all the way into the filler neck, then pull it out a bit to allow for an air gap between the nozzle's rubber seal and the opening of the filler neck. That should help. If not, find another gas station with faster, less sensitive pumps.
They won;t pull code on a truck as old as mine around here, so I'm not sure if thats what it is, although I'm ALMOST sure. My brakes went out today and I'm not sure why, which is why I'm here, and that has to be fixed first.
P.S: This is the first and last Nissan I buy by the way.
Anybody knows the answer. Please the car is due for emissions test and I am sure it will fail. Iam sure the dealer will charge me an arm and a leg to have repaired..
How was it Fixed?
I went to dealer and baught the Maxima 01 MAF sensor because it is a lot cheaper and fits Pathfinder 100% because it is basically the same engine.
The AWESOME power of my Pathy returned and i am happy.
Please remove your MAF and see if engine runs any different.
this recall is not including the 2005 Pathfinder, even though the part numbers for the 2005 and 2006 are identical.
All of you with a 2005 Nissan Pathfinder that your feul gauge does not work need to complain to Nissan Usa 1800 647 7261.
You need to tell them to give you a case number.
You also need to contact The http://www.nhtsa.dot.gov/ and file a complaint.
If enough of us complain, we will get results.
Wife has 2005 Pathfinder - getting no help from Nissan - we'll just keep calling and wearing out their phone lines
My yearly inspection is coming up and I can't wait for a recall to get it fixed so I am going to try to replace the fuel sensor myself. I bought a replacement part from CourtesyParts.com for $100 including shipping.
The Recall # is WBI/10-026
This after many many complaints.
Possibly something will come along to Pathfinder owners
Question:
My '05 xterra has 4.0 L, 9.7:1 ratio, 260 HP, 281 lb-ft torque.
The Pathfinder has 4.0 L, 9.7:1 ratio, 266 HP, 288 lb-ft torque
Any one know why the Xterra is regular and the Pathfinder is premium?
Please what do I do? can somebody help, mechanics have eaten my money so much.
