Chevy Silverado and GMC Sierra Exterior and Body
How long do you think shine will last before the front of $40,000 look like crap? Not only is it cheap it looks cheap too. I only wish you could option out of that style of bumper when ordering.
I have plenty of air rushing into the box and lifts my soft tonneau cover up while driving at highway speeds about 2" to 3" over the rail. and every time theres wet roads I get lots of road spray in the box.
Great for my tools !!!
I installed EGR bed rail caps to cover my stake holes. There are open areas in the left and right top front area of my bed, sealed using DapTex latex-based Insulating Foam Sealant that remains soft and flexible. I have a TrailFX bed mat on the floor. These minimize water blow-by in most of my vulnerable areas. I also added a TruxSeal tailgate seal in the back (mostly to minimize dust draw in the back).
Both sides and bottom-front of my bed are not air tight. There are drain holes thru my front floor and body gaps behind both side walls. With my solid bed cover, air pressure is not a problem, although I can understand it's effect on your soft cover. This is one reason I selected a light weight hard cover that can easily be removed. Remember our truck beds are not designed to be air-water tight.
Where are you noticing the most "water spray" in your soft-covered truck bed, front, back, sides?
The problem with my tailgate (2000 Siverado 4.8L 3rd Door ) is is there is a little plastic piece that keeps breaking. The dealership want $150 to fix the problem. I am just try to find a detailed diagram of the tailgate so I could fix this myself.
Larry
Disgusting !!!
I have had it in for service several times and they cannot find anything. Does anyone know what causes this noise and is it destructive???
Did a little searching and was the cheapest price I found was 440 US. Anyone know a place that might be cheaper?
:sick:
Monroe Ceramics brake pads feature a true ceramic formulation that promotes cooler, cleaner and quieter stops.
Cooler Stops
- Up to 350° cooler than other brake materials
- Minimal rotor wear
- Longer pad life
- Consistent, comfortable and smooth braking power
Cleaner Stops
- Formulated without ferrous metals*
Quieter Stops
- Precise control of vehicle NVH (noise/vibration/harshness)
*Limited high heat and severe use applications contain some metallic fibers.
*********** REBATE!!! ********
NOW THROUGH MAY 31ST
- BUY 1 SET OF CERAMIC SERIES PADS AND GET $15 BACK!
- BUY 2 SETS OF EITHER CERAMIC SERIES OR DYNAMIC SERIES BRAKE PADS AND GET $30 at www.specialtyautosource.com
Anyhoo either try your local big box parts store and look in the "HELP" section
(aka Motormite or Dorman) as they have a bunch of china knockoff replacement parts. Bring in your broken clip and look for a replacement assortment pack of
clips.
I know the dealer won't have the clip and a new replacement handle with clips is about $80. The HELP knockoff replacement with new clips is $30.
Heres a company that sells them tho:
http://www.clipsandfasteners.com/GM_Tailgate_Rod_Clip_3_16_Rod_Size_p/a18926.htm-
Looks like this?:
I talked to the dealer but they have never heard of this problem. I was wondering if there was a short circuit problem. As anyone out there experienced anything similar??
but it seems that the other end is broken. Not the clips at the handle they are in good shape and are working. So how do I get the tailgate open so I can repair it. I have
a spray on bed liner.
Mark
