Suburban Fuel Filter
furrowjocky
Member Posts: 14
Do 06 burbs have a external fuel filter, as in the past, or is it now in the tank.
Did you ever figure out what that gizmo is?
I am having this same issue with my 2001 suburban and just like Cbroy I gave it a tune up and it started right up but I noticed that when the engine is hot it starts up immediatly unfortunatly after 10min of sitting it starts up slow again. I changed the fuel filter air filter oil filter spark plugs and nothing! any help
I have a '99 burb (5.7L with 71K miles) and replaced the in-tank fuel pump and filter about 5 months and a 1,000 miles ago as I was told a noisie fuel pump is a sign of a bad bearing, plugged filter, or both . New fuel pump makes more noise now than the one I replaced at 70K. Are these fuel pumps normally loud ?? Truck runs fine, but other burbs don'y make the noise mine does. Any clues?? Thanks in advance
JMDB92
