Subaru Tribeca - Direct Connection for iPod, Satellite, Rear Camera
I would like to hook up my iPod, Sirius Satellite Radio and Rear View Camera directly to the factory stereo navigation unit through a line-in/video-in/aux-in connection and not through an FM modulator or FM Transmitter or after market screens etc...
I have a 2006 Tribeca 5 Pas Lmt. w/Nav. I do not have the audio-in port in the rear of the vehicle like the 7 Pas. Anyone know if it's tucked away in the 5 Pas?
There is mention here of an iPod cable with RCA Video and Audio Plugs. Is there a direct connection to the stereo in the car? Is it in the back of the radio or nav screen? Anybody know how to pull apart the dash correctly to access the radio and nav screen?
What does the AUX IN button control on the factory radio?
I have also seen some posts here about using a Kenwood KVA-S300 to hook up a rear view camera to the Nav. The KVA-S300 offers 2 more Audio/Video RCA inputs. Could I use these to hook up an iPod? If so I believe I will be able to view iPod Video on the Nav Screen. Nice!
If I get enough information and help I am willing to undertake this elaborate installation of a rear view camera, iPod and also a Sirius Satelite Radio. I will take pictures and detail instructions and post here and also on my personal website so everything can be found in 1 place. Looking forward to hearing from everyone.
have turn wheel mounted by Circuit city by the arm rest and the display is on the inside window
It is unfortnate that it is not direct
but HC unit is the most steamlined after market
I was also given the Starmate from Sirius as gift and had them install by drivers front corner and like i-pod I just have to find a station.
It would be nice to have all integarated
however i beleive in the end it was much cheaper they way that i did it
I also have a Legacy GT wagon that I installed a Audio-In circuit board made by www.jazzyengineering.com and it works great. I'm on a mission to find some way to do the same with the Tribeca.
Thanks for your reply!
kmartin, "Subaru B9 Audio/Entertainment & ipod Questions" #18, 5 Feb 2007 10:43 pm
and
kmartin, "Subaru B9 Audio/Entertainment & ipod Questions" #21, 6 Feb 2007 10:55 pm
(Seems to be two iPod forums here, the other in the Maintenance & Repair section.)
-Karen in AZ-- happy iPod and '06 Tribeca owner :-)
Do you use CarSpace? They have a How-to section now.
I create a video for now to swap wiper blades (U-hook style):
http://www.carspace.com/ateixeira
-juice
-juice
-Karen-
goto allsubaru.com and select 2007 b9 tribeca and then do a search on camera ....
-juice
When it gets warmer,i'll take the lcd out and try it with a camcorder and see if i can get an image. Don't really want to spend $200 for nothing...
You seem to be very knowledgeable about Subies, so here's a question I hope you can help with.
I just bought a 07 Tribeca which came loaded with XM satellite radio. I want to switch to SIRIUS, but both SIRIUS and the dealer seem to be scratching their heads. Is it possible?
PS - I, too, have a 98 Forester and a Miata (though mine's a 97).
Thanks -
Lynn in LA
But...I've heard the two may merge. I have no idea what that means for the hardware, as I'm not sure if they are compatible.
I do find it *very* strange that Subaru puts XM on the US built models and Sirius on the Japan-built models. :confuse:
Although they have merged (similar to Dish and Direct TV) the hardware and essentially everything else remains split. So you still have 2 competitiors but the money goes to the same place!
-mike
Just to be sure I understand (because I am not very good with electronic talk), do you mean I'll have to buy a Sirius radio unit, mount it somewhere on/near the dash and then run an antenna/receiver?
I have that set-up in my Forester, where the Sirius comes in through the car radio, but a separate Sirius radio unit is mounted behind my automatic gear shift and the antenna/receiver is located on my roof (wires hidden, of course).
Appreciate your patience....
-mike
Oh well! Thanks for clarifying.
Lynn in LA
