Just because there are no gases in the coolant does not mean the head gaskets are not having a problem. If there is white smoke coming out your exhaust, either the head gaskets or the block have a problem. But, the antifreeze will foul the oxygen sensors quickly (if there is any present), so your check engine light will illuminate before too long. If the car is not experiencing overheating, you do have some time to figure this one out.
What was the temp when you started it?
Perhaps it was condensation that accumulated in the muffler burning off if it sat for a while and it wasn't too hot.
My guess is there may be nothing wrong with your car at all.
-mike
Check the cost of a re-man, 194k miles is a long life already.
-mike
Several months later and about 1K miles, all seems to be ok. Big trip coming up in a few weeks, and we'll know for sure then (I have my doubts). Thought I would pass along the info since so many of us are dealing with this - repairing the HG may not solve the problem if instead the problem is the cylinder. I'll update after the trip.
I left the ignition on and killed the battery .She'll cranks over now but will not run .
The car ran fine up until this happened . The coil has continuity on both sides Primary and secondary. The ignitor did not send a pulse when I cranked over the engine . The fuel pump is working . What is the problem ?.Did I burn out the ignitor ?
Can anyone shed some light on this problem? I checked the price on an ignitor
they run over 100.00 but is there something else I should check.
It seems to run rough from time to time as well as some VERY rough starts. I've hit 50k miles, but problem started around 40k.
Brought to dealer since I've owned her and they haven't fixed the problem the last 3 times.
Any ideas?
See if that makes any difference.
No check-engine light?
Overheated again a week later, not sure what happen but the top and bottom hoses were sucked in. Thought I lost pressure from a faulty radiator cap, so I replaced it.
Worked good for a few days, but overheated again, so I replaced the thermostat, still overheats.
Now my temp gauge ocilates from normal temp to high.
Has anyone had this problem?
I have had dealer say anything from blown head gasket to cloged rediator.
jtcom
Does it always overheat when driving it?
I would suspect a few things but it depends on what was done during the change.
-mike
Guessing here, but it could be unburned fuel getting by, so look towards things like spark plugs, plug wires, or the ignition coil.
Mechnovice
How long after the timing belt replacement did the failure occur? If something was not tightened down properly, I would expect the problem to manifest within 2,500-10,000 miles.
-mike
Now it doesn't start or just barely and dies. Dome light will not go off. Only gets dimmer or brighter with the door open or closed.
Searched for a burnt smelling module under the dash but unable to pinpoint any that were bad. I realize some my be well concealed.
Sound like a poor earth. Check the connections to the battery, remove leads, wash with carb soda mixed in warm water (pour over battery terminals) and refix, tighening securing bolts firmly. After re-fixing, flex the leads with lights on in darkened area to check if leads are faulty
Cheers
Graham
-mike
Since about a week after buying it, I have had problems with accelerating. When I hit the throttle it will jerk forward. Also, when I am cruising down the road it will pulse back on the throttle.When I leave my foot off the throttle, there is no problem. Lastly , when starting the vehicle the rpms will go balistic, fluctuating between 3000 and no idle, its actually stalled upon warmup.I have brought this car into my local dealership for repairs 3 times. They have updated the computer. Adjusted the throttle sensor to its max. The last time I brought it in, they replaced the throttle sensor, thinking that that was the fix for my problem. Everytime after coming back from repairs withing 1-5 days the vehicle has gone back to its regular problems getting worse as the days go by.
I have spent $350 dollars for no satisfaction.
Any suggestions??
-mike
I would also like to add that this problem is sporatic. I also have reaccurring low idles and when I have low idle, the problem seems more likely to occur. The check engine logs that the dealer read indicated that the Throttle sensor is out of range, but that obviously wasn't the problem since the sensor got replaced and I am still having the same issue.
ANY SUGGESTIONS ARE WELCOME
-mike
Get a For Sale sign...
Not bad, really. I replaced my head gaskets at 192.5K.
-mike
-mike
thanks, johnnie
Dealers around me charge about what one costs to own, then you can use it as many times as you need.
I bought one, used it twice for our fleet, but also used it to help out a couple of friends. They were very greatful.
It has paid for itself 4 times over. I got a $99 Actron model. Worked on our Subarus, Mazdas, and even a Chevy Suburban a friend owns.
OBDII. can ya getem' at NAPPA or do you have to go to the dealer? maybe I should just bite the bullet and bring it to my mechanic. hmmmmmmm
I usually find that ineptitude is simply a lack of due effort.
The port is located within 3ft of the steering wheel.
-mike
Motorsports and Modifications Host
They are very, very easy to use. You plug it in a port under the steering wheel. Once some one points it out to you it's cake. Plug it in, hit a button. That's it. Hit another button if you want to reset the code.
Actually, having computer experience is more useful than being a mechanic in this case. The port resembles an old printer parallel cable, the bulky side.
