VW Passat STOP Motor Indicator
extra80
Member Posts: 4
in Volkswagen
I have 2003 Passast V6 4 Motion Wagon with 29,000 Miles on it. Recently the Stop Motor Light Came on. I have not driven the Car since. I have done oil changes on the recommended 5K intervals Has anyone else had a similar experience with the 2.8 L Motor?
After doing research on google, it appears that this issue is common with 1.8 Liter, and VW has extended the warranty for it. Has anyone heard of this issue for 2.8 L Motor? Also it appears that VW is not very responsive. Google Volkswagen Passat Engine Sludge and related keywords, and there appear to be alot of issues out there in terms of VW supporting their product.
The VW sludging issue is far more complicated than that. By every account that I've heard about or read about, if the owner of a car with a failed engine can prove that they'd had their oil changed every 5,000 miles AND used an oil that was VW 502.00 Certified (or better still, VW 503.01 certified), VW will replace the engine, no questions asked. That said, it seems that lots of folks like to ignore the service schedule and then complain that VW won't buy them a new engine when it fails. "Hey, I drove and maintained my 1973 Chevy Malibu that way for years and that engine never quit. Blah, blah, blah..."
One guy here in the TownHall was posting all over the place a couple of months back, screaming about this very issue. When asked if he had adhered to the maintenance schedule he admitted that he hadn't. He also admitted that he'd gone as long as 19,000 miles on a single oil change and most of the rest were between 8,000 and 11,000 miles. Even still he felt that VW should buy him a new engine, so much so that he was wanting to start a class action law suit over the issue. Pretty funny.
Best Regards,
Shipo
http://www.consumeraffairs.com/automotive/vw_sludge.html
http://www.democraticunderground.com/discuss/duboard.php?az=view_all&address=364- x202530
Do you know if self oil changes constitute a proper oil change by VW Standards for warranty replacement. Also are you aware of any document which specifies the requirement in detail?
Are electronic copies of the oil changes OK, or are originals required?
2) DIY oil changes by law are supposed to be acceptable, however, once again; it is typically a nose bleed, one which the manufacturer will usually win.
3) Electronic copies should be enough proof of proper service.
4) The specific requirements for oil service for all VW and Audi cars are available in the Owner's Manual, from the dealership and many places on the web. The following is a chart of VWoA approved oils, from the horse's mouth as it were:
http://www.vw.com/vwcom/content/objects/pdf/service_maint/oilchart.pdf
Keep in mind, for turbocharged engines especially, the above chart is the MINIMUM acceptable specification. Oils certified to meet the far more stringent VW 503.01 specification (by definition a super-set of 502.00) would be the only oils I would use in any VW or Audi. In fact, I am so impressed with 503.01 compliant oils, I've used them in every car and van we've owned since the spec first came out. Errr, well that's a little disingenuous, 503.01 oils also meet the BMW LL-01 spec which is why I originally started using them. FWIW, the only two oils that I know for sure that meet this later specification AND are readily available here in North America are the German made (i.e. says "Made in Germany" on the label) Castrol Syntec 0W-30 and Mobil 1 0W-40. Accept no substitutes. ;-)
Best Regards,
Shipo
http://www.signonsandiego.com/uniontrib/20050514/news_lz1d14sludge1.html
Anyways I have two backup cars, so I can take my time to properly research this before approaching VW.
Best Regards,
Shipo
I'll keep you updated. Good to hear the V6 may not be experiencing the same issues.
