2007 R320 Explodes during blizzard
ncrews
Member Posts: 6
Fully loaded, 2 month old R320 explodes suddenly in our driveway during a Colorado blizzard.
See the complete story and pictures at http://www.landxml.org/R320.
It exploded due to excessive heat from friction.
There are certainly a significant portion of the story that attempts to mislead the reader to a false conclusion.
The tire came apart due to excessive centrifugal force. This was likely caused by the engine being floored in an attempt to get the car out. Remember if one tire is not moving, the other tire on the axle would be traveling at TWICE the speed indicated on the speedometer. It would be easy to exceed 200 mph tire speed!
Word to the wise!
Be careful when trying to extract a car from a snow drift. Excessive wheel speed can cause a tire to come apart. DO NOT stand behind a spinning tire!!
"2007 R320 Explodes during blizzard"
That headline, if you can call it that, further demonstrates the lack of intelligence.
Ha, it was good for a laugh at the least.
-Ryan
An inexperienced driver can easily spin a tire too fast and cause overheating, but blowing up a tire is extremely uncommon.
btw...an R class lease is one of the best deals going.
BTW. The attic of the house needs some more insulation to brave the cold winters. FYI
Pictures and complete forensic expert report: http://www.landxml.org/R320
Summary:
The car was purchased new from Mercedes of Colorado Springs, Colorado.
A defective Mercedes "4Matic" system caused the rear tire to explode causing $25,000 in car damage and $1500 damage to home. Mercedes and the dealer will not stand by the car and only tell us that it is an insurance issue. Automotive warranty items, including factory defects are not covered by insurance - only the resulting damage is.
To date, the dealer and Mercedes refuse to simply "undo the deal" giving us our money back and paying actual out of pocket expenses related to the damage caused by the Mercedes factory defect.
IF you own a 2007 Mercedes with "4Matic", just get the car towed out if you ever get stuck or this can happen to you.
I am going back to Acura...
Summary:
Gee, simply taking foot off the pedal would have prevented this problem.
Blame the vehicle.
PS
An Acura MDX would not have gotten out of that snow drift.
The proper action to take when a tire is spinning due to lack of traction is to reduce throttle and/or change the conditions at the wheels to increase traction.
Unfortunately, people frequently lack the education or experience to make the correct decisions when driving.
Blaming Mercedes for a exploding tire is a just another example of a person failing to take responsibility for their actions in today's blame and litigation prone society.
Thankfully this incident did not result in any injuries.
Perhaps you did not read the forensic expert report posted on the web site. Read the engineering report and learn something about modern traction/stability control systems. You can look up his resume at www.robsonforensic.com; but he is far and away an unbiased expert on the subject.
The explosion occurred in 5-10 secs after applying positive throttle. This could have happened to anyone, including you. There was simply no time for a driver reaction.
The bottom line is the car was not moving because of a single high centered wheel. However the stability control module thought the car was traveling 20KPH (recorded in vehicle diagnostics log) so it inappropriately applied all engine torque the single, free-spinning wheel. Somewhere between speedometer indicated speeds of 35 and 50MPH (x4 = 140-200MPH), the 130MPH rated tire exploded from extreme centrifugal loading. The car should have applied the brakes to the wheel as soon as it's rotational speed was 3 MPH greater than the opposing wheel. This is according to Mercedes technical documents.
Had the car functioned as designed, the event would not have occurred.
Why is that so hard to understand?
