Ford Aerostar Starting/Stalling/Idling Issues
My 97 Aerostar 3.0L has developed a wierd problem. When it is cold (below -10 degC) it will not start. When I turn the key on, I hear the fuel pump relay click but do not hear the fuel pump. Also the light for the overdrive displays off. At first I thought the gas line was frozen but that isn't the problem. If I plug the block heater in for a couple of hours, it will start right up. Also the off light for the overdrive is not on and of course I hear the fuel pump when the key is first turned on.
Any ideas what might be causing this? It runs great after it starts.
Thanks in advance
Thanks in advance
Is this elect. or gas problem?
Thanks to All!!
thinks its running cold, but warmed up.
good luck on your aerostar
HELP!!!!!!
Elimination two, easyier, is make sure ignition wires are not laying bare on the manifold. Sometimes (it) happens. If it bumps the manifold, what ford stands for will show up. That is when the frustration begins.
Elimation three, is, simply check to see that the coil and condenser wires are secure.
Elimation four, if all these things check out okay, replace the distributor module, which is highly unlikely as it starts sometimes and runs fine.
matter is removed.
The easiest approach is to put on a pot of coffee, then get an extension cord and a hair dryer. Place the dryer so as it blows hot air onto the distributor and wires. Go back in the house and drink your coffee. This allows the dryer to dry out any moisture that may have accumulated. Give it twenty minutes.
If you don't want to do that get a can of spray-dry and spray the cap inside and out and then give it a try. Or, hang a light bulb, about 60 watts, over the wires and distributor. Caution that you do not lay bulb on engine parts or on plastic, especially if there is a strong smell of gasoline etc, just common sense things. Be sure to plug in light and see that it is burning, maybe a better word would be lit. Be sure not to light up anything else.
Today, I took out the distributer cap off. Inside the cap the "teeth" were rusted. I took sand paper and got rid of the rust. I used sand paper on the rotor as well. I cleaned until all the metal peaces were silver looking (cap and rotor). I placed the rotor and the distributor cap back and it worked. At first I could not start just with the ignition key. I had my father use the helper from the engine and the car started. And now, it starts just fine with only the key.
So if you Aerostar cranks up due to rain, moisture...
1. Open the distributer cap
2. Clean the "teeth" with sand paper inside the cap
3. Clean the rotor with sand paper
4. Put everything back the way it was.
Don't unplug the cables. Check this video as well. http://www.youtube.com/watch?v=nKELjcqT-oM
Mechanics were telling me to replace the cap and wires... which would cost around $40 cap and wires plus $70 labor. I don't think you need to buy a new cap. Just remove the rust with sand paper.
Getting to the distributer cap is tricky. From inside the car. There is a peace you can take off right under the radio. As soon as you open, you can see the distributer cap. Placing the "under radio cover" back is tricky as well. You need to push from inside the car with you hands, and from under the hood with a 4' stick (I used the back of a broomstick). Push both at the same time until the cover fits back in place. For this you need two people.
Hope this helps.
No apparent signs of overheating. is it the thermostat? How to replace?
