Oldsmobile Alero Maintenance and Repair
joejoejojoejoejo Member Posts: 3
I keep finding a small puddle of coolant sitting on a lip about 1/3 of the way down the engine. About 4 months ago it kept overheating so I changed the thermostat, fixed. But it still leaked coolant slowly. Now the car is overheating again and the heat doesn't work most of the time. It also is going through a crazy amount of anti-freeze, and it is blowing out the overflow hose on the reservoir. About to take it to a dealer or mechanic, I don't have a garage and it is -4 outside. Can anyone help??
«134
    toppimp92toppimp92 Member Posts: 1
    I have a 2000 Alero and whenever i drive it it turns off, but it'll turn on again, but i have to wait for like 2-5 mins. so it can start it up. what is wrong with it?
    tomslookingtomslooking Member Posts: 2
    My 2000 Alero did the same thing. Dealer replaced electronic fuel pump, no more occurences (yet).
    burdawgburdawg Member Posts: 1,524
    If it's a V6 then it's a real possibility the intake manifold is leaking. It's a problem that has been discussed many times here and in the Grand Am forum.
    Taking my 01 v-6 Alero in to get fixed any idea on how much it should cost? Leaking Intake Manifold.
    If that's what it is, if I remember right, expect $600-$700.
    emmanuelchokeemmanuelchoke Member Posts: 97
    Head gaskets, $1,000 to $1,500.
    robwhitrobwhit Member Posts: 13
    My daughter's 2002 Alero 4 cyl stalls maybe twice a week, especially in cold weather,when engine is warm and idling- NO check engine light comes on. Mechanic confused- one reply said changed fuel pump to solve problem-would yellow light not go on if fuel pump failed? Any other ideas what problem may be? Mechanic wants to start replacing some other expensive electronic parts. Car has new fuel filter. Runs GREAT otherwise.
    destination0destination0 Member Posts: 1
    I'm so glad that I found this website. For the past two weeks my 2003 Alero has been doing the same thing. The dealer has made me feel like I'm making this up because they weren't able to recreate what happens when the car is in my possession. I've paid for a new battery and several diagnostics that turned up nothing. No engine or service light has come on. I will be printing this suggestion off and telling the dealer since my car is currently not working. Thanks again!
    Further to my daughter's alero problem-It has been suggested to me that many times the key assembly loses the signal (anti theft)and will shut the car off-local dealer sells a lot of these ignition assemblies and my dtr had A LOT of extra heavy keys etc on her key chain which can damage it due to the extra weight. She now only has the one key on the chain and so far car hs run fine-We are crossing our fingers-Do you have a lot on your key chain and is yours a 2.2 engine? Our dealer says not many fuel pump assemblies are sold-they are very costly!!
    Is the security light coming on while driving? The passlock system is not supposed to shut the car down if it detects a security fault while it's running, but the light will come on.
    Having a failing fuel pump shouldn't in itself cause the check engine light to come on.
    No there are NO lights coming on the dash-Interestingly it only stalls when idling.
    someone else suggested that if fuel pump failed the engine yellow light would likely NOT come on. The price of a fuel pump assembly is unreal for this car!! So far the car has been OK with only the ignition key on her keychain but the stalling tended to happen when it was cold outside even after engine was at running temp.
    Thanks for your interest in trying to solve this wierd problem. If a dealer started playing with the car it would soon be over a $1000 and still maybe not fixed.
    Have you tried wiggling the ignition switch while it's idling to see if you could replicate the problem?
    Yes but it did not cause it to stall. With the nicer weather the problem seems to have gone away till next winter.
    mickey20mickey20 Member Posts: 1
    i took my car back to the dealer in october to get mines fixed. I paid 800.00 dollars. Now the same things has happen again this time they say i need a new motor, I think that they did not do something right the first time. because the car did the same thing again.This time it messed my motor up
    thompdthompd Member Posts: 2
    I've read through the thread and I can't believe all of the problems with coolant leaks from an Alero. Just took mine to a dealership to check the cause of a coolant leak and some other "loud" noises. Was told that I needed the following - Engine drive belt (is this the same as serpentine belt?), spark plugs, water outlet assy., F&R Brakes,;fuel filter,front engine mount, engine cover, outer tie rod ends and "set toe in"(never heard of that one). I've had the car for 5 years. Not quite ready to purchase a new car and huge payment but was told by one mechanic that it really may not be worth fixing since the mileage is high and don't know what will go next. There are also some lights that need replacing. Estimated about $2700. (pricey dealership fees). Any thoughts??
    The drive belt is the serpentine belt. Brakes of course are wear items. Fuel filter is recommended to change at 100K, but it may need it or not, but it's good maintenance, same with the spark plugs. I take it your coolant leak is from the water outlet leaking - is it a gasket or the housing leaking itself? The engine mount can be bad at 100K, it's not unusual. Don't know what they mean by the "engine cover". Outer tie rod ends if worn and replaced will mean the toe in will have to reset, in other words an alignment.
    I like to get at least 150K out of a car, so I would consider doing the repairs, but I do as much myself as I could to keep the cost down. You may get by without the plugs and fuel filter, the rest you should do.
    ronsmith38ronsmith38 Member Posts: 228
    My daughter's 2001 V6 Alero shuts down while driving. The first symptom is the doors unlock on their own, and some dash lights may flash. So far she just pulls off to the side and is able to restart the car.
    Also, sometimes the car won't start, it acts as if the battery is dead (the battery was just recently replaced). After several tries if then will start.
    Any idea of what can be wrong?
    Bad ignition switch? Does she have lots of stuff hanging on her key ring?
    Thanks for your reply-Yes she had quit a bit extra on her key chain and since removing all of it the car has not stalled-if this is the problem it is wierd that it did not stall while driving and only at idle.
    sscreenersscreener Member Posts: 3
    when I went to put it in reverse,the little button on the side of the shift lever popped out.It won't stay in,is it broke or can it be fixed or do I need a new one.How easy is it to fix? 2000 alero 4cy
    joe7074joe7074 Member Posts: 2
    same thing happened on mine also.i was planning on going to the junk yard and seeing if i could find another one.it looked to me like the hole gets wollowed out from use until it just popps.sorry i dont have an answer but your not alone
    Just got the car fixed.The part was broken and it cost $43.00.My mechanic took ten minutes to put in ..........
    ksnmlaneksnmlane Member Posts: 1
    My g/f's '01 alero, driving to work, every light on the dash came on, check engine, trac-off, etc... what could this be??
    lgoodenlgooden Member Posts: 1
    My 1999 Oldsmobile Alero, V6, 3.4. Had problem running hot, I took it in for repairs an it would not start after they did service. after complaining I did the work all over myself.. I had the heads serviced; serviced, valves adjusted and replaced head gaskets. but when I torque the rocker arms done to 168 inch pounds the car want idle smoothly an some time want start. so I keep re adjusting the rocker arms, loosening them and slowly torque them down, it works find if I dont torque them down all the way, but they loosen like that. also I've notice that the Ex-rods our a little longer than 6 inches. And I read the my over heating problem could and still maybe that my water tank on the radiator could be bad or need a smooth service.. Which I think could be the next issue.
    rpino69rpino69 Member Posts: 7
    My wife owns a 2001 Alero and the check eng and trac off light keep coming off an on. When it is on the trans hits real hard. Can anyone help.
    melissa1106melissa1106 Member Posts: 1
    I've been having a problem with my Alero. I'm driving & then suddenly the car won't go past 10 mph, it doesn't shut off or stop, it keeps driving but not over 10, and when I step the gas, the car pulls . I have to turn it off and re-start it again for it to gain speed but then a couple of miles or blocks, whatever the car feels like doing, later it happens again. I've been on the highway when this happens, I've been on city streets when it happens, I've even been on stop lights when it happens...It's emabarrassing, annoying & not to mention, dangerous. Does anyone have any suggestions/solutions? I've had the spark plugs changed. :mad: :cry: :confuse: :sick:
    tcatrider_99tcatrider_99 Member Posts: 1
    I have a 2000 Olds Alero with a V6. It is throwing a code for the Cam sensor. I purchased a new Cam sensor but now I'm not sure where the Cam sensor is located. Can anyone tell me where to find the cam sensor on this motor? Thanks.
    ijennings1ijennings1 Member Posts: 67
    Our 3.4 2002 Alero (65,000 miles), has a problem with acceleration. It is very sluggish when accelerating, although after about a 5 mile run on the freeway, it improves, but is not perfect. It's now virtually impossible to drive safely, and on an incline, we are in trouble!
    About 10 days ago, we filled it up with gas from our usual gas station, and inserted a well known make of fuel-injector cleaner, which we use about every 3 months. Therefore, we thought it may be some dodgy gasoline. So, when it dropped to about 1/4 full, we filled up again, but it has made no difference. Now the 'Service Engine Soon' light is on, but is not flashing. I've checked the fuel cap, and that seems to be fine.
    Can anyone advise before I take it to my shop for yet more remedial work!
    Turns out the repair shop guys ran a scan, and the catalytic converter was shot! Apparently, the average life for the 3.1, 3.4 & 3.8 liter engines is 71,000 miles. Total cost to repair was around $450! HOWEVER, the good news is, GM waranty these converters for 8 years or 80,000 miles; at least for our model (2002). So, if you have this problem, check with GM, to see if it is covered by their warranty.
    mjgroffmjgroff Member Posts: 1
    I have a 2001 Olds Alero. The other day, out of the blue it started acting like it wanted to stall( shaking and idling very rough) Once you start going it seems to run okay, only had problem at idle, however, it did make a smell kind of like burnt fireworks. The check engine light flashed on and off. Diagnostic showed misfire on 3. I was told to look for vacuum leak. Got it home, turned it off, now it wont start. Anyone have a suggestion?
    See my two posts above. Maybe number 3 spark plug has gone? How long ago did you change the plugs? What engine do you have? What's the odometer reading?
    Sorry to state the obvious, but get it towed to a repair shop ASAP, don't drive it there, even if you can get it started. By driving it to the shop, you may do more damage than good.
    I'll keep my fingers crossed it not too expensive for you.
    joycejjoycej Member Posts: 1
    my 2001 is doing the same thing, my husband found a broken wire in the drivers side wheel, its suppose to be for a speed sensor, but my speedometer works fine. they want 350.00 to fix it.
    Sounds like the broken wire is for the ABS (anti lock brakes), so it wouldn't have anything to do with the speedometer.
    jgraysonjgrayson Member Posts: 1
    I need the location of the HAZARD WARNING SWITCH on my wifes v6 2001 Olds Alero. The turning/hazard lights are intermittent. I see there is a recall on that part. But if its somewhere I can get to it I would prefer to replace it. IF that part is available to the public.
    Thank you,
    Jeff
    klauszuckklauszuck Member Posts: 1
    Hi my name is Klaus and I’m from Germany
    I'm driving a 2000 Alero and my current problem is, that my dash light shuts of, when my headlight go’s on. I tried the wheel where you can dim it, but it's still dark. Even the display on the radio gets dark.
    Did has somebody the same issue.
    Klaus
    :confuse:
    jdknight_79jdknight_79 Member Posts: 1
    Just two days ago my 2000 Olds Alero Coupe started to idle rough. I went to my local Autozone and had a free code reading. It said Cyl 1 Misfire. I took the coil pack off the car and removed the plug boots then put them back on. The car is doing the same thing. I purchased a new coil hoping that would be the problem but have decided to wait until I can pick up the plug boots and do the two jobs at the same time while I have the coil pack off. Does anyone know what the problem might be? I'm thinking about replacing both coils as this is the 4 cyl 2.4 model and has two coils.
    phnzzphnzz Member Posts: 1
    When I turn of the rear defroster it only stays on for a short time. If I push the button again the light does not come on. I have to wait a few minutes then it will come on for a short time. What needs to be replaced? Thanks.
    kdeezlekdeezle Member Posts: 12
    I am having trouble with my heat. The heat will only come out at the highest fan setting any other setting only minimal heat will come out as I accelerate. the heat comes out very warm. that is not the problem. the problem is it is only coming out on the fan setting. I have a new water pump and no leak I can see. Can anyone give me any advice?
    It could be the fan relay or circuit board. Don't know where these are located. There seems to be a problem with these cars with the fan speeds 1 and 2 not working.
    bigdingdangabigdingdanga Member Posts: 2
    I too am having the same problem, however I took it to a local shop and was told it is probably the blower resistor (which can be picked up from any "big box" parts retailer for about $20-$30). I paid about $24 for mine and am going to install it shortly, as soon as I figure out where to look for it, which is why I'm browsing through here.... lol
    Good Luck
    It's on the bottom of the plenum in the passengers footwell. You will have to remove the trim panel below the dash. Look for a connector on the plenum, remove it, then remove the two screws (the back one is hard to get to).
    sheryl7737sheryl7737 Member Posts: 1
    I've been trying to get a hold of an 2000 Owner's Manual for a few days now and I am not having any such luck. When I bought my car it didn't have one. If you could help me in anyway, I'd be very appreaciative.
    ssanchezssanchez Member Posts: 1
    This part is inside the fan housing
    krawdadikrawdadi Member Posts: 1
    I replaced my resistor board to correct the fan problem. It is under the ac blower fan on the passenger side. It is a tight fit. you will need a flexable rachet extention to remove the screws that hold it in place. Once removing the ac blower you should be able to see it after removing the connector that plugs into it.
    :D thank you for the help, I did however already "fix" the problem lol, in my instance there somehow is/was water in that whole assembly so I disconnected the pig-tail to the resistor dried it out and put electrical grease in the harness, reconnected and still got nothing without kicking the blower motor then I would get a little bit of a reaction. The blower would spin very slowly creating a slight breeze, that is when I decided to spray some "old faithful" (WD 40) into the motor casing through the holes that are visible on the bottom side. Once I did that I tapped the motor with a regular claw hammer and voila!!! I now have heat again!! I did however have to tap on the motor for a couple days but it's been nearly a week now and it's still going..... knock on wood!
    stepbak27stepbak27 Member Posts: 1
    Ok after reading these posts I have found out that people have had similar experience as i have had in the past 6yrs. My Alero has 175,678 miles on and and when I bought it back in 2002, it had only 28,000. Yes I have really drove it havent had any major issues until now. I have had the hazard switch replaced, ingition module, coil housing (sp), brakes replaced many many times as well as rotors and also the fuel pump was replaced recently. My service engine light came on when I hit 50,000 miles and has been on every since. I was told it was the oxygen sensor, well had that replaced and it still is on. Now my car is starting to really knock and it used to have a fast take off but for the past month or so, when i take off, the service enginge light blinks and the trac off light comes on. as of today, the service engine light blinks the whole time i am driving and my car is very hesitant and knocks really bad. On top of all that, the heat is not working. It seems to only work when i am driving but when the car is still or stopped it doesnt blow out warm air. The low coolant light comes on constantly so when I went to have the thermostat replaced, I was told that my engine is running off of 2 cylinders and my car is a 4 cyl. Has any of this happened to any one else? What do I do about my car only pulling from 2 cyl? Is it worth repair or should I just get another vehicle?
    rdeschenerdeschene Member Posts: 331
    Did the service technician even explain WHY the engine was running on 2/4 cylinders ? It's either spark or fuel, right ? Spark: could be fouled spark plugs and/or bad wires -- the latter tending to be worse in high humidity or rain.
    Heat: could be related to only running on 2/4 cylinders (less combustion so less heat, right?) or maybe the blower motor resistor is shot. The latter would give you consistently no air speed for a given fan speed setting, regardless of whether the car's moving or not, though.
    When you replaced the O2 sensor, it doesn't seem that was properly diagnosed as it didn't solve the problem you were having.
