Thanks a bunch! Ashley
MODERATOR /ADMINISTRATOR
Need help navigating? [email protected] - or send a private message by clicking on my name.
Share your vehicle reviews
When I turn off and remove key the transmission message continues to show for about another 30 seconds.
When I turn on key, not engine, all messages flash and radio and navigation flash on an off and on. This is a mystery.
My husband has owned his '07 530xi (65k) for not even two months and has gotten to drive it less than three weeks worth of time. Got the car to the dealer (short version) where they decided that the replaced battery had never been programmed to the computer. They said we may or may not still have to replace it after they charged it fully and removed all the low voltage codes it was flashing.
The car ran fine for almost two weeks after purchase, then randomly would not start. It seems the major difference between our problem and those of many posters here is that the car would crank, it just would never turn over. It also never stalled on the road. It only stalled once, but that was after a successful attempt to start the car and then only a few seconds after the engine turned over and began to run.
We have had the car back from the dealer for less than a week, and this morning it would not start again. Now, however, the starter cranks and the engine turns over then stalls. Doesn't sound like battery to me. It is colder now (had out first frost last night at around 31degrees F), but the car is garaged.
Do we think this could also be an integrated supply module problem? I think hubs is at his wits end, but are now afraid we are stuck with this car because we won't resell to someone else knowing it has these problems. And we really don't want to spend a fortune fishing around for answers at the dealer.
FWIW, the first mechanic we had the car in to before getting it to the dealer (local , reputable and experienced with Beemers) had it for a full five days before the car decided not to start again. He successfully turned the key several times a day for every one of those five days.
The dealer at first refused to change mine as since it wasn't throwing any codes, BMWUSA wouldn't reimburse them for the part as they couldn't justify the change (mine was under warrantee) but I was to the point where I would have just bought the part myself and put it in...isn't that hard.
But after changing mine, the car has been rock solid for almost 8 months now.
We are having this same issue with my car. Was wondering if you figured out what was wrong. My husband changed the oil and the car worked fine. Then he tried to reset the service light and now my car won't start and it's flashing all kinds of errors.
Any help or advice would be great!
Thanks so much!
The starter turns but not the engine immeditely. If there are other queries to understand the problem better, please feel free to ask.
TG
I am in Midrand Johannesburg,
So you say it is the throttle cable? right?
How long is this job?
TG
The starter motor is not designed to run continuously, and I'm surprised it lasted 20-minutes before burning out! The manual on many cars talk about if it doesn't start in say 30-seconds, wait quite awhile before trying again to allow it to cool off. The starter motor continuing to run could be a bunch of things from a bad ignition switch to a sticky solenoid valve or a short. The mechanics of replacing it shouldn't be beyond a good mechanic, but most won't have the ability to reprogram the vehicle to a new battery. Batteries do not like to be deep discharged in general...unless designed for it, each deep discharge decreases the overall life, maybe to zero, if the current load is high enough andoverloads things warps things.
IBS Inelegant Battery Sensor and still nothing, i took off the starter and had it tested and it tested good. Called dealership and found out my car does not have INTEGRATED SUPPLY MODULE:121099 (12-52-7-510-638). I ask parts person can he tell me the part that replaced this on my car and he said he did not no. If anyone can help please let me know.
When you turn the key everything lights up properly but no crank! Any ideas or help would be welcome. Dealership wants 89.00 for first hour then the price goes up from there.
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
I have a 2005 BMW 530i with 145k miles on it. I know nothing about BMW. Having issues with starting. Put the key in, foot on brake, turn key and nothing happens. No lights or anything. Has happened a few times, but only when it's cold. When it warms up by afternoon, it will start. Haven't gotten any dash light warnings about battery. Only service light warnings I have are rear reverse bulbs need replaced, brakes need replaced and occasionally, when I stop, the abs warning will pop up. Had a slow start issue a few times, but like I said, not always and usually when it's cool out. Only other issue/symptom I've had is having to occasionally reset the clock after starting it, but not always on the days of the slow start, just randomly. Hope im making sense and someone can help. Thanks!
You have an E39 and they do not have the Intelligent Battery System(IBS) so there are no settings to change when you install a new battery
You've done a fair bit of troubleshooting, but you still might find this helpful:
BMW No-Start Diagnostics
