Subaru Forester (up to 2005)
11516182021344
  • tlimatlima Member Posts: 124
    The only rear speakers that I could find in 5" were Polk 501a. You may be able to fit some 5 1/4" with a little effort.
    -Tony
  • terijterij Member Posts: 1
    I found my first door ding today. Boy, that first one always hurts! Has anyone had any experience with paintless dent removal? The small ding is on the door about an inch from the edge. It's on the rear driver's side so I will notice it every time I get in the car.
  • tomsotertomsoter Member Posts: 2
    I'm about to maybe get 99 Forester S 4A 17,000 miles - dealer asking $16,566. Kelly & Edmunds say it's good price. Maybe too good? Carfax says title & record are OK. What should you look for on inspection or test drive regarding common problems reported on this or other sites?
  • jeijei Member Posts: 143
    My '99 Forester S 4A has almost 60K and has had only a few problems. I would inspect for:
    - Alignment, front & rear. Mine was off and made the factory tires noisy.
    - Cruise control. The thottle servo froze up and was replaced. Also, the switch on the steering wheel developed too much play front-to-back and would not engage regularly. I am replacing it also.
    - Premature/excessive brake pad wear. Pads should last at least 60K.
    That said, my Forester continues to delight me. I expect to keep it over 200K without major trouble.
    John
  • jackleungjackleung Member Posts: 79
    Remember U mention to me that U went to a shop called Custom Tinting near Lawrence on El Camino? I look around and couldn't found it. (I search thru yellow page on the phone also.) Can U give me a more detail direction how to reach there?
    Thks,
    Jack
  • gossamargossamar Member Posts: 106
    Yep, the FIRST one always hurts!! I have had two small dents removed on my SUPERDUTY, after the RHINO liner installer let the hose hit the tailgate. Granted, you could only see them from an angle, but I knew they were there. Had the local FORD dealer perform the work, at RHINO's expense, and it looks fresh from the factory!! The technician even went over the areas with me after he was done to ensure the work met with my satisfaction. A few tips for this process. First, the technician must be able to get behind the dent in most situations, Second, as long as the paint/clearcoat is not cracked, they should have no problem. Finally, it all boils down to the technician itself and the pride they take in thier work. Find a reputable body shop and get a couple of quotes. I picked up two new dings this winter on my truck, and will be making an appointment once the weather gets more into spring. So far, no dings on the Forester, the wife has been instructed on "proper" parking locations. Good luck....
  • kenskens Member Posts: 5,869
    Jack,
    Here's the address:
    Quality Window Tinting & Auto
    3295 El Camino Real # D
    Santa Clara, CA 95051
    (408) 363-8468
    Remember, tinting places are a dime a dozen. Try calling around a couple places. I'm sure there even better ones out there.
    Ken
    With the heated seat equiped on my 2001 S+, I don't have dual power socket beside the driver seat. And as the manual said, the one located on the instrumental panel is not suitable for any electrical accessories and it's burn some fuses of my accessories. Anyone has any idea on how to make the one on the instrumental panel to work? Or anyway to make the front passenger side to obtain the 12V power?
    Jack
    Ok, thanks a lot.
    I will try it next weekend since most of them are closed for Sunday.
    Jack
  • subearusubearu Member Posts: 3,613
    We've had our cell phone charging in that front outlet on several trips with no problems. I believe others have mentioned this also.
    As far as other plug in devices, I believe a radar detector would work without a problem also. Haven't tried one though.
    -Brian
  • kvailkvail Member Posts: 2
    I'm thinking about buying a 2001 Forester L and have been talking with a salesman at Gillman Subaru in Austin, TX about the internet price. He says he'll give me a price $100 above invoice, which runs about $2000 less than the list price. Does this sound reasonable? Is there something else that I should look out for?
    Kathy
    Brian,
    This is what I thought in the begining. But the result is I have 3 different accessories burned on that outlet. 1 phone charger burned the fuse, 1 one outlet to 3 outlets adapter burned the fuse, 1 indoor light burned the LED and this one is gone!(All of them are working fine in my previous car!) This will NOT happens ALL THE TIMES but it's just happens all of the sudden. Is this thing only happens to me? If so, should I bring this problem to the dealership even though the manual already mention the front outlet shouldn't use anything except Subaru lighters? How come I never heard of any problem in other car but Subaru in using electrical accessories in the "lighter outlet"?
    Is there any way to get the power from the original dual outlets in the L model? I am not a smoker and I don't mind to replace that "lighter outlet" with a "electrical outlet".
    Rgds,
    Jack
    One more note, all 3 things burned all of sudden within a week!
    Jack
  • dannykadannyka Member Posts: 115
    Hi all,
    The Forester I ordered is finally at the dealer. (Woo-hoo!) I'm picking it up this Friday. Before I sign my life away for it, I'm planning to do a walk-around to look for any dings, paint flaws, panels mis-aligned. I'll also take it for a test drive to check for unusual behavior and/or noises.
    Is there anything else I should look/listen for?
    TIA,
    -Dan
    I think with used Subaru if there is a problem it would be fairly obvious, so my suggestion it to turn off the radio, open the windows, and go on a thorough test drive. Listen and feel for anything odd.
    Take it at high speeds, low speeds, tight turns, bumps, you name it. Everything you are likely to encounter in regualr duty.
    I've used my front charger for a cell phone (fine) and a notebook computer (not fine, it crashed when I started the ignition). So I guess some things are fine, others not.
    Kathy: that price sounds fair. Just make it clear before you go that you want absolutely no surprises. No fees tacked on, no unwanted options, nothing that'll increase that price (undercoating, sealant, etc).
    -juice
  • subaru2subaru2 Member Posts: 3
    Two questions,
    I own a 1999 Subaru Forester S that just had transmission work done on it at Norwood Subaru in MA. They have car covergae up to 45k miles, unfortunately my car has 49K miles on it and I had to pay $30 per day for 3 days while my car was being serviced, the tranny work was under warranty. I already tried Subaru of America, no go. Anyone have any other ideas?
    Second Question: It was third gear and reverse that let go. Has anyone had similar problems at around 50K miles and what should I be looking for as I get closer to that 60,000 mile marker.
    I don't think a warranty covers a loaner car during service.
    If it happens again, ask the dealer for any old car off his used-car lot. They usually have something if you are flexible.
    Shoot - if something ever breaks on mine, I'd PREFER to get an SVX or XT, something interesting like that, as a loaner.
    -juice
  • riskman11riskman11 Member Posts: 11
    Although I haven't contributed much, I really do enjoy reading this forum. great discussions!
    We are rapidly approaching the 3000 mile mark with our '01 Forester S+. Any particular issues to be aware of as we get ready to take it in for service? Am also interested in everyone's thoughts concerning changing to synthetic oil. Don't plan to do it at this change, but possibly the next?
    BTW, the car has and is running flawlessly, although gas mileage isn't quite what I had hoped for yet. Part (maybe most) of that is the style of driving my wife does as she runs from hospital to hospital here in Baltimore. Generally averaging 20.5 mpg in the first 3000 miles. Getting ready for a road trip soon, we plan to take the Forester and hope the trip will help mileage improve.
    TIA for any thoughts re: synthetic oil. :)
    3000 miles just calls for an oil change. Unless there are any adjustments you want made?
    Wait until 15k miles or so to go to synthetic. Seems pretty early to me. My mileage improved up until about that kind of mileage (about +2mpg), which tells me mine was still breaking in.
    -juice
  • don4341don4341 Member Posts: 69
    I would think that the main reason a manufacturer would say "Don`t. use this outlet for anything else" is : There is only a certain amount of current available. Putting heavier loads on the circuit will no doubt overheat electrical contact points and/or wiring. Suspect that you have done this and you now have arcing connections which no appliance likes.
    If you were local I would say lets make up a extension cord to fit that socket and plug in a load near the recommended load range. We would then measure the current flow on our cord and see if it`s solid or flux. If the current varies on a pure resistive load I would look for a damaged socket or bad wire connection. Best guess - not a mechanic.
    Thanks juice, as of now, no adjustments needed, no rattles, no problems. The rear tires were a little bumpy for the first 2000 miles, almost as if they were flat-spotted, but seem to have improved. 15,000 is when I changed to synthetic in my Passat, and was planning to do the same with the Forester, just wanted opinions. I'm sure the upcoming trip (2000+ miles) will do wonders in loosening up the engine and improving gas mileage.
  • karen56karen56 Member Posts: 14
    I posted a while back and said that the smell was gone from my car and now it's back again, strong as ever! I'm at almost 4,000 miles and am at my wit's end. I really hate this smell. How much longer before it goes away, does anyone know?
  • gsogymratgsogymrat Member Posts: 97
    Has anyone towed with their Subaru? I have a 2000 lbs camper and wonder if a Subaru would have enough power to carry 4 people, gear and tow my camper.
    Karen: mine lasted a little longer than that. I don't recall exactly, but the undercoating burns off slowly. A long trip may help, or warm weather.
    Towing - I've only tried an empty 700 lb trailer to test my hitch. It's rated for 2000 lbs only if you have trailer brakes. Payload varies by model, up to 1040 lbs on the L 5 speed, so the people and gear ought to fit fine.
    So the key is the camper. How heavy, and does it have brakes?
    Unfortunately, none of the more fuel efficient mini-SUVs (RAV4 and CR-V) tow much either. In fact, their capacities are lower.
    -juice
  • dawatdawat Member Posts: 5
    Hi all, I followed this board and was convinced that the Forester was the vehicle for me. Because of a very hectic schedule, I could never go testdrive one or even get in one but I loved the way they looked when I saw them in my town, driving around. Finally, when I got a Saturday off I dragged my husband to the local dealer to look at *my* new Forester. First of all, we were completely ignored by salespeople. You would think this was a good thing except all the cars were locked! Finally, someone came over to us but told us he didn't sell Subarus but would send someone out who did. So while we're waiting, we're walking around trying door handles. Finally, we find one with the back door unlocked so I can crawl in and unlock all the doors. Talk about TINY!!! I'm not a big person, either. The first thing that happens while I'm sitting in the back seat is a reach over and pull out the cup holders...which immediately fall into my hand and onto the floor since I didn't realize I would have to catch them. Yes, I know someone else could have broken them but who wants something that could be broken that easily on say, a test drive... when usually people aren't really *using* the back seat. I then get into the drivers seat. It's ok but not spectacular. My husband gets in and moves the seat all the way back to where he would have it. Again, he's not an overly large person - 6". Then he gets in behind the driver's seat (we do this with every car we test). His knees are wrapped around the side of the driver's seat. I'm still rationalizing, however, that we don't really carry our bigger friends and family in the back *that* often. But the restricted space, coupled with the cheap accoutrements, inflated sticker and lack of service made us cross off the Forester. To be fair to Subaru, we also eventually found an unlocked OB Ltd (again, crawling in through the back). This was a lot nicer than the Forester. Roomier, less cheap feeling but w/ the sunroof, my husband's head brushed the ceiling. For about the same price as the OB Ltd, we're going to Toyota to get a 4Runner / HL where the quality and service can't be beat.
    I hate to rain on Forester's parade and I know everyone here will have a million justifications / excuses but I just wanted to let people who are considering a Soob to hear another side of the story.
    P.S. Yes, we left w/out taking a test drive. No one ever came out to see us and we were climbing around in their cars for a good 30 minutes.
  • qbrozenqbrozen Member Posts: 32,944
    well, you considered it too small. So, go with the 4Runner if you want. Those of us who have the Forester simply didn't want just another SUV. We wanted something that handled more like a car, had all wheel drive, and could carry more than a sedan. That's what we got. Simple. You want a truck. So get a truck.
    I owned an 87 4Runner for about 5 years (the longest I've ever owned one vehicle to date) so I would certainly attest to it being a good truck (although I don't care for the new ones).
    Good luck with your next vehicle.
    If you didn't drive the Forester you didn't really get to experience any of its best qualities (ride, handling, etc.). Too bad.
    The Highlander and 4Runner are nice, but not in the same price ball park, not even close. They appear to be fine choices, though.
    -juice
    dawat,
    Hey, no hard feelings. The Forester can't be everything to everyone. I think you hit the major issue on the head though -- you can't judge a vehicle without actually seeing one in person.
    One thing does confuse me, however, is that why were you looking at a mini-SUV when rear passenger room was of a major concern. People who shop for Foresters open compare them to similar vehicles like the CR-V, RAV4 or even the Escape. In comparison to these alternatives, the Forester does shine in many aspects. The only way you'll know is by actually seeing and driving the alternatives.
    Ken
  • sport33sport33 Member Posts: 19
    Just picked up my new 2001 "L" 5 speed, only upgrade was the remote keyless entry with alarm. Nothing else needed, lots of bang for the buck! Traded it straight across for my 4wd Xterra (rotten vehicle, the best part about it is the TV ads, I should of known better than to buy a reincarnated Datsun).
    After 1k miles, I slowly started working the motor up to 6k rpm, and now at 1650 miles the motor has really softened up nicely. The car is very quick, and total fun! First tank.. 27 mpg (highway miles under 4k rpm), haven't checked since. No mechanicals so far, the car is very tight, and the level of interior finish is great.
    I do though have a soft, rattling noise that seems to be coming from the instrument cluster. It seems independent of the motor (does not change pitch with change in rpms), and only noticeable while idling. Any ideas as to the nature of the noise? I don't recall having heard it before, however I've been too busy zipping around to take note. Also, @ 3k I was thinking of going synthetic.. I've always used "natural" oil. Any thoughts there? Thx!
  • canadianclcanadiancl Member Posts: 1,078
    Gee, I hope your husband is not upset, or depress, that you don't consider him overly large - 6". After all, statistically, that's considered at least average, isn't it? :)
    Sorry Joe (the Host), I can't help myself, it's just too darn tempting!!
    - "We wanted something that handled more like a car, had all wheel drive, and could carry more than a sedan. That's what we got. Simple."
    Seems like the Highlander would be the perfect car, no? After all, it's a Camry in heels with a foot of extra space tacked on the end. And I seriously doubt the Forester carries more than a sedan WITH the seats up.
    I didn't look at an Escape because I'm trying to Escape... crappy Ford cars, I didn't look at a Rav or CRV mainly because I heard so many people on this board gloating about how much bigger a Forester is. I DO need space but I also wanted something that would carry passengers, dogs, lumber, whatever but still be safe and drive well. Oh, yeah and not break like a crappy Ford (or Forester in this case) I wish I had driven it and I knew that was the one thing the people here would point to but it was really hard getting a "hello" out of the subaru dealer much less keys to one of their cars.
    I didn't really want to flame Foresters or Subaru or their owners. I just wanted people who do research here to get a balanced perspective. Read the opinions on this board and then go out, drive the car, sit in it, jiggle things around, kick the tires and be HONEST with yourself about what the vehicle can and can't do.
    Sorry the dealer ignored you (WHO was that?) and the rear cupholder broke. Two years ago I bought a '99 Forester "S", even though the back seat is tight & flat - because of the driving experience -I mostly commute alone.) On the same day, we tested a RAV4 (too light/small/cute; dumb rear door with no bumper), an Outback (roomy, pleasant) and the then-new Forester - which produced big silly grins on our faces! For all the cost of a new car, I wanted some delight. Still true at almost 60k miles with few problems. When the kids are home, they do grumble about the back seat if they're stuck back there.
    HOWEVER - if the Highlander had been on the market, I would have also test driven it, and most likely, seriously considered it. Definitely more roomy, and really another size/price point in the market. I will test drive the HL for the fun of it even though it's fairly pricey and I'm not in the market.
    So good luck in your research & purchase. I appreciate your honesty. If you do try a Forester (at another dealer!), let us know how the driving compares to the Highlander.
    John
  • drew_drew_ Member Posts: 3,382
    LOL, only Steve and I are co-hosting the SUVs message board. No Joe here! ;-)
    Carry on...:-)
    Drew
    Vans, SUVs, and Aftermarket and Accessories message boards
  • kate5000kate5000 Member Posts: 1,271
    It's too bad that ignorant inattentive salesmen at that dealership turned you away. The back seat room is small in the Forester, no question about it. As far as front seats are concerned, opinions differ. There was a person of 6'7" on this forum (with an appropriate moniker "big_guy"), and he said the Forester and Escape were the only SUVs where his head was not brushing the ceiling. Try Nissan Pathfinder, for example. It looks much bigger, but interior is pretty small. Even I feel cramped there, and I'm only 5'3" (on a good day :-).
    I did not get a chance to test-drive the Highlander yet. It looks nice (like Forester on steroids). We think of Highlander as possibly a good choice for my husband's next car, but I reserve all the opinions until we actually test it.
    I should say that driving dynamics of the Forester are so good and it's so numble that after I owned it for 6 mo, every other SUV feels really clumsy. Since most of the time I commute alone in the car, back seat room is not an issue. Yet it holds a teenager plus baby pretty well when needed.
    Try driving both the Highlander and the Forester, and let us know how they compare.
    Just got 99 S automatic with 17k. Subaru doesn't provide seatbelt extenders and universal type won't work. Anyone know of extender from other import (like Toyota, Nissan,etc that provides extenders) that works?
    I remember reading on this & other sites about the funny sulfur smell. What is it and can it be fixed?
    Do ABS normally travel closer to floor than regular brakes? Mine go to about 1 inch above floor.
    brake pedal travel for ABS should not be more than for non-ABS.
  • oregonsubieoregonsubie Member Posts: 10
    I really do not see how the Highlander and Forester compare. Our 2001 S+ with every option was around $23,000. For a 4 wheel drive 4 cylinder Highlander the MSRP is $25,395 without adding options. Adding a few options to that, and no huge sunroof, I got the price to $26,569. That doesn't include an LSD system, side impact air bags, huge sunroof, 6 disc in dash CD changer, heated front seats and mirrors, aluminum alloy wheels and its short 10HP and weighs more than the Forester. Even paying a little over invoice, option for options the Highlander is a good $3-4,000 more than the Forester. If 1 inch more headroom and 1 inch more rear seat room is worth that price, then buy the Highlander.
    My only point is that option for option, SUV for SUV the Forester beats the competition hands down. The Subaru dealership I bought my car from has called me repeatedly to make sure the car is okay and I still like it. They rolled out the red carpet for me when I brought it in for the first oil change. They even called me on my birthday last year to wish me a happy birthday. Not all Subaru dealerships are the same. When it comes to dealerships remember, Your mileage may vary.
    Also, the over inflated EPA estimate for the Highlander 4 cylinder is 24mpg highway, while the Foresters is 27mpg. Even 3 to 5 mpg over the life of a car matters to me. Just my 2 cents worth on comparing these 2 cars.
  • p0926p0926 Member Posts: 4,423
    dawat- The Highlander is sure to be a popular vehicle but it's in a different class from the Forester. It's really a mid-size SUV designed to compete with Explorers, Blazers and the like. Also, I just checked Edmunds prices for the Highlander and the selling price appears to be at least $5,000 more than a comparably equipped Forester.
    The Forester will certainly hold more than a sedan, even with the seats up (remember the cargo area goes all the way to the roof).
    Sorry to hear about your experience at the dealership but fail to see how that soured you on the vehicle itself. There are plenty of other dealerships out there that I'm sure will be more than happy to sell to you.
    Bottom-line. If the Highlander better fits your individual needs and if you have the cash to pay for it, then you should certainly buy it. (After test driving it of course)
    -Frank P.
  • joseph50joseph50 Member Posts: 235
    Before I purchased a 2001 S in January, I was mindful of reviews commenting on the Forester's "soft" brakes, and I found this indeed to be true on mine. But, in the course of driving (and thoroughly enjoying)the vehicle, the impression registered that the relative softness is actually conducive to using the ABS correctly in an emergency-stop situation. If the brakes were tight or hard, the initial and immediate felt resistance might cause me to back off the pedal instead of continuing to apply constantly increasing pressure.
    Just a thought from a someone happy to see 30 mpg on my last fill-up when my previous Tauras' best was 27 mpg over the the same trip.
  • pnptmpnptm Member Posts: 5
    I picked up a Blue S 5 spd Monday night, and just wanted to say thanks again to all the helpful responses to my questions posted here while I shopped........juice, Frank, and others.....I'll be checking in from time to time and hopefully can help others (and dawat, agree the cupholders are poor- but we all need something to complain about!!)
    sport33: congrats. I'm sure your mileage is much better than before. Any more specifics on the rattle? They are not common in that area.
    Tom: the pedal can be adjusted, but you may need new pads. The previous owners may have ridden the brakes. The break-in smell should be gone by 17k, though. Wash the undercarriage to get any salt mix from winter off.
    Congrats pnptm. Glad we could help. Hang around and share impressions in a few weeks?
    I think ít's a high complement that the Forester is being compared to the Highlander. We're talking about a $30k plus SUV, easy. Equip one like a $23k Forester S Premium and you're probably a good $10 grand over the Forester, yet we are arguing over which is better.
    -juice
    Remember the electrical outlet problem I had mention before? Turn out is my poor quality phone charger coz the short the circuit and burn the fuse. So, the electrical outlet in the front panel is ok to use any electrical accessories (of course, resaonably load) with it.
    pnptm- Congratulations! Wait a minute...my Blue Ridge Pearl Forester is becoming less and less rare every day it seems. Ah...the price of fame!
    Jack- Glad to hear it was your phone charger causing the problems. That makes much more sense.
    -Frank P.
    Ahh... I love a Blue Ridge Pearl one too. Too bad they don't have it on S+ model... :~(
    Rgds,
    Jack
  • araymondaraymond Member Posts: 3
    Juice, Ken - anyone: What's your sense of the going market price these days for the Forester I I/ automatic. Edmunds is showing: invoice $19,223, MSRP $21,095 & TV $19,649. That sound right? We're in Conneticut. - Anne
    Anne,
    I don't know about the NE, but around here in the San Francisco Bay Area, Foresters will go for $200-$300 over dealer invoice.
    One way to check "market" prices is to go to carsdirect.com and look up their prices.
    Ken
  • laurievrbalaurievrba Member Posts: 16
    hi, I'm in Ct also-I just bought a 2001 forester S+ for $150 over invoice, but my first quote(online -of course!) was for 250 over.
    I haggled with the online dealer(claiming another site quoted me less) which is how I ended up with 150.
    I ended up getting my subaru at colonial subaru in danbury- which was a good experience, I recommend.
    I think these guys have a big overstock of the foresters.
    Hope it helps
    ~L
  • mac08854mac08854 Member Posts: 6
    Hi everyone -- I've had my 2001 5sp Forester S since January 26. The car now has 2041 miles. Last weekend (St. Patrick's day), I began to experience major problems with the car.
    On the end of a trip, as I was about to park, the engine light turned on and the car began to idle roughly. I reached my destination, turned off the car, and let it sit (I went about watching the Corrs play in Rockefeller Center). When I returned to the car and started it, the engine still idled VERY roughly. However, the car still seemed to be able to drive okay, but that did not last long. Less than 2 miles later, I would step on the gas and would get little or no response from the engine. In order to get moving forward, I had to pop the clutch. But, as I would depress the gas, the engine would rev to 3000 RPM and then the power would drop rapidly. I could not let the engine idle in neutral because the car would stall due to the rough idle (it was like the engine was wheezing).
    Luckily, the dealership (Hillside Automall in Hillside, NJ), was on my way home and not too far from Hoboken where the car was parked. The car literally limped there (I *should* have called Subaru Roadside Assistance). A mechanic at the dealership took a look at my car with the diagnostic computer and got the code "301", interpreting that as misfires in Pistons 1 and 3. This was at about 1950 miles.
    He blamed the problem on bad gasoline (I used regular, like I always use and as the owner's manual states) which clogged the injectors. He poured a canister of dry gas chemical into the tank and revved the engine, which seemed to clear up the problem. He said that if I continue to have problems, bring the car back. I was able to drive the car home, and it seemed to be fine. The tank was filled about 1/8 with the old regular gas, so I proceeded to fill the tank with mid grade gas from a station on the way home.
    On Tuesday night, I began to notice a slight rough idle, a slight power loss, and the engine light turned on again. Sensing a return of the problem, I made an appointment for Thursday morning at Hillside for service. But, just my luck, it drives fine Thursday morning and the engine light turns off. The dealership looks at it, says there's nothing wrong with the car -- but I insist they do something about it and they order new injectors for the car. They continue to tell me the car is fine to drive home, which I did, and it did handle fine. The car now had 2011 miles.
    HOWEVER, on Thursday night, less than 12 hours after I left the dealer with the "good-to-go", the problem returned with a vengeance pulling into my driveway (2041 miles). I had the car towed Friday morning (this morning) by Subaru to Hillside, as I deemed the car way too unsafe to try to drive to the dealer. The response of Road Side Assistance and the actual tow truck driver itself was quite fast (45 minutes, compared to a 5 hour experience I had once with AAA), and the towing experience was actually really pleasant (good conversation with the mechanic while driving to the dealer). I wish that my experience with the dealer was only so pleasant.
    They were extremely resistant to giving me a loaner car, and it took my insisting to speak to a manager and arguing I should NOT be having any of these problems with a car that is not even 60 days old and hasn't even had its first oil change. I was NOT going to pay for a rental. I got the loaner rental for free: a lovely Geo Metro (well, it WAS free).
    I am now waiting for a response from the dealership, what they find, and what they fix. Luckily, everything is covered under warantee (that first 90 days). I am praying that I did not receive a lemon -- I waited for this car (it was ordered) for nearly three months, longer than I've even HAD the car. I do not believe it was bad gas, as my Dad had filled our van with regular gas from the same station the same day I filled my Forester, a week before St. Patrick's day. I am very disapointed in the mechanical problems I am having, after reading so much about reliability -- especially since I've only put 2000 and-some-change miles on the car.
    I must admit, I still do love the car and how it drives as well as its feature content. I also must commend Subaru for the excellent response with their roadside assistance and the mechanic/tow company they chose in Edison (DeFalco's towing?). However, this has done some serious tarnishing on my view of the Forester as well as the decent purchasing experience I had with the dealership (Hillside Automall).
    Needless to say, I will be writing Hillside management and the operations center in Cherry Hill, NJ.
    I will post the resolution of my mechanical problems hopefully later this week.
    --Mac
    PS. I recall someone in this group had a similar problem in an automatic where she would lose power while depressing the gas. Did they ever post a resolution of the problem and the root cause?
  • bassistbassist Member Posts: 15
    Mac,
    It sounds like you are having the very same problem I had with my '01 Forester. No power on gas, very rough idle, backfiring, etc. I posted about it a few weeks ago (#775). The dealer replaced a bad fuel injector and a faulty fuel air sensor (actually the 2nd time the oxygen sensor has been replaced). Since then my Forester has been running fine.
    Sounds like I had better luck with my dealer service than you however (Carr Subaru in Portland, OR). They were pretty sympathetic and gave me a rental car with no hassle.
    I have a lot less confidence in my Forester. I'm seriously thinking about getting rid of it but I'm not so sure about what I would replace it with.
    cam
    Ateixeira, re post 881. The noise has a soft "tumbling" quality, however I have since gone back to the dealer and have heard the sound to a greater or lesser extent on other, new Foresters. It's a hypercritical complaint, I have to find something wrong with the vehicle!
    I am sorry to hear others are experiencing trouble with their soobies. I have owned many new cars/trucks in my lifetime, and let me assure you there is no such thing as a perfect car. My other fun car for now is a BMW 330ci and it is by no means totally "ultimate". For the money, I have not come across a better value, or level of finish than the Forester not to mention the fun factor of a 5 speed... rally, rally!
