Subaru Legacy Steering Issues
I bought a brand new 07 Legacy 2.5i sedan at the end of 2006. At 1500 miles the steering was problematic, took it in to the dealer, and by the time they were done, they replaced the entire power steering system. They said the problem was with the power steering rack, which they replaced. I asked if this new part was from the same supplier, so could also be defective, and apparently it is. I am rather alarmed, this is the 1st brand new car I have purchased in 20+ years. Has anyone had similar problems? - Merrie
-mike
Let the dealer fix it, call 800-SUBARU3 if you need help from SoA. I'm sure they'll sort it out and this will become a distant memory.
-juice
If it is working properly, I expect, as do Mike and juice, that this same problem is highly unlikely to recur. Steering problems, in general, are not common, but there are always bound to be one or two bad products to come off every production line. I think you just were unlucky.
-juice
-mike
-mike
-mike
As the problem was averted with the FWD fuse, does that indicate a center differential problem or would it have to be the rear?
-mike
-Wes-
What some people are calling a center differential, the tech manual calls a transfer clutch. (I have a tech manual covering the transmission). I am thinking this is the problem. It can not be the front differential as the problem would not go away by installing the fuse.
Do you have any additional information? Do you want me to keep you in the loop regarding what I learn?
Let me know
Tony
Gaby
-mike
Subaru Guru and Track Instructor
Steve H
You say "i have the fwd fuse out of my car"...
When you take the fuse out, it's AWD.
You actually insert the fuse to go to FWD mode.
So it seems like the problem occurs when AWD is engaged.
Initially with power steering problems, you will only hear noise (and shaking) when the car is cold, and when you turn to extremes. Later, more stuff happens more often.
If you've lost power steering, and lights are on, this really sounds like an urgent situation. It might be unsafe to even drive the car. I ended up getting my car towed using the Subaru 24 hour roadside assist to the closest dealer. It was easy. No hassle, no problem, no charge.
[I had waited until my car was un-driveable because I kept thinking it was 1) my imagination, or 2) I'd take it to the dealer and they would say #1]
One quick thing you can check is the power steering fluid level, if you're able. My car had no fluid left after the rack had broken.
Good luck, be safe, and let us know how things work out
I brought my 2003 Legacy to a mechanic last week with a steering problem. Turns out the hose was dried out and leaking in 3 places and I needed a new pump. I got a call on Friday saying they replaced both but now with the new parts, the power steering is not working when idle or slow, only when the speed picks up. They then replaced the (new) pump and hose and put in a new rack, but to no avail. The same problem was happening. They tried it again with a 3rd pump and hose and 2nd rack and it STILL wasn't working. They've called Subaru and other mechanics and everyone says that what they tried should have worked.
Has anyone heard of something like this happening and have a solution? If not, does anyone have an idea of what else they can try? They've had the car for a week now and we wouldn't mind getting this fixed so we can get our car back.
