Did your repair shop check your entire system for leaks, bleed, flush and install new fluid? Have they checked out your calipers?
Good Luck, ask lots of questions at the repair shop.
My problem with my 03 was different than yours. The compressor got really loud for a little while and then didn't come up. When the front suspension didn't come up I also noticed that I didn't hear the compressor any more. The dealer replaced the compressor and relay for $700, luckily under warranty.
-gatorrob
2. Any O2 sensor problems out there? Check engine light came on, went to auto shop and they said that my O2 sensors were the cause for the light coming on. Appreciate any advice. Thanks
The other is using a slight amount of shop air, artificially inflate the system once it's disconnected from the compressor. This can tell you if the system after the compressor is air tight.
Just a note: Never raise the car off the ground and activate the air ride system.
As far as your O2s go. They certainly could be bad. Not only length of time but several other things can destroy them. Chemicals of all sorts can wreck them. Something as mundane as the wrong sealer used on an intake can have an effect. Running too rich can do that as well.
O2's are also considered a "tune up" item and are recommended to be changed every 60K miles or so. But remember to maintain your ignition and fuel system as recommended as well. Doing one without the other is useless.
Whenever you have a sensor code. It's a good idea to check for at least the presence of voltage and ground when applicable at the sensor. With many feet of wiring and several connectors usually between the sensor and the PCM. There are numerous opportunities to have a failure that is not the fault of the sensor.
Now, this could be totally coincidence, but now I have a problem, just weird.
I guess the fuse would be first step,,,anyone know which fuse???
Relay next step, passenger side under bumper???....How do I tell it's bad????
Any other ideas????
Front end still at normal height...
I don't hear the pump come on when it goes in gear either???
Previous owner may have had the height sensors adjusted to ride a little higher.
I have a 2003 Lincoln Navigator and It has the "Check Suspension light on the dash. I took it to the mechanic and he put it on the module and error code "C1991" came up and it said: "Module Calibration Failed." The mechanic replaced the height sensor and the solenoid was also replaced. The "Check Suspension" still remains on the dash.
What is this code and how can this problem be fixed?
My suspension seems to be working because my SUV raises and lowers itself whenever it needs to. The compressor is working.
Thanks in advance
Hello. I absolutely hope for some help. Here it is no one knowing anything about Lincoln Navigator ultimate. I have a 2004 . And now suddenly last day it came a message :
Check air suspension, and not long after it behaved like a kenguru. And it was absolute down in the front over the wheels. We of course do not drive it now. But we must find out what it is.
I have red that maybe I have to change a "dryer " it stood at this site :
"Help your compressor stay dry by replacing your air suspension dryer every 4-5 years. (Note: "OUR" rebuilt compressors come with a dryer already) PLEASE CHOOSE 1 hole dryer) OR 2 hole dryer."
Is this the case ? I dont think this has been changed before, but is the problem coming so suddenly as this did.
I had a smal "accident" at home before driving, I backed into a plant pot in plastic, I think it came just under but I cant see anything did happen. But I can see that the button for this air suspesnion is located back.
And I red also to check the hight sensor, where is this placed and can I check it my self ?
Then it is also some fuse`s nr 11 and 20 can they be the problem?
I have noticed that the aircondition has not been on top lately either.
Well I hope for advices who can tell my garage what to do and what parts to order.
Since it takes 14 days to order parts from America , I really hope for answers that can be trusted
kind regards
Cecilie Jansson
kind regards
Cecilie Jansson
I tried your advice , but unfortunately it didnt work. Just want to tell how I did so I did it right,. I turned the key to on (I didnt start the engine, only so the lights worked), then kept the brake in and then took it to drive and then back to park. Then I took my foot of the brake pedal. And waited 1 minut. But nothing happened.
Do you have some other idea?
Kind regards
Cecilie Jansson
I have a 99 lincoln nav that I can not get power to the air compressor for the air suspension. all the fuse's are good and the relay's , including the one under the pass side of the rad support. the things that are changed out to new are air ride control box that is above the radio, the pass/side relay on the rad support, the pump is new, and the ride height sensor in the rear is new. I just need to get power to the pump in order to find out if anything else is wrong with it . thanks in advance Jay
The left rear side doesn't come on at times (it sits and rubs the tire) and truck rides like a rodeo, other times it comes up but the front right and sometimes both front sides don't come up. It seems like depending how the truck feels, either the left rear or the right front or both front don't come up.
Any insight will be greatly appreciated.
I have a 01 Navi 2WD and I have a situation with my suspension on the passenger side. My compressor works fine it comes on and off and the driver's side lift no problem, the passenger side no. I bought the shock air bag and had the mechanic replace the old one. Turn the compressor switch on, compressor kick in, however once again only the drivers side went up, the bag was not being filled with air. So I turned the compressor off again and then on again, it click in and started raising the vehicle, but the passenger side with the new bag doesn't fill.
Further to this the vehicle sensors of course are sending a message that the vehicle is not level so the compressor sends air and as a result the drive side is at the maixmum height and the passenger side living the low life.
How can this problem be corrected before opting for springs. I like the ride the bags give and this vehicle believe it or not only has 46K(+) miles.
You assistance is greatly appreciated and I look forward to your response
Justiss
Nassau, Bahamas
PS. Im selling the good Air Suspension components. My height sensor was the only thing bad. I just need a trusted suspension. email me if you have any other questions.
williamacosta26@gmail.com
As for the air leaking when parked, it is perfectly normal. The navigators air suspension is supposed to drop after a preset time (15-30 seconds), to a height that I believe they call "Trim height". It is also supposed to reinflate the suspension and raise itself when you put your gear selector in the drive position.
I believe I have the suspension service manual in PDF which helps to trouble shoot. But since it is made for service departments with the right equipment, many of the procedures are not applicable to us without the equipment.
Email me and I can try and forward it to you.
1998 lincoln navigator
4dr 4wd
5.4L 330cid V8 FI (L)
When you shut the Airride switch off in the rear of the truck, you still cannot open the solenoids. They are electrically actuated and are set to default to the closed position.
Here it is straight from the workshop manual:
The air spring solenoid:
�� allows air to enter and exit the air spring during leveling operations.
�� is electrically operated and controlled by the 4WAS module.
�� is only replaced as a unit (the air spring solenoid is serviced separately from the air spring).
Back to me:
Sometimes you will find that your Door Ajar light is messing with air suspension height levels. That's because it is a factor which determines the height.
Also, if there is a bad connection, a little elbow grease and a wire brush can help.
Hope this helps.
Anyone familiar with a temperature sensitive issue like this?
If it does not stabalize after a few trips i would have it checked. It could be just having to re-calibrate the system or you might need to replace the height sensor.
Let us know what the end result was.
I just purchased the same kit but have not installed them yet.
I had problems with my air suspension last year and it cost me about $1,300 to fix. I am starting to get the same symptoms again and am afraid that I will have to fork over another grand or so.
"hen you shut the Airride switch off in the rear of the truck, "
