Hyundai Azera Starting/Stalling Issues
I have a 06 Azera I live NY since this cold spell has hit the car will not start with the remote in the AM after sitting over night. I have taken it back to the dealer three time and they have reset the system and replace a chip in the starter but it will only work for one day then it’s back to not starting anyone have clue to why this maybe happening
Is your remote starter an original equipment item? If so, which model do you have? I have an 06 Limited with Premium Pkg. and I don't remember that being an option. You are right that it has been cold here in the NY area. Wishing for a remote starter!
Don
You input is appreciated.
The tensioner is hydraulically controlled and uses a ratchet mechanism to hold it in place when the engine is shut down ( it would otherwise retract due to loss of oil pressure ).
The teeth on some of the ratchet mechanisms wear or shear and do not hold the tensioner in extended position. This causes a rattle of the cam chain on startup until oil pressure extends the tensioner. This would explain a slight rattle for a few seconds after startup.
My Azera shakes for about four minutes only when it is cold, then it smoothes out when it warms up (or idles down). During the day, I hardly notice the engine started as some of you mentioned. I have heard of the problem with the oil reaching the mechanism which last a few second only.
How can I access the TSB?
Thank you again.
Go to the link indicated below. You can print a copy for your dealer in PDF format.
http://www.hmaservice.com/index.jsp?SSOSESSIONID=oa6tHjX4VkN3OMvBtW33DvF8
Azera is 1 of 3 Hyundai models listed with same problem.
