maybe your mic is defective? well, I hope you get it fixed
Must tell you, have never had a moon roof wind deflector. Boy, that was well worth the money! After a few minutes you can forget the roof is even open.
Got it? Enjoy the car and quiet worrying.
Trying to decide whether to act now or to wait another month or two and any thoughts would be much appreciaetd.
JSY
That was a real timetable. The tech may have had a delayand they may produce some hybrids before then. Your dealer will not know. I guarantee it even if they ask Nissan directly.
Now that gas has hit $4.00/gallon, I'm wondering whether it pays to sell the Acura and buy a hybrid. I'm especially concerned because I drive about 50 miles a day and now hear that in a year or so gas could be $8/gallon.
Looking for some feedback.
Judging the way you wrote your question, your having to make the same decision.
WHAT MAINTENANCE (THAT I COULDN'T GET FROM SOMEONE ELSE) IS REQUIRED OF A NEW ALTIMA HYBRID? IM AFRAID IM GOIING TO BE STUCK WITH A CAR, THAT I CANT HAVE SERVICED!
Thanks for your feedback!
so you've checked every dealer in the area?
That is odd. Most car manufacturers won't allow a dealer to sell a car unless they can service the vehicle. Are you sure they can sell you a hybrid model? Perhaps they just blowing smoke in your face, trying to get you to buy the normal version?
You might consider the Toyota Camry Hybrid (for a similar size), or one of the other hybrids from Honda or Ford.
I live in PA but bought mine at a dealer in New York 45 minutes away. Not really a bad drive.
I also have a slightly chemical smell when using the AC.
Any ideas?
Is it a different smell than any other car you've been in? Mostly this is due to moisture in your vents and you get to smell the funkiness as the water evaporates
The passenger side is basically two settings, hot or cold. If you set the temperature at 89 or 90 you get hot air, if you set the temperature at 60 - 88 you get cold air. On the passenger side if there is any difference in air temperature within the 60 to 88 range it cannot be more than a degree or two.
On the drivers side it is similar, but I would estimate the difference in air temperature within the 60 to 88 setting range is at most 5 to 8 degrees.
The above holds true whether in EV or ICE (or both modes). My method of measuring is the hand test. May not be the most scientific but in my wifes Avalon it can detect differences across the entire range of temperature settings
Anyone experience anything similar?
Anyone have any experience with the dealer addressing any component of the NAH HVAC? Part of me says if they try to fix it they will only screw something up!
So far everything else is good. Thanks in advance for your feedback.
The speakers on the system are great, as they use the radio ones, but outgoing voice is very garbled and almost impossible to understand what I am saying. Other people have tried it, I have called me home phone & left a message 1/2 on bluetooth and 1/2 without & retreived the message, and a world of difference.
Not sure where to go from here, the dealer made a comment to me these things are not "perfect" and should only be used in an emergency. For someone that drives 4000 miles per month and on the phone constantly, that is not a good answer.
Anyone else have any problems like I am having? I have found out that just because a phone is "bluetooth" it does not mean it is compatible in a Nissan. I guess every car manufacturer different, and word of warning to anyone out there getting a vehicle with bluetooth check with the manufacturer & be sure it will be compatible. With the Nissan blackberry's ok, but other's like Palm Pilot, etc. will not work. Believe me, I know this first hand.
I just purchased a new 08 NAH. Everything is working excellent, except for 1.
My question is on the meter on the right that shows the charging level. It never has been above 3/4 high. It has never been below 1/4 low. Has anyone ever seen there's above 3/4? Have you ever seen your meter fully charged to the top? I can't get mine to go their. I have about 800 miles now. It's running great except for this 1 item. Maybe that is the way it should be. Any input would be appreciated.
Thanks again. Been getting 34 to 38. Love It !! This is a great forum.
He took the car to the dealership and it was idling so loud that everyone in the parking turned around. The mechanics and service manager were surprised to see this happening. Apparently this has never happend before. So we have a rental car so they can see what the problem is.
Anyone have any suggestions on what the root of the problem is?
The tech said that the idle speed was too high (1200 vs. 1000). No explanation for why it would have happened after 2 weeks of flawless driving.
In any case, after the adjustment (done twice as i mentioned on another thread) all is well and the car is smooth as can be. I hope yours turns out to be as simple a fix! good luck!
Do you happen to know where to find out which phones are "approved"? The bluetooth is kind of an important factor living in Los Angeles with the new cell-phone law.
http://www.nissanusa.com/bluetooth/index.html
I will NEVER put the windows down with the key. I will ALWAYS need to "button-up" the car by closing all the windows immediately and the button on the key ought to do this.
It should be in the owner's manual.
The 12v battery powers up the electronics so that the hybrid battery can spin the engine to start it.
Jump starting is simply a matter of connecting jumper cables to the terminals, just like a regular car. Some hybrids have jump terminals in the front, with the 12v battery itself somewhere in the back of the vehicles. Other cars (like my FEH) have the battery under the hood.
If your car is new and the battery dies more than once, return it to the dealer... they replaced my battery, because it's a known issue that the 12v batteries tend to die if they sit for too long. Apparently, all the technology in the car is a drain on the 12v even when the car is off. As a result, the dealers' cars die pretty often and they have portable jumping units they carry around... I bought one on Amazon to carry in my trunk, just in case. But since they've replaced the 12v, it's been fine.
I've search the manual, but didn't find anything. Not a deal break, just annoying. Most everytime I open the door, I hear the ding ding and end up checking my lights and making sure my car is really off - they always are.
Thanks in advance.
If I open the door and hear that chime I just press the door sensor (so the car thinks you closed the door) and presto, the noise stops! It will also lock your steering wheel btw, which is normal.
K
i would worry about the battery first (which has 100k warranty), and then the voltage converters second.
you also have to figure that no car company would warranty a car only to the point where they think things will fail (it would cost them too much if even 25% of their engines failed before the warranty period was over). powertrain warranties usually go to 5 yr/60,000 mile and most engines do double that easily (100% more). the NAH has a 8 yr/100,000 mile so you would figure it's designed for at least 25% more miles than it's warrantied for, 125,000 miles.
just my logic
As far ad the meter going below 1/4, that's easy. Just sit in line at a long drive-thru line with the AC running and after a while the battery will get to the bottom of the blue range and the gas engine will kick on to run the accessories and charge the battery.
These are obviously not normal conditions. Normal driving the meter is always between 1/4-3/4.
Very interesting report. Much appreciated.
