Saturn Aura Real World MPG
Regards:
Oldengineer
My DIC was within 0.5 mpg of the calculated mileage. Which one was wrong? - dunno, maybe both!
Long road trips, yes MPG on computer goto 22-23.
Can actually see MPG drop 16.0 ... 15.9 ... 15.8 in stop-n-go traffic. Again, I'm conscientiously light on the pedal.
Is there a "stingy" mode on the chip that controls fuel/air mixture?
I continued to see improvements in MPG up through 10Kmiles so next time you take the trip, you might see another 1to 1.5 MPG improvement. I did.
I am now consistently getting 29 on the Interstates that are pretty level. I have gotten 32 mpg@68-70mph on desert interstate with not much more that 1000 ft elevation changes.
Definitely very satisfied with the mpg / performance.
BTW I keep the LS2's @ 37/35 psi F/R which really helps the cornering and mpg.
Needless to say, I was very pleased with the mileage under those unfavorable conditions. On the next leg of the trip (57 miles) using freeways only and traveling 60 - 65 MPH, I averaged 33.6 MPH. I checked my speedometer using my GPS and it was 237.9 miles (car) and 237.2 (GPS). When I hand calculated my mileage, I found that the car's computer over estimated MPG by 3% or about 1 mph too high. Still happy with the results.
On the return trip, I averaged 33.5 MPG on the expressway using the A/C this time, but saw the MPG fall off to 27.3 when I hit two lane highways, traffic and traffic lights (before 3% error reduction).
I expect to get 34 MPG on level uncongested highways and accept that hills, traffic and lights must reduce this figure commensurate with the distance travelled under less favorable conditions.
By comparison, my 2000 Chevy Venture van with a 3.4 - 4spd automatic, rarely hit 30 MPG on the trip computer which always read 5% high or about 1.5 MPG less true mileage. The difference was due to weight, aerodynamics and the engine/transmission efficiencies.
When I feel that my MPG levels off, meaning that my engine is fully broken in, I will switch to synthetic oil to maybe get even better mileage. If you use synthetic too soon, you may not allow the engine to break in sufficiently.
Oh yea, You'll need to pump up those tires to at least 35front 34rear to get best mileage. 30 is like running on a flat as far as I am concerned. I run 37 front 35 rear when loaded and on a trip. I get 30+ average on the highway at 80 MPH with my 3.6L XR
US EPA ratings can be found at :http://www.fueleconomy.gov/feg/findacar.htm
I apologize for your frustrations. I hope this information is beneficial to you:
The best fuel economy possible is the direct result of proper maintenance and good driving habits. Listed below are GM's recommendations to achieve the best mileage possible. The first group are things to consider for your vehicle, while the second are tips relating to your driving habits. One of the major contributors to poor fuel economy are under inflated tires. Tires low with pressure create drag that the vehicle’s powertrain must overcome, wasting dollars in fuel. Always keep your tires inflated to the proper pressure as shown on the vehicle placard. This not only serves to increase gas mileage but cuts down on tire wear, further decreasing your costs per mile.A vehicle that has a dirty air filter can’t efficiently draw air into the engine. This restriction forces the engine to expend energy to "breathe" wasting fuel in the process. Change recommendations are found in your vehicle Owner’s Manual. Always use the proper viscosity oil in your engine. Oil that has a higher than required viscosity will create more drag on the internal components of the engine causing more work for it, especially when cold. Each Owner’s Manual contains information on the proper type of oil for your vehicle. Look for the "starburst" symbol on the front of the bottle, and the SM rating on the API circle on the back label. If you are in doubt, stop by your dealer for an oil change, and any other services required. Most current GM vehicles are equipped with oil life monitors to further assist on the "when" to change your oil. (aveo/Wave/Optra/Epica currently do not have oil life monitors).
Note: GM Vehicles DO NOT require additional engine oil additives. Some additives may cause harmful effects to the internal seals and additionally void the terms of your vehicles New Car Warranty. Purchasing higher than required octane fuel is a waste of money. Using higher octane fuels in a vehicle that only required regular unleaded fuel will neither increase performance nor improve gas mileage. In all cases refer to your owner’s manual and ONLY use the octane rated fuel recommended for your vehicle. Even though current GM vehicles have 100,000 mi (160,000 km) service intervals for spark plugs if your vehicle is at that point in its life, have the spark plugs changed to assure proper running and continued efficient, trouble free operation. Avoid quick/full throttle acceleration from a standstill in town and high cruising speeds on the interstates. While the optimum MPG for highway cruising speed varies from vehicle to vehicle, faster is almost always worse. If your vehicle is equipped with a Driver Information Center that displays Instant Fuel Economy, select that readout and vary your cruising speed while on the highway. The display will change continuously with uphill and downhill sections but you should quickly be able to identify on level ground the speed range that your vehicle does the best in. Avoid leaving unnecessary items in your trunk. It takes power to move increased weight and that means more gasoline consumption and reduced performance. While the change may be slight, multiplied by thousands of miles, it all adds up. Your vehicle uses much more fuel when the engine is cold. This is especially true in the winter months when the engine will take the longest to warm up. Combine errands or trips so that the vehicle only needs to warm up once to encompass many different stops.
Feel free to email me with any questions comments or concerns. Have a great weekend!
Christina
GM Customer Service
