Acura TL Electrical System Problems
thku4grace
Member Posts: 1
in Acura
I have an 1996 Acura TL 3.2. I have electrical system problem. When I first start my car in the morning it usually starts up normally. However, after I have run the car for 30 minutes or so if I stop and restart my car, I often have problems. It doesn't start slowly like a run down battery might do but instead I get nothing. No turnover at all. I can try it numerous times without the car engaging at all. But if I wait for the car to cool down from normal operating temperature, after 30 minutes or so, it will start up without any problem. Once again, its not a slow start, its no engagement or a normal start.
I have already checked the battery and its fine and I've replaced the starter with only a small change in vehicle behavior. Strangely enough, a few months ago my car would experience this same type of starter problem but only when it had sat overnight. No slow start, just nothing. But once I would get it started I could stop and restart my car as often as I wanted all day without any problem. I'm perplexed. Would love to hear from someone who understands this problem.
Replacing the battery worked for me (this was done under warranty, so it didn't cost me anything, but time). Anyway, the problem has not returned and it's been about 8 mos.
Hope this is helpful.
I will not buy another Acura... these cars have very hard problems to fix.
I think original assembly was fine after inspecting it for cracks, holes. Moisture may have entered from back of headlight assembly from bulb insert location which is usually sealed by gasket after reinserting light. Acura, Stanley (who made light assembly) and dealer told me to take a hike. Any suggestions?
Andre Libert
Do the lights still work? If so, why not just leave it as is?
The real issue is whether they had to use a new assembly at all? If they had just installed the lights which were burned out, and made sure the seals were tight, this would not have occurred.
Moira
Acura replaced the battery and the cables attahed to teh battery or so they say. I know they at least looked at the battery because they forgot to reinstall the cover plate.
The problem went away for a year, but is now back in full swing.
This happened from day one of owning the car with zero miles on it.
Check the fuses all OK, balbs are OK. Normaly after i release the parking brake, the light came on and the sign DSL came off. Now the DSL is on all the time and no any light on the balbs.
Please, if any body know what is that or had similar experience, please lets me know. Thanks.
I asked about them about replacing the battery with a larger capacity battery and they said they have to use the battery that Acura specifies which makes sense but the entire thing seems dumb.
The first time it happened I had left the radio on in the garage for an extended period. The second time it was only for less than 10 minutes and this last time I was hooking up a Bluetooth phone device in less than 5 minutes. This last time there was a starnge clicking sound and I knew something was wrong and then it wouldn't start.
There is no condensation and the HID bulbs were in place for six months before intermittent outages. High beams work fine, even when one low beam is out.
I appreciate your thoughts.
Brian
So it seems a week or so should be no problem, but anything over 1 month and I'll be on thin ice. I asked the BCAA guy who came to jump start it, if it is normal for a healthy battery to drain in a month, and he said it's possible due to all the electronic accessories and stuff in modern cars that will continue to drain the battery even after the ignition is shut off.
Now I know I don't even need to crank the ignition to know that it's dead. The doors wouldn't unlock with the remote, and the alarm blinking LED on top of the door would be off.
Any suggestions?
My 05 Acura TL battery was dying after 4 days of non-use. Also, when I selected the HFL on the computer, it continually said "Booting." When I felt the map light console at the very front left corner by the rear view mirror, it would get very hot. So, it seems that the HFL malfunction was the culprit for draining the battery.
The replacement procedure can be found in this TSB:
http://www.acuraworld.com/tsb/3gTL/b05-020.pdf
I pried the sunroof switch off using a small eyeglasses screwdriver, it was quite easy. Then, I reached into the hole on the rear of the car side and pulled down. To remove the HFL cover, you simply have to remove four bolts using a rachet.
I disconnected the HFL plug. I believe this should fix the problem, since there will no longer be any power going to it. If not, the unit will likely have to be replaced. It can be found for around $399 online and should be an easy do it yourself.
If have this problem, but absolutely can't live without the HFL, it can be found for around $399 online and should be an easy do it yourself. The part number is
77120-SEP-A01ZA. Below is a link where it can be purchased. Best of luck!
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=TL&- catcgry2=2004&catcgry3=4DR+BASE+NAVIGATION&catcgry4=KA5AT&catcgry5=INSTRUMENT%2B- PANEL&ListAll=All&vinsrch=no
ACURA should own up to this error and stop costing people hundreds of dollars and just replace there HFL (We already paid $400 in total which is what the HFL replacements costs)! In addition to the time wasted jump starting the Car!!!!
If the battery dies again I will just follow the manual and remove the HFL! this is disgusting
How did it go? sounds like it should be a good option.
i heard a motor running after the engine was shut off... i told the service people... a relay in the aC WASN'T SHUTTING OFF... the running motor drained the battery... many batteries...
after they changed the relay.. all was good.
for battery issues... listen for motors not shutting off... ask them to check the ac relays...
good luck
w
