Chevy Colorado and GMC Canyon Electrical Problems
1235714
    hcoombshcoombs Member Posts: 2
    TBunch: I have had the same problem with my 2004 Colorado. It occurred 3 times in the 5 years I have owned it. In the manual, under "passlock", it states that you can wait 10 minutes and try to start it again and this works for me. However, I would like to find an answer to the problem. Have you spoken to or written to anyone at Chevrolet to get an answer? I did take it to my dealership 6 mos ago and they put it on the analyzer and then told me I should replace the ignition switch module to the tune of $400+. I chose not to do that. The manual also cautions you not to leave the starter engaged once it starts. I have noticed at the times this happened that the starter seemed to stay engaged even though I released the switch key. This may have something to do with the passlock disabling the fuel system, which is what it does. HCoombs
    tbunchtbunch Member Posts: 3
    what exactly is the passlock? i dont have power locks or any type of alarm?, and yes sometimes it seems as if it still wants to start even after i turn the key back
    slr777slr777 Member Posts: 7
    I was waiting for the weather to get better as this truck is my only transportation I thought I would ride my harley while I get my truck fixed. I told my wife to get it set up to take the truck in with in the next 2 weeks. On 4-7-09 it was a warm afternoon and I stop and got gas got back in the truck and went to roll down the window and it worked I sat at the stop light rolling drivers side window up and down 10 times like a kid. When I got home and and used the key fob to lock and un lock everything is working????? Has not worked since Nov. Now all the sudden starts working I am not going to mess woith taking it back into the dealer I am just going to wait until I change battery or what ever. Dealers act like they never heard of this and in 2 minutes I can google and find many who have had the same symptoms. Just glad it started working.
    sorry little out of context but this is a follow up to my Nov 25-08 posts
    flacondoflacondo Member Posts: 9
    I posted this same problem, last year. When the weather was warm, everything worked. When the weather was cold, the power door locks and driver's power window would NOT work. Yours may continue to work all Summer, but when Winter returns, the problem will reappear. The only permanent solution is to replace the driver's side power window/door lock switch assembly. If not in warranty, it's very expensive. This is certainly a frequent problem by many Colorado and Canyon owners, but GM won't acknowledge.
    Yes I re call reading that. I am keeping print outs of all I find on this problem. Is there any programing involved with the driver's side power window/door lock switch assembly? its not clear to me I think I read something about that?
    NO programing required. It's a very easy swap-out, so if you have to pay for replacement, I suggest installing yourself and saving the labor cost.
    Thank you for the information.
    tbunch: in my 2004 Colorado Owners Manual, Pg 2-17, it implies that all of the Colorado's are equipped with the passlock theft deterent system. the system enables fuel to the engine if the ignition lock cylinder is turned with a valid key.
    If a wrong key or the cylinder lock is tampered with, the fuel system is disabled. It also states 'remember to release the key from START as soon as the engine starts'.
    (i still have a feeling that possibly the starter solenoid (sp?) or something in the start circuit is causing the starter to stay engaged too long. I believe that this will enact the passlock.) HCoombs
    snaproll1snaproll1 Member Posts: 88
    I think I started this thread way back when or at least this is where I posted the window/lock/fob/starting/battery problem a year and a half ago.
    I've been following the thread since then. I've seen posts to the effect that it's the door module on the driver's side and bad grounds, but I really don't think that is the issue. When I started having the problem, I found a few posts on the net with a bunch of silly stuff people were hearing from their dealers. Things like running both more than one window at the same time was "the" problem, yada, yada.
    Basically a lot of folks were saying that their dealer had "never heard of the problem before", yet I found several posts of the exact same symptoms. I found if I removed the door module connector and plugged it back in, everything would be fine for a few days. My dealer said that was absolutely crazy, at best it was resetting something in my BCM that 'fixed' the problem temporarily. My dealer said, "Never saw this problem before, and whatever you read on those internet posts are garbage..." The said the BCM tested bad, that would fix the problem for sure... and the problem happened the next day, truck wouldn't start, wouldn't turn over, dead battery. So they took it back in, farted around with it again and said the two and a half year old battery was the problem and... "Oh by they way, there was a service bulletin on your fuse block, which yours was burned... and we replaced that for free!"
    Uh-huh.
    That was about two years ago and I haven't have a problem with it again. Here's what I assumed happened. There is some defect in the fuseblock that fried the BCM, battery and possibly the heater blower motor. The day after they got done 'testing' all the stuff the blower resistor fried as well, "just coinincidence" according to them, (fried the very NEXT day???). So I think this improperly designed fuse block shorts out and causes all kinds of electrical problems with the truck. Since I had it replaced, (and all stuff that mysteriously fried in the space of about a week), I haven't had a problem since.
    Well, except for the head replacement because of the soft valve seats. Luckily they covered that with no issues and the truck has been running ok since. I have 99K miles on it and it's a 2005. One other weird thing, I don't tow much or often, but I've had the U-Joints in the drivetrain go bad. I replaced one set a year ago and they're sounding like their going again, a metalic 'clink' like a pipe rattling every now and then. I'm still getting about 20MPG with the truck, which is why I bought it, but I'll tell ya, this is the last time I "buy American" until these bailout buddies start building reliable vehicles or honestly start backing them once again.
    gthfishgthfish Member Posts: 8
    Thanks brokenail for the information, really appreciate it..gary
    AlennxAlennx Member Posts: 20
    SOLVED!
    I rented a Trailblazer for a week while out of State, same kit setup with phone, radio and batteries charging from my inverter, this vehicle is pretty much the same as the Colorado but has a voltmeter in it showing 14V at idle in the rental place.
    So I'm watching this thing and by day three, the engine is starting to idle up and down and the voltmeter is showing about 12V at idle, but no engine light yet... which means all my kit is drawing more wattage than the alternator is making at idle and the battery is now sweating the load... so I quit plugging in my laptop during idle and, 24 hours later, idle is normal.
    I get home and back in my Colorado, which still has the engine light on and idles between 500 and 700 every two seconds all day. I plug everything but my laptop in and a couple of days later, the idle levels out at 700 and the light goes out! That was several days ago.
    The engine light came back on briefly the other night when I was idling with my headlights on for two hours, but then went out on the way home.
    My belt is squeeling when it gets wet. I think this means I need a new belt? Or it means the alternator is so fried it's creating too much friction...
    Either way, if I want to power my laptop in my truck for more than ten minutes, I have to get a much bigger alternator installed. One that will output 100A+ at idle.
    On another note, I pulled the resistor pack for the blower in the passenger footwell and, wouldn't you know it, the connector on the red wire is all burned and melted. I think there's a Technical Oops Sheet on that so I might find a Chevy dealer who will fix it. JFYI, with the resistor pack disconnected, the blower still works on 4 and the heater, inside/outside button and A/C all work fine.
    My 2005 Colorado just turned 80K and now runs like a dream again. :shades:
    russ95russ95 Member Posts: 16
    My 2004 Canyon (3.5L 5MT 2WD) has had a continuing series of small electrical problems since new. These have included no start, blower motor, blower resistor, blower loom (2X), & intermittent rough idle. The truck now has 111,000 miles and finally runs right. The fix was simple, just put a real battery in it. My OEM style group 86-7YR battery died at the bottom of a wilderness lake boat ramp. I had to remove the upper & lower portions of the battery box to fit an old deep cycle battery from my boat to get back out of the mountains.
    I chose to eliminate the battery box & vent hose and select a larger & stronger battery more suited for truck use. I installed a Costco/Kirkland #4 battery which is rated @ 1,000CA & 850CCA. This battery also has a 36Mo/100Mo warrantee & only costs $80.00. The battery is snug but fits into the available space, cables, and the stock battery retainer system.
    The bottom line is that EVERYTHING works better especially the engine which has never run this sweet. I suspect the combination of a minimal battery and a low capacity alternator result in excessive voltage drop and thus high amperage draws everywhere. My next step will be an alternator upgrade. This is a cheap way to stop buying electric parts. I also expect to see an improvement mileage & may get to 30mpg yet!
    Russ
    On the previous post (#216) I neglected to provide the actual battery identification. It is a 850CCA, GROUP65, Costco item #12866, $80.00, & also called a fitment #4. The width is a really tight fit in the stock retainers & I'm not sure that other brands of group 65 batteries will fit the same. Also late models of Canyon & Colorado both 4 & 5 Cyl have upgraded from 100A to 125A alternators which will probably be an easy & worthwhile conversion on the older trucks.
    Russ
    merch3merch3 Member Posts: 1
    I have a 2004 chevy colorado extended cab and lately my drivers side window has been acting funny, sometimes working just fine and sometimes it just stops for a bout 15 seconds, then will start working just fine again. the locks work, and the mirrors work.
    and then yesterday i got in my truck, put both windows down, and drove about 5 miles. when i parked and tried to put the passenger side window up it didn't budge and so i waited hoping it was just the same problem as the drivers side window but nope... it wouldn't move. so i had someone pull up on it while i pressed the button and it went up just fine, then it worked fine for about 5 minutes then got stuck again. i don't know what is going on. but this morning it worked fine again for a couple seconds then just froze up again. i can hear it click on the passenger side door like it receiving the power its just not moving. ive been reading a lot of posts with people having electrical problems, i don't know if i should hope its electrical or the motors are going out. i don't know which is cheaper. any response is welcome.
    HopeGMCHopeGMC Member Posts: 7
    I had the same problem. Look at my entry #154. Hope that thelps.
    Check the connection for the blower motor. Passanger side. Two screws. The problem is that the connectors heat up and loose their connections. If you can take the connector apart - one wire at a time and clean them up and put more tention on the prong, that should take care of it. I would try that before replacing the resistor board
    grnbeltwarriorgrnbeltwarrior Member Posts: 1
    Just found this after having issues with my 04 Colorado for a number of years.
    First incident was this: after shopping came out to my trucks wipers going and when I unlocked the door, the blower was on inside. This while the keys were in my pocket. Dealer replaced the BCM. Under warranty.
    Fine for 30,000 miles.
    Next problem: Go out to the truck, nothing works. Try to start, only thing that came on was the service engine icon on the instrument cluster. Nothing else. Dealer replaced the BCM again. $700 bucks gone.
    3 weeks later,
    Driving the truck, filled up gas. Blower on while the keys in my pocket. While driving the truck to the dealer, the wipers turn on then stop mid way, the horn honks twice, the instrument cluster goes completely black then displays the odometer reading as 999999. Blower does not work, locks work, but when you shift out of park or drive it used to lock and unlock the doors, it does not do that anymore. Replaced the BCM again. They are going to replace the instrument cluster once they get it in. So far the dealers techs are dumbfounded on how this is going.
    Any other ideas?
    I am going to ask them to look at the fuse block. Just seems to be a lot of electrical issues with this thing.
    paul139paul139 Member Posts: 2
    OK, so I bought a loaded 2004 4x4 crew cab colorado z-71 for my daughter, past owner told me had just put in a new battery, after one month all of the problems listed in this post with the exception of the blower began happening to her truck. So, I began to disconnect and reconnect every harness connector to try and trouble shoot this issue. FINALLY, last night as the no start no power no dash passlock battery good condition occurred once again my neighbor watched the dash while I wiggled wires yet again. and fixed it!!!!!!!!. From the battery trace the small ground wire to the inner fender, remove the bolt, remove the small retainer that holds the eye on the bolt. remove the eye connector, place a "star" washer on the bolt, reinstall the eye, place another star washer on the bolt and reinstall. Problem is resolved. no issues, door locks, lights, dash, pass lock all ok now :)
    jsouthjsouth Member Posts: 13
    I have a 2004 Ext. cab 4 wheel drive I5 Chevy truck and the problem I have is my check engine light has come on and will not go off even when you take the key out of the ign. The Chevrolet dealer checked for a code but there is none. HELP!!!
    The 2004 Chevy Colorado is actually "Decepticon" technology, designed to create confusion and distraction amongst the human population, meanwhile, The Fallen wage their endless war against the "Autobots."
    Seems as likely an explanation as any you'll get from the Dealership. :lemon:
    mrwebmanmrwebman Member Posts: 15
    Has anyone replaced their own Body Control Module in this truck?
    Mine went out once under warranty and now it has apparently gone out again. Several things that it controls no longer work like fog lights, door lights, door lock from remote only, cargo light, etc. Got the schematic and traced it back to the BCM... ouch. No warranty this time so I'd like to do it myself.
    It's easy to get to - 5 minute job as far as physically doing it but I don't know if there is any programming needed and I don't know where to get it or what the part number would be. I couldn't find it on rockauto or the gm parts site. My truck is the LS with power door locks and windows, etc. and I only seen the one without all of the power options... The one listed on amazon.com is about $138 but I don't know the correct part number for mine so I'm not sure it will work.
    Any advice out there?
    Dennis
    yes read #222 ithink from me paul139, its cheap (less than a dollar) takes 10 minutes and I will bet takes care of the issue. A bad connection on the ground from the battery to the body causes all sorts of issues. In most cases now when you select a function the push button sends a signal to the bcm and the bcm fires the function A bad body ground messes with everything including false codes and BCM faults. Good luck :D
    kirk11kirk11 Member Posts: 2
    I am new to this forum but since I have been reading the posts I have hope for my 2004 3.5L ext cab 4x4 pickup. I had electrical issues with radio not shutting off when the drivers door is open. The door lock chime does not work when the lock button is pushed and door is open. I took the vehicle in to the deal who claims the problem was in the drivers door wire harness and it was fixed. I presently have an Air bag light on all the time so I took the back door drivers side apart last night to trace out the wires. The black tape job that was around the wires was loose, I found one expose wire inside the door (I taped it). Where the wire harness boot meets the door frame was a mess. at the connector in the bulkhead there where chaffed wires and the connector looked stressed. I taped that all up and guess what I now have my original electrical problems (radio will not shut off when door is open, and door lock chime does not work), I think that the may be a cold solder joint ( work done by the dealer) and/or the connector at the door bulkhead has issues. The airbag light is still on, it is another problem!
    Thanks for the tip but it didn't work in my case but I can see where it would be important to do. As in your case, there was paint under the ground terminal. Of course, paint is an insulator and you really don't want a ground to insulated.
    Anyhow, because I have so many things that are not working I highly suspect the BCM. I stopped in at the local Chevrolet dealer yesterday and asked them what the cost would be and their answer was $265 plus tax plus installation labor plus programming fees plus shop towels plus EPA fluids fees plus etc, etc, etc. Might be able to get out the door at about $1000.
    I was there at the dealer to have the front end aligned and tires rotated and they said I was number 3 inline and that I would have to leave their building because I wasn't allowed to hang around in their waiting room but one hour max. Must be a new government regulation now that GM is owned by US. If I was made of money I would have set the car on fire right there in their lot - I was so mad. I bite my tongue because they said they'd have their courtesy car take me back to work. Guess what - after an hour and a half I had to call someone from work to come and get me because their courtesy person never showed up. I'm expecting the call from the FBI right now about being in their waiting room over an hour.
    IS THIS THE REASON WHY MOST PEOPLE BUY FOREIGN?????
    Sorry... I still need an answer to my original question if anyone knows... what is the correct part number for my BCM and where can I get it programmed?
    I was able to take off work early today and got home to work on my colorado. This is a followup on #227 by the way. I suspected a bad solder joint at the drivers rear door electrical bulkhead (where the rubber thingy meets the rear door frame bulkhead) moved the rubber back to expose the four wire connector. Because I had taped it throughly the pressure broke the cold and corroding solder joint. So I made a new splice cleaned the wires, slipped on a piece of heat shrink, flux and soldered. I now have my radio off when the door opens and when the key is in the ignition and the door is open the chime activates. :) Hurray for small miracles that saved me a trip to the dealer.
    I still have an Air Bag light on after startup. :confuse:
    Later
    leadfoot4leadfoot4 Member Posts: 593
    After reading "russ 95"s mention of the upgraded alternator, I looked into that for my 2005 Canyon 4x4, as it's primarily driven in winter, at slow speeds with lights and heater blower all running at the same time.
    I did an internet search, and found a Delphi alternator supplier on the west coast that provided me with a new 125A delphi alternator for $150. This included a smaller OD drive pulley, which will speed up the RPM of the alternator, and boost output at slower speeds, which I see a lot of, when the roads are snowy and slippery.
    I did the swap-out last weekend, and it was by no means a picnic. I have the 5 cyl. engine, and everything is "shoehorned" into place, there's VERY little room to work. I purchased a Haynes repair manual, which said to remove the lower inner fender panel for fastener access, and the engine lift bracket, to allow the alternator to come out. HAH!!!!!
    I wound up disconnecting the fuel supply/return lines, removing the battery and battery box, as well as loosening and slightly lifting the main fuse box in the LH fender well. Then it was a series of twists and contortions, before I was able to remove the unit. However, it allowed me to see all of the corrosion that had developed on the electrical connections over 4 years of driving in a damp, winter environment. A little Scotch-Brite cleaned everything up, and some dielectric grease on the connections will hopefully keep me trucking!
    tyrod_emmonstyrod_emmons Member Posts: 2
    ok my doors locks are acting funny, by this i mean, when i hit unlock on the fob the only one that unlocks is the driver door, same for locking it, when im in the truck and i hit the button to lock or unlock and the driver door is the only door that reacts, now here is what is strange, if i hit lock or unlock on the passenger door, the driver door is once again the only door to react none of the other doors do anything. i am having no window problem on any of the doors
    Although I haven't had that problem with my Canyon, I had/have a similar problem with my Corvette. If the systems are similar, there's a circuit board that has most likely 4 relays that control the lock/unlock functions. If any/all of those relays go bad, the locks won't function electrically. To replace the entire circuit board, at least through the dealer, is about $400, from what I've heard.
    I found a write-up in the CorvetteForum that explained where to source the relays, as well as how to replace them. I took the circuit board out of my Corvette's door and replaced the one bad relay, as the driver's door wouldn't lock from the fob's signal. After replacing it, I was good for a few weeks, until one of the other relays failed, and now it won't unlock from the fob.
    That was last summer, and I hate to admit it, but I just haven't had the time to take the door apart again, and get in there again. It's annoying, bu not a show-stopper.....
    adecadec Member Posts: 1
    I have a 2006 gmc canyon 4x4 with 47k miles on it. I have had nothing but problems with it like at first the abs light would come on and the brakes would make a terrible grinding noise, so the dealership took it back and had to replace the hubs took them like three weeks. now i bought the car new shouldn't have these problems right away. So finally they fixed that and then my check engine light would come on almost every 1500 miles after my 30k mark. first it was a fuel cap then an evap problem in the vacuum nd both times they smoked it and found leaks. and now it has come on again and i have to take it back in. The whole ordeal has just discussed me and it is just nickle and dimming me two, three hundred at a time. does any one know what to do or has had these same problems. Or what i can say to a dealer to make it better. thanks.
    Hi tyrod_emmons,
    Thanks for the tip but I've already removed the board in the door and replaced both relays. It didn't get better or worse - stayed the same. I have the schematic so I looked for the signal from BCM to the relay board in the door but the signal never gets to the board to tell the door to unlock. For instance, when you press the key fob unlock button, the lights flash and the door should unlock but that unlock signal never gets to the board in the door to tell it to unlock. When I press the switch in the door to unlock the doors it all works perfectly.
    I'm missing other signals from the BCM too. My fog lamps don't work and I checked the relay under the hood and it is not getting the turn on signal from the BCM. My lights in the cab won't turn on when the doors open - again, missing signal from the BCM. Removing the key should unlock the doors - again BCM. The bed light won't work - missing signal from BCM. My radio looses time too, randomly. That one is hard to trace because it could be the BCM or the radio itself. It has done that since new but the dealer wouldn't fix it because they couldn't duplicate it.
    As far as I can tell, the BCM and the A/C fan resistor assembly and harness are very weak points on this vehicle. My BCM was replaced once under warranty as was a lot of other things. It would be easy to say that I should have bought a foreign vehicle but I would have paid over $10K more for the same thing and I couldn't justify it. Even if I have to pay some out of pocket expenses, I've still not come close to paying the extra $10,000. Besides, it's really fun to drive and gets good gas mileage for a truck. By the way, why $10K? Because I used GM bucks and got lots of discounts that Toyota wouldn't even talk to me about.
    Cheers.
    jaybob3jaybob3 Member Posts: 1
    2005 Colorado: passenger side window works some times, some times not.
    Doesn't matter if using driver side control of passenger control. If window is
    pulled up or pushed down, it works for a while and then stops again. Took
    door panel off and lubed moving parts and window channels. No help. Anyone
    with same problem?
    mommy6mommy6 Member Posts: 1
    I have a 2008 Chevy Colorado. What kind f maintenance should be preformed by 54,000 miles other than oil change??
    I am a single mom of 3 & I have no clue!
    I have not done any kind of maintenance other that Oil Changes (when the light comes on).
    Now...I know my vehicle & it just doesnt seem ok.
    The gears are not catching on right!
    WHAT SHOULD I DO! HELP!
    Remember..iTS NEVER HAD NOTHING REPLACED OTHER THAN OIL!!
    Thank You SOOO much! :confuse:
    dmathews3dmathews3 Member Posts: 1,739
    You could have sat down and read and reread the owners manual so you wouldn't have to ask this question as you would know what is needed to be done. Also waiting till the oil light comes on in most peoples opinion is waiting till the oil has outlived it usefulness. And hopefully the oil light you are talking about is one that means it is time/past time to change the oil and not the one that comes on when the oil gets to low. If that is the case you are on borrowed time and have been asking for trouble. SO GET OUT THE BOOKS AND READ THEM, then find a trustworthy Chevy dealer had have them go through it and give you an estimate to bring it back to 100%
    roger9999roger9999 Member Posts: 1
    I just changed my battery on my 2005 GMC Canyon. Everything works perfectly except when I unlock the truck using the keyless remote, the horn beeps three times. It never did this before. Has anyone else experienced this problem? I tried disconnecting the battery and let it sit for 30 minutes. I tried removing the fuses for the power lock and horn. Nothing seems to work.
    My blinker on the drivers side will not work. I replaced the bulb and checked the fuse for both sides, can someone help with this?
    farmer90farmer90 Member Posts: 1
    My daughter has an '04 Colorado. She says the dash lights and radio goes haywire and sometimes goes blank. When this happens I will disconnect the positive battery terminal and this seems to clear the problem for awhile. Just replaced the battery and it was about to explode from being swollen. It was also very hot to touch. Parts house had never seen a battery in this kind of shape. What could be causing this problem and could it be related to the battery problem?
    I suppose it could be. Being 5 and almost 6 years old I'd go through and clean all the ground terminals on the truck as I think that has been a problem with Colorado along with the wire harness for the door windows/locks etc.
    I had a battery taken out of my truck with a special battery grip because it was too hot to touch. I had the engine light on and off, the tadio lost half it's button lights, etc. This was the third battery in two years and started a long search for the cause. I then bought a Yellow Optima battery, which is a gel-type battery and have not had a problem with the battery since.
    Things to consider:
    1. Is the vehicle spending more than 5% of the time driving on unpaved roads? This can slosh a 'wet battery' around and mess it up. Standard car batteries are designed for flat surfaces, slow corners, easy driving. Is the vehicle being stored in freezing conditions? This is also an issue for standard batteries.
    2. Is the vehicle charging the battery adequately? You can test this easily by turning the engine on and putting a $10 Tester on Vdc across the terminals of the battery. You should be seeing 13.8V or higher at idle, which will rise to 14.3V or more at 1500rpm.
    3. Run the vehicle around for 10 miles and then turn it off. Check the Vdc across the battery again and, if it's below 12V, The battery is acting a resistor and will be getting hot as the alternator attempts to force charge into it. Buy a 'Gel battery' or even a 'Dry battery', they cost a little more but they are plenty powerful and handle adverse conditions much better.
    Make sure the idle speed is about 650 for the i5 engine. if not, the first thing to do is get a $3 can of "Gumout" Throttle Body cleaner (do not use anything else), remove the ari hose between the filter box and the vacuum box, you should be able to look through the vacuum box and see the throttle plate. Spray it liberally all over for a count of three, turn the engine over (you may have to replace the air hose because of the MAF sensor) then spray it again. Refit the hose. Fire it up and you should see a noticeably improvement at idle and under acceleration. This has a direct effect on the charging system as the alternator output at idle may be too low at 500rpm.
    Good luck!
    mikeyrmikeyr Member Posts: 2
    Tyrod,
    Have you solved this problem? I am having the same issue. Looking at wiring schematics, there is a gray wire that is spliced off the gray drivers door wire, and it splits off to the remaining 3 locks. I'm wondering if there is something wrong with this connection. Otherwise it is probably the BCM and replacing doesn't appear to be cheap, and I have no clue if it needs to be reprogrammed or not, because replacing it would be easy enough. I could be out to lunch, I can't say I've done much with the wiring of a truck!
    steve819steve819 Member Posts: 3
    RU saying that the fuse was bad even though it was good? Here's my problem and it has been noted before. I have a ground somewhere on the positive side of my electrical system. It drains the battery in about 2 days. It blows no fuses and melts no wires. Here was my analysis attempt. I charged the battery and pulled the red lead off. I put a meter in line between the positive post and the red lead and sure enough it reads voltage (it shouldn't of course but that indicates a ground.) I then pulled the cover off the fuse box. I pulled every fuse and relay, one at a time. The voltage on the meter never dropped. How the heck can that happen? Isn't every circuit fused? But now that you mentioned the 100 amp mega fuse at the entrance to the fuse box it makes me wonder. my mega fuse is good or at least it reads continuity.
    Hey Webman,
    Not sure if you got your part number, but I believe it is GM PART # 25779767. I don't believe you need to program it, but am not sure and would like to know that myself. I can send you a link to a form were a number of people have bought and replaced it.
    steve263steve263 Member Posts: 1
    :shades: Hello single mom dont listen to the guy with a chip on his shoulder with the last reply. The colorado does not come with a book its a dvd. But anyway just have all the fluids changed trany. Flush the radiator and you can but dont need to have the transfer case oil changed. The oil change should be every 3000 miles you also can go with the 5000 mile oil. If you are really bad about changing the oil use 50/50 half sinthedic oil. Its a better oil last longer and does not break down as fast. Go to a oil change place like jiffy lube and thy will put a sticker in the window so you will know when to change the oil again. Hope this helped. steve
    sddave1sddave1 Member Posts: 1
    I have an 04 colorado and the wipers will not shut off. I am thinking there is a wiper module or something that runs them that needs to be replaced but I cannot find it. Any help would be greatly appreciated.
    ndeprattondepratto Member Posts: 1
    hi i have a 2005 canyon i was driving along and i put my charger in the auxillary power outlet, then all of a sudden my turn signals stopped working as well as my forward high beams, the light for the 4 way, and the light for the heater controls. somtimes when i pull back on the high beams everything will come back and if i plugg something in it will go off again and sometimes even when i just start the truck up after it is off this happens, any insite?
    gbohegbohe Member Posts: 1
    My 2005 chevy colorado started idling rough and burning alot of gas, after I hit a deep pot hole driving about 8mph. Will not stay running when I first start it in the morning unless you constantly mash the gas pedal. I took it to Auto Zone they hook it up to a diagnostic reader, it showed 3 different code numbers all having something to do with a vacuum leak. I have 88000 miles on the truck warranty ran out how do I find the leak.
    blue021blue021 Member Posts: 1
    I have a 2008 GMC Canyon SLT crew cab 4wd, and I have exactly the same problem you described. I have no idea as to a fix, sorry. Maybe as we add to this web site someone will take note. Two 2008 trucks doing the exact same thing as this cannot be a fluke.
    turkeyhunterturkeyhunter Member Posts: 1
    Had the same problem with a 2004 Colorado. Here is how to fix it. Pull the bulb out of the socket and take a small file ( I used my multi-tools smallest screw driver blade) and scrape the carbon build up off of the connectors inside the socket. You may also have to pry out the wire on the bulb socket about a 16th of an inch. I have to do this about two or three times a year.
    jdwoodjdwood Member Posts: 2
    I went out to my truck today to find the battery dead, after realizing the interior light wouldn't shut off after closing the door. I charged up the battery and started the truck only to find the DIC saying that the doors were ajar. I ran around the truck shutting every door, I have an extended cab and still the message on the DIC won't disappear and the interior light won't shut off. Any suggestions or ideas on what could be causing this? I
    Let me ask the dumb question first. Do you have the interior light switch turned on and you are just thinking it has something to do with the doors? Wouldn't be the first time so double check the light switch to make sure it is in the off position.
