Are Ford Explorers Junk?
writerhopeful
Member Posts: 6
in Ford
I'm looking for an SUV. I've ruled out many brands and types due to research. However I'm curious about the Explorer line. I've read several reviews about transmissions on the Explorers. Is this a continuing thing in the Explorer line or is this a thing in general with all SUVs? What's the difference in the Explorer Sport, Eddie Bauer Line, Ford Escape? Any information you can provide will be useful
I have owned 6 Explorer/Mountaineers now - a 94 that I sold at 140,000 and the only thing wrong was the shift motor for the 4WD had quit. I have had a 97, 98, 02, 04 and now own an 06. Personally, I think they're the best design for a mid-sized SUV out there. They are still truck based, so you can tow with them, and they're tough as nails. My son ran one of them over a curb so hard it blew both front tires. But after new tires were put on, it didn't even need an alignment, let alone any parts!
The standard V-6 has been around since 1976 or earlier. It's made in Germany, and will literally run forever with very little maintenance. The V-8 makes the car a blast to drive. The third seat is actually comfortable for Adults and folds away flat into the floor. The truck has an independent rear suspension, making it step over bumps like a car, and without the toss and turn of say the Jeep. They are fully up to date as far as technology goes. Ford has done a fine job on this truck. They are machines, and machines sometimes break. There are lemons out there, like with everything else made. But generally, they are some of the most dependable and tough trucks on the road. They are NOT junk. Buy with confidence.
But if you bought a 30K US$ SUV, and drive it everyday with the same BIG Tranny problem, I'm sure, You will hate the SUV.
3 moths ago, I read many reviews about the Ford Explorer EB. but I'm not a lucky man then I don't read anything about problems with the tranny
Now You are safe. Don't BUY THE EXPLORER!!!
I'm sorry, but I paid for a SUV no for a SUV with a Big tranny problem. :lemon:
Far from being junk, the Explorer is one of the very best values now on the market.
NVbanker - one of my brother in-laws had a Mustang II with the V6 from Germany. He asked me to rebuild the engine and transmission for him, so I took it apart, but found that the high mileage engine hardly needed to have the cylinder bores honed.
I know, and I agree with you, I bought a Ford Explorer EB. But my friend, nobody buy a Brand New SUV for get problems :mad: .
"My 2006 EB V8 does occassionally have a rough downshift to 1st when coming to a stop"
You are a lucky man, In my first 5K milles, My 2006 EB V8 does occassionally have a rough downshift to 1st when coming to a stop but now, ALWAYS, everyday. I need to take time to visit the dealership AGAIN!!!. I'm sorry, But It's my first FORD, I will not to buy ford again in my life.
Any suggestions? I'm looking to spend 6,000 but am REALLY looking to go much lower.
Because of their 20 year old design, they have the distinction getting just about the WORST crash test score of any SUV ever tested by IIHS.
Notice how the passanger/drivers space is crushed. The dummies head is hanging out the window. You would be dead.
vs a 2002 Ford Explorer: (note how the passanger/drivers space is maintained.
vs a 2006 Ford Explorer:
2006 Ford Explorer test Good accros the board which is the highest score.
1)Mass Air Flow Sensor
2)4x4 can't make up its mind whether it wants to work or not, but most of the time it does.
3)Bad thermostats causing it to over heat on the freeway and baked the oil. This also proves how strong the engines are, because I continued to drive it at the temperature red-line most of the way home, and it didn't quit.
I must also note that I needed to have the transmission fluid changed to to hesitation. It was disgusting to see what I was driving around with.
If you think these things are junk, then my my you're sadly mistaken. I cannot seem to kill mine, and neither can most other people.
Are you sure about that? I was thinking the Pilot to actually be a bit larger than the Explorer. Compare the price with similar equipment. You might also want to go to Edmunds.com and compare "True Price to Own". Also check out KBB for resale values on 2-5 year old similar equipped models. "Pricey" involves a lot of things. Not just the buying price.
As far as durability goes... My 79 year old mom's 95 V6 Explorer's auto tranny laid down at about 60K miles. Cost her about $3k to replace. At her age of about 85 the tranny laid down again with about 90K on the vehicle. The first tranny lasted 60K the second one lasted 30K.
I drive it occasionally and it feels as though the car is falling apart. The steering column is loose and rattling, the driver seat is sagging (mom weighs 110 lbs) and the suspension seems to be noisy and weak.
But that is a 95 and this is 07. I would expect the V8/6 speed to be a good combo. The 4.6 has been around for a while and proven itself to be reliable. I understand that it now incorporates variable valve timing which should improve power and fuel economy. Durability of the 6 speed will have to be proven.
Kip
Well, I finally woke up and realized that everyone else is right, and that I was naive.
Last week the O/D light came on in my Ford Explorer. I drove it right home and got the manual out to see what the problem was. "Transmission problem" was what the manual indicated, as well as several websites I reviewed.
I didn't worry at first, since I figured this would be covered under warranty. My Explorer is just under 5 years old and just under 60K miles. Surely there would at least be a 60K power train warranty. No one would buy a vehicle if they knew the transmission would only last 59K miles.
Well, the dealer told me a new transmission was needed (5th and 2nd gears were worn down), that it would cost $3500, and that it is not covered by warranty. And to add insult to injury he charged me $90 to tell me the transmission was bad (something I obviously knew) - isn't this similar to stealing?
I then asked him what trade in value I could get (not that I really would buy another poor quality Ford, but I wanted to explore all options). $5500 is the most they could give. I laughed - since I had taken very good care of the vehicle. It told me that they didn't want the vehicle either - so much for them really standing behind their product. They know the quality is poor.
Obviously I was quite irritated. I asked what caused this. None of the possibilities applied since I took good care of the vehicle and had it serviced according to the maintenance manual. In fact, the dealer (Cover Ford in Austin) did the 30K checkup. I spent $1K on that (and probably got ripped off).
I took it to a transmission specialist and had it fixed for under $2500. He informed me that he sees a lot of issues like this with Explorers - probably a poor design and poor quality. Also, judging by various websites there are indeed lots of complains like this.
I wouldn't be surprised if Ford knew of the poor design - since the warranty that came with the vehicle was only 3 yr/36K even for powertrain. If Ford had good quality, why couldn't they step up to the plate and offer 60K or even 100K power train warranty. They must have known the poor quality. In my mind, this is deceptive practice - and I kick myself for not recognizing this as a red flag.
Well, for the 2008 Explorer I see Ford is offering 60K powertrain warranty. So they must have made some improvements (which further underscores their recognition of the poor quality in earlier years). But it's still a far cry from 100K that some vehicles come with. You also have to wonder what other quality issues are lurking.
I think the choice is now clear to me. In the future I will be considering something like a Honda Pilot. Ford deserves the trend of lower market share. Consumers are very wise, and the quality the provide is reflected in their declining sales and marketshare.
Please don't make the same mistake I made. The foreign competition provides much better quality and customer service.
I think it is a mistake to think that you can avoid car problems by buying a particular make. And I disagree in particular with the broad assertion that foreign competitors provide much better quality. For example, we spent 25% more on a Camry than I would have spent on a better equipped Taurus. My husband leased a Taurus a year or two later and had absolutely no problems with it the entire time he had it (about 80,000 miles). Meanwhile, I was warned by Toyota of an "oil gelling" problem that may occur if I followed the recommended oil change schedule. And I had numerous other smaller problems that took me to the dealer, as well as poorly designed interior features (seat belt, cup holder and vanity mirror) that broke within a couple of years of light use.
42,000 Miles - radiator replacement
72,000 Miles - front wheel bearing replacement
86,000 Miles - radiator replacement
109,000 Miles - transmission replaced
133,000 Miles - radiator replacement - service informed me that Ford acknowledged problems and issued a corrective action bulletin with dealerships.
When I buy my next car Ford, GM and Chrysler will not be on the list of choices!!!
I have since read on this blog of a similar problem that some one else had and they only replaced the V2V valve, now am wondering if I got taken by ford yet again, anyway I have also had to replace the ball joints in front at 72000 miles, so I would be interested in a suit
Junk that Ford couldn't sell when it was labelled FreeStyle....
And then also didn't sell labeled as a Taurus X.....
Now they relabelled it yet again as an Xploder and the name just simply fits.
EB, Eddie Bauer (not EcoBoost) is simply a nice set of seat covers.
EB, EcoBoost is now dead in the water, Ford will undoubtedly soon be licensing Mazda's SkyActiv, or if Mazda is smart this time Ford will have to BUY Mazda.
The ony good news is that Ford is now using water cooling of the PTO in order to alleviate, possibly, the high failure rate of same. It looked to me as if the coolant was also being piped all the way back to the rear diff'l/clutch in order to cool it and alleviate another HOT spot.
Anyone know the truth on that last bit..?
Where do I begin? I purchased a 2004 Ford explorer in July 0f 2011, and traded in my 2001 Oldsmobile of 5 years. I also purchased the 12 month 12,000 mile warranty. Before driving it off the lot I had the dealer fix the ABS system because the light was on. There is a crack going down the back of the trunk but nothing else was wrong at the time so I left the crack alone.
In April of 2012 I took it to the dealership for a belt, check trans, shocks, ball joints, and a ticking in the heater when knob was turned to heat (not cool). The dealer was very rude for 1 and tried to charge me almost $800. for items not on the warranty. I told him to just fix what was on the warranty and also give it a oil change. He informed me that the trans was fine and charged me for looking at it because nothing was wrong so my so called warranty still came out to almost $400. out of pocket expenses. After getting the car back my heat went out and I was told by a mechanic Buddy that my breaks, rotters, emergency break pads and the back tires were shot. So I had him replaced them because this was also not covered on warranty.
Just last week my RPM started jumping with miles over 65.(no lights were on at the time)So I took it to 6 different places getting estimates on what could be wrong. All shops said the same thing. "Start with fuel filter, oil filters and oil change". I was told if that does not work then something else is wrong but with no lights on it was hard to tell. I did all of what I was told. The day after I paid for all this the service engine light came on. I took the car to Auto Zone to get it checked. (EGR Valve code)
The man at Auto Zone told me to take it off and clean it with spray and let it dry before replacing. I took it to a shop and had them do this. The same day I picked up the car my service engine light came on again, O/d light and the car was driving like I was hauling a bus and jumping. I took it back the next day and he replaced the EGR valve new since the same code was showing up. Later that day after getting it back the car started doing the same thing after driving for 5 miles this was Friday 9/21/12. *I have now turned to the internet and I am MADDER THAN I WAS BEFORE LOOKING ON THE NET!!! OMG!!! ***** :sick:
I still owe a car note on this car, I am a student working a part-time job and a single parent. I have no ideas what to do next. I refuse to put a trans in it and refuse to pay for it if I can not drive it. I am so upset that I bought a FORD. I would rather have a old beat up Chevy any day then buy a brand new Fix Or Repair Daily/ Found On Roadside Dead = FORD!!!!
FORD!!! GET OFF YOUR [non-permissible content removed] AND HELP THE PEOPLE WHO HAVE MADE YOU RICH!!!!!!!!!
