GMC Yukon Radio, Stereo, iPod, XM Sirius Questions
Just purchased a 2001 Yukon, no owners manual. How the heck do you operate the rear radio controls ???? I turn the power on, light comes on but nothing seems to operate,
Thanks!!!
SUVs and Smart Shopper
I noticed the same thing once the XM satallite radio trial run had expired. Regular radio stations almost sound muffled compared to the crisp sound of the XM stuff. I talked XM into another three month trial at around $5 a month and can't be happier. If you reset the defaults to customize your sound system for regular radio, it should fix the way you hear stuff. The Bose system is great but I think it was really dialed in for the XM or Sirius product.
I was wondering if you would know if the SIR-GM1 will work after I install an aftermarket Navigation System, into my 2004 Yukon SLT, which has the XM option.
The Navigation Sytem I am planning to install is a Pioneer AVIC- Z2. I would love to use the XM antenna which is already in place, instead of having a whole lot going on, atop of my roof of my truck.
Any insight will be greatly appreciated.
SFBerto
Does anyone know how to get the song information to display when listening to XM Radio? We were told that you can access the Name of the Song or Artist, etc. when listening to XM, but we don't know if this is true or how to do it.
Thanks!!
I just decided to treat myself to a 2003 Yukon XL SLT, very rare here in the UK
I am prepared to order from the US for my install, but obviously I want to get it right 1st time
Mine is a 2003 SLT, I am told it has a BOSE system, the speakers say BOSE on them but the headunit doesn't. The headunit has Delco part No. 15184935 on the side, is that BOSE?
OK, here is my plan, the way I see it I have 2 options.
Preferred Option 1:
Below the regular headunit in the centre console there is a space which has a single DIN opening which tapers off towards the back. I thought I could add a DVD 7 inch flip up screen here and feed the audio to the aux of the headunit.
Upon looking at the rear of the headunit today I see I will need an adapter like this maybe http://www.logjamelectronics.com/pacaaigm24.html
Option 2:
I replace the headunit for a double DIN in dash screen.
This brings up a whole load of issues with the BOSE amp and speakers already installed and also the onboard bongs etc.
Also the wife doesnt like the way the headunit points towards the driver and she cant see the screen properly, to I guess if I did it this way it might need a 2nd screen anyway
Soooo, can anyone advise the best route here, am I missing something which make this job easier or harder?
Thanks in advance
Ben
Help - which is right?
My plan at this point is to do a total install of amps, Speakers and subs with complete rewiring so you have total control over outcome. Many installers have stated some problems tying into factory wiring. If you go with a screen HU the angle is not going to change so put a visor mount for the wife or TOmTOm so she can navigate. Also my wife has an iphone and the nav functions are pretty good...you choose. Good luck
No nav screen, just single/multiple cd/tape and radio.
The manual says that once the DVD is playing there should be a DVD symbol on the radio, then I should select the DVD as audio source by pressing TAPE/DISC until DVD is highlighted, or choose DVD from using the SOURCE button. But the DVD symbol never shows up even while the DVD is playing, and DVD is not an option under SOURCE or TAPE/DISC.
Either I'm just doing something wrong, or there is a problem.
Also might be after market DVD, with missing head phones.
Cannot select DVD audio from rear entertainment center either.
Did this model come with a DVD player?
If so, how do we listen to it? It plays the movie, but cannot access sound.
Please help!
(Just kidding! :P )
Things may have changed with the new 2007 head unit, but I looked into this for my 2005, and there is an adapter for sale that will work with the factory system. Apparently you connect this thing to the back of the factory radio, and when you push the CD/AUX button it will switch between those inputs. Total cost, installed, was about $150 at a little cell phone/car audio shop I just happened to visit. They would run the USB cable through the dash somewhere, they said most likely into the glove box, but I suppose they could put in in the center console or anywhere else. Again, it may be different for 2007+ models. If any of the buttons in your radio say Aux or CD/Aux, you'd probably be in luck. Just swing by some stereo shop and ask for their recommendation.
Your dealer said its from "Normal wear and tear", Hummmm, how many miles do you have on your 07 Yukon anyway?
Let's move over to the "GMC Yukon Tires and Wheels" discussion.
I apologize the agent hasn't contacted you back. I checked your case notes and your agent is going to call you today. Thank you,
Mariah GM Customer Service
I've been told these buttons are illuminated by fiber optic cable from a central location. How do you access it, to change a burned out bulb?
