High Tail Lamp Replacement 2006 Sonata
Can the high tail lamp be replaced without going back to the dealer? Replacement instructions are not in the owner's manual.
1.) unplug the connector in the trunk (white, directly under lamp).
2.) remove the 2 gold-colored screws from inside the trunk. They can be seen from the trunk. 1 is thru the larger square opening where the wire connects to the 3rd brake light. The 2nd is on the right side thru a small (screwdriver width) hole covered by a piece of foam tape stuff.
3.) after removing the 2 screws, go inside the cabin and the brake light housing pops right up.
4.) disconnect the bulb from the housing while inside the cabin.
5.) in the trunk remove the wire and bulb. (it's about 5 inches long. the wire from the connector to the bulb socket)
6.) reverse steps to install.
A friend and I had gotten to the first step in your instructions, but then we moved on to something else when it got tought.
Can't wait to try this .... in your face HYUNDAI!
I was happy that I only paid $50 for the replacement, as the first dealer I visited wanted $85. Next time I'll do it myself if it's really as easy as reported above.
I did got my brake lights replaced on both sides at walmart yesterday. and they really did it for 2.95 (total) ..actually they should have charged $2 for each side ($4 total for labor) but they weived it as they took 45 mins instead of the 15 min they promised. And i didnt even asked for a waiver. Trust me go to walmart and save yourself a bunch of money. Hopefully it should be similarly low cost affair for the high tail lamp replacement.
-Rajnish
