Chevy Blazer Blower Motor Intermittently Works
On my 97 Blazer, the blower motor will suddenly quit working while the anti-lock brake light will simultaniously light and the cruise will switch off. A half hour later, all three will switch back on. This happens once every five or six times I drive the car. Sounds like a broken wire making and breaking a connection but where would it be to be common to all three of these items? Any ideas?
SUVs and Smart Shopper
If thats it about $150 for a hub and have to have an 18mm wrench for brakes, a 36mm for 4wd nut, and a 2 jaw 6" puller for CV if 4wd. Dirty job so get the cardboard out! 2wd is much faster!
The power windows intermittently haven't worked for years, but this pattern just showed up a few weeks ago.
My dealer couldn't recreate the problem.
Bitter
\There severals items to check, 1st the fuses.
If good run a hot directly to the blower motor , to check if that is good. The plug with 2-3 wires.
Then check the connection behind the controls behind the dash, which has to be removed, not as hard as it looks. total of six screws.
The whole assembly pops off after the screws are removed.Don't forget a the five screws under the dash on both sides of the steering column.
If those connection are good (orange always hot) Check the resistor for hot , it is attached to the blower motor under the hood. the resistor send current to the blower .
Recap
Fuses
Control under radio , behind the switches ( fan,temp, vents)
Resistor.
Blower
Yeah I'am good ....lol
I DIDENT DO ANYTHING TO IT I swear............
The Jimmy germlin ??
My freind was surprized I finshed my part quick Iam sitting there screw driver in hand looking like ?????????? what the??
Yeah me and my tools
Anyway what can I look for and any and all help is needed.New here and this is MY first Jimmy.Thanks Vernon
i have not replace the relay yet but need to
Bitter
Regarding the blower motor cutting out, I can unplug the plug on the outside of the blower motor casing (the plastic box it sits in) on the bottom left corner from the plug coming from the wiring harness. I can usually unplug it then plug it back in and it will work for a few mins before cutting out intermittantly then quitting altogether. Everyone tells me it's the resistor but I have replaced that already. The plug looks to be in good shape and I have cleaned the connectors to be sure it is making the best connection possible. When I wiggle the plug it does not cut out so it seems to be fitting nice and tight. It is almost as if unplugging it and plugging it back in resets it somehow? But only temporarily. What am I missing?
Regarding the 4th positon of the blower speed switch: I have replaced the switch and positions 1, 2, and 3 all work properly but when clicked into the 4th and final position, nothing changes. It remains the same speed at position 3.
Can anyone help me? I'm pulling my hair out over this! :confuse:
ACDelco 15-8719 or 15-5635 (GM 12193601)
$23.00
$47.00 MSRP
I did however buy one and replace them 1 at a time and couldn't get the blower to come on at all so I returned the relay.
Anyway, no windows, no blower, it IS your ignition switch!
