Z
Also, on the factory installed systems, does all the call info such as number, time of call etc.. get shown on the radio display unit?
I only have the prem package so i have to use the voice command to enter in every single entry. Which is extremely annoying since you can only complete it via voiceactivation. It would be a lot easier to navigate through the center console and just speak the persons name you're enterting rather than completeing the whole task by voice.
Other than that I have no complaints with the bluetooth. I have a Sanyo M1 and it's been working perfectly. I just checked and there's no call waiting option which is annoying. But I can deal with that. Hopefull the person calling on the other line gets my voicemail and not a busy signal. I'll test that when I go home.
They said it works perfectly.
Any ideas? Of course no help from Palm or Sprint. Anything would be appreciated.
I do not think that it is possible to pair up to phones at the same time though.
Somewhere under preferences (it is not in the bluetooth section), there is something referring to automatically picking up handsfree - you want to check this option and things will suddenly start working. Basically they made an enhancement to bluetooth and one of them was to ensure that if you connected to a bluetooth device it would stay connected unless manually ending the connection.
Here is another way to get it to work as well. Dial out on the phone, then push the Phone button in the Infiniti, it will switch over to your car speaker and you can dial outbound.
Alex
Bluetooth cannot be added individually, but if you go out and drop a few hundred on an aftermarket GPS unit, most now include Bluetooth for hands-free mobile calling.
I'm assuming I'm SOL since the device is fairly new
kc
Basically, you import your phone's address book into the G, and then record voicetags for each number.
With a simple voice command, you can then have the car dial any of these numbers with one quick click of a steering wheel button, and a simple voice commnd.
Yes, the car is like one big bluetooth headset.... with wheels
Can I just push a button in the G35 and 'talk' to my phone without using the G35 voice tags? I can currently do it with a simple bluetooth headset.
If you've got a WM5 phone you can download JETware (free to try, $ to buy) and download your entire phonebook at once into the download section. Without that, depending on your specific phone, you may not be able to get the entire phonebook in there.
Then you just copy your most frequent ones from the downloaded phonebook to the voicetag directory and viola done.
I have a 2008 MB 320CDI and it is not discussed in the owners manual.
I have seem this symptom before on other boards but when I called Infinti's BT help line, they seemed mystified by the problem. Other than this initial connection issue each time the car is started, the phone works fine for calls, receiving calls and voice-activated dialing, etc. Just is a shame to have to start car, select Phone, hit Hang Up and then Back and wait 10-15 seconds for the system to activate.
What I do now is turn the car on, see the "connected phone" message and then hit the hang up button on the steering wheel several times, then hit the back key above it on the wheel. A shame because everything else is nicely executed with the car and this ritual every time starting the car followed by 10-15 seconds of deadness before the radio/etc. comes back should be fixed.
Call the BT desk and press them...I will probably call every once in a while to keep them honest. Please post back here with any info.
Based on your experience, I would say Motorola has BT problems as part of their WM6 based phones, but they will probably not make a change due unless this issue is widespread. As much as I hate to do the work around (phone, hang up, back), I still do it and will probably look into a Blackberry Curve when it comes to Verizon next month.
Let us know how it goes.
extensive web surfing has not given me a definite answer on this, would greatly appreciate if anyone could answer. I need to know because I've found a good deal on one with Nav, and I want to be sure it has bluetooth before I bid on it.
thanks for any help.
jeff
Z
Initially they are blaming the phone until I told them about the website...I will update you guys once I get some info :confuse:
This may sound crazy, and is only a theory, but hear me out. I'm not convinced this is a bluetooth problem - I think it is actually a problem relating to the "start-up" of the nav system.
My reasons include:
1. this afternoon, I turned the phone off before starting the car. I then started the car and let the nav system finished its "start-up" process. I then turned on the phone, and everything worked like a charm.
2. from what I know, Bluetooth is designed simply to wirelessly connect 2 devices - this actually works fine once the inital problem goes away.
3. when I start the car with the phone already turned on (and the last time the car was on I had the screen on a radio screen), I actually see the screen flash from the radio screen to the "follow these rules/hit enter" screen. This did not happen when I had the phone turned off and started the car.
I'm thinking about this because I want to make sure I contact the right part of Infiniti, and I don't think that's the Bluetooth helpdesk.
Thoughts? Thanks!
I did the software upgrade from Motorola website which updated the Windows
CE version from 6.0 to 6.1 I believe...Now everytime I start the car everything is just perfect the way it is supposed to be.... As most of you already figured it out this is a Windows mobile 6.0 issue rather than the car's.... Well now I'm a happy camper.... I suggest all of you who have a Windows CE 6.0 please upgrade to the next available version...this should solve many problems....and I can see even the phone
was way faster than before when browsing on the Internet...:)
Found a registry hack that solved the problem. Requires using a registry tool and slightly risky changes, but worth it IMHO for the desperate. Here is the post, the instructions are in post #5.
http://www.everythingq.com/forum/moto-q-9c/q9c-and-infiniti-g35x-bluetooth-probl- em-16833.html
