Chevrolet Cavalier Speedometer Questions
I've got a 04 Cavalier 2dr 5sp manual that has a speedometer that bounces slightly when driving down the road but seems to register the speed pretty correctly. Today when I first took off it would only register between 10-15 mph but after shutting the car off and restarting it went back to its bouncing thing but seemed to register pretty close to the correct speed. Is a there a plastic gear that might be going bad and can be replaced? The vehicle has about 41000 miles on it and runs out very good otherwise.
If oiling it doesn't fix it, then replace the speedo cable with a new one.
David
also could be..fuel level sensor, thermostat, speed sensors and a couple of other things, but being it;s all of them acting up i would say it's something to do with the cluster itself. but, i have not seen where one has been brought into my shop with all gauges acting up. usually the speedo is inop.
the only way to truly know is if you bring it into the dealer. it's under warranty so why not bring it in?
Any help appreciated!!!
