Dodge Durango Engine and Performance Problems
I have 2002 Dode Durango SLT 4WD V-6, I purchased it in this past October. Last month we started having a problem with the engine cutting off while driving, but it starts right back up after turning the key off and on again! It doesn't matter how fast, slow or if you're sitting at a red light or stop sign, it just does it when it feels like it! The worst was yesterday when my husband drove it 60 miles to and from our home...it cut off 8 times on the way up and 7 on the way back. I haven't noticed it doing it on warm days but at least once or twice on cold days! When the engine does cut off the only changes in the dashboard are the mileage will say "no bus" and the circle around the "D" on the gear indicater disappears! HAS ANYONE ELSE HAD THIS PROBLEM AND IF SO, WHAT WAS THE FINAL OUTCOME? Our Dodge dealership has NO CLUE!!!!!!!!!
It started about 1.5 years ago. I brought it to the shop for repair. They told me it was due to a bad contact "somewhere". Now the problem is appearing again. The "check engine" and "no bus" indicator light up.
I hooked up an analyzer but it does not detect the error. The easiest way out is maybe by replacing the SUV computer, but what if the problem is somewhere else? This is very frustrating. We can help us out?
i run the car for about an hour and it turns off. then i wait for about five min. and then it starts going. and it does the same for the next hour where i have to wait about five min. for it to start again.
it makes changes in the dashboard where the mileage will say "no bus" and and the circle around the "D" on the gear indicater disappears the same for me.
I have the same problem as the first post. can anyone else help.
I came to the forums hoping to find an answer to what was wrong so I could have the problem fixed, but it seems as if no one, including the Dodge dealerships, knows what is causing this.
Hopefully someone will have an answer, so I can again feel safe while driving.
Thanks JOHN
My 2002 Durango is doing the same thing, accept on occasionally it doesn't like to shift right away. Have you found anything out regarding this issue?
Regards
Problem started back in jun 2008, where check engine light came on a car just stopped. Had it towed to dealer they had no idea what was wrong except to say i had a misfire in engine and needed fuel injection system service. That was done light came on a few days after went back to dealer and they said I had to replace O2 sensor, did that. In aug 08 check engine light came on again, replace O2 sensor and that I needed to replace all spark plugs and wires, All were replaced, (money is adding up!!), still light came on a few days later. Dealer then said i had a new code of P0052, replaced powertrain control mudule with software.
Throughout 2009 light would come on periodically and go off, some one told me at dealer light will come on if gas cap not tightly closed. That brings us to May 2009, went to a new dealer because other one was going to close. I needed oil change and they saw check engine light on, ran diagnostic said i needed to replace catalytic converter. I ignored it because i just had a baby and not enough energy or time to deal with and car was running fine!!
Bring us to date, car is still running fine, check engine light is on and another shop where oil change done says I need to replace O2 sensore and catalytic converter. what is going on? anyone else have this problem. :confuse:
Replying to: henrilouis (Jun 13, 2007 12:32 pm)
I've had the same problem with my 1999 Dodge Durango for almost a year now. I've changed every sensor ( ICS,PSC,CMP,CKP, MAP, TPS, ECG, etc.). I've had the fuel injectors rebuilt, fuel pump replaced, Catalytic converter replaced, Dist cap and rotor replaced, replaced the ignition coil,and new plugs/wires, I've even had the PCM replaced twice. The only thing that changed is it dosen't die while I'm driving anymore. It still "bogs" down on me and I still have to start it 5 times to acutually get it to move. Is there anything that the dealership or the 10 mechanics I've taken it to may have overlooked ?
** Ok, I really feel like a fool. Here it is almost a year later after I thought part of the problem was gone, all new parts and it's shutting off while I'm driving again. It's also bogging out again while I'm driving down the road. I'm thinking about scraping the Durango and just buying a new SUV, it's probably cheaper in the long run. But I will guarentee my next purchase WILL NOT be a Durango.
:lemon: :sick:
PLEASE HELP ME, a solution, OR somewhere to buy what parts I need would be a tremendous help. Thank you.
But this year, since the temperature has dropped to 20 degrees, I now have both knock sensors tripping my check engine light at the same time. This happened all the sudden and my truck will not run right at all!! It looses power, feels like the engine is seriously misfiring. I seriously doubt that both sensors are fowled up at the same time with little or no warning and causing problems like this.
What else could be wrong? I don't have the money to waste changing knock sensors when that isn't the problem. I read in another post that it could be my distributor instead....... Help please!!!! Thanks!!! :confuse:
Has anyone else experienced something similar?
I have a 2000 Dodge Durango 5.2 Engine.. I haven't had any real trouble until now. My check engine light keeps coming on and I took it to advanced auto and they told me that 4 of my 8 cylinders were coming back as something wrong with the electrical wiring ? Has anyone else had this problem ? The cylinder's don't have wiring in it... Could it be the computer ? Is this an easy fix or should I just sell it and get a new car ?
I had a tune up done and replaced injectors. After$1500 it still runs very rough and engine light is on. Also the same codes come up ie: injector malfunction and multi misfires. now I am told it might be ecu/pcm. I hate to invest another $500 on a might be. Any ideas? thanks in advance.
I also took my Durango to advance and go the error codes, I then went to Goodyear and they did a tuneup. After that didn't work they said it was the injectors. Another $1100 and that didn't work. I then took it to Americas garage and spent $700 on test to be told it might be the pcm/ecu. Yes I did hve the multi cyl misfire as you do. Saying all this, I to am in a very bad place. I did a title pawn to pay for this and it still doesn't work and now I can't without my car.
Then it was $1100 to have all injectors replaced. The car still runs like crap.
I just ordered an pcm/ecu today for$250. I pray this works. I should have it by Wed. I will post if it works out.
This will at least explain the code your getting.
