Honda Odyssey Electrical Problems
Locks, internal lights and DVD player ?!?
I hope this isn't duplicative....3 issues/questions as mentioned above. I have 2007 EX-L with DVD with less than 5K miles.
Every once in a while, the auto lock feature seems to kick in (after the locks have already been auto locked). It does seem like it occurs on acceleration after a stop so it could be the ABS test that I have read about here. How often (monthly or weekly) is the ABS supposed to test itself and how long is it supposed to last (an entire local trip...20 mins)? This has happened 3-4 times so far.
Next, the indoor dome lights turn on and off while driving when they are set in the middle function (to turn on when the car is opened and then off after a bit). It seems like this happens in connection with the ABS but am not quite sure. This too has happened 3-4 times. Any thoughts?
Lastly, anyone's DVD make noises when a dvd is in the player but is not being played and has not been used for a few days?
ray
ray
Myself have a 2003 Honda van, the left vent windows without use for more than a year but stopped working!, I did bring it back to dealer for replacing the motor, after I own my van over 3 years the the right vent windows stopped working! I bring it back to dealer and they said it will cost me $380 for repair !.
I have 3 different friend has the same issue.
Everthing goes fine again after I turned the rear wiper knob back/forth a couple times. Seems to me the wiper switch has sort of short circuit inside.
I have some concerns regarding the accuracy of the odometer reading on my 2007 Odyssey. Is there anyway to check to see if the odometer is working correctly? Also, should i take it to the Honda dealership or have it checked by a dealership other than Honda? Please advise. Thank you
Take it in to the dealer - why not? Surely this is something they are capable of? I do think it's a good idea, if you know a local place, to maintain a relationship with them - if they are good - because Honda, like any company, is mostly interested in selling you a new car. I haven't been wildly impressed with my dealership, but of course your mileage may vary.
Uh, sounds cool in theory... but where I live it's dry probably at least 90% of the time. Are you sure it's supposed to do that?
2. When you turn the engine off I find that it is strange that the van has retained power to the power windows and moonroff but no retained power to the radio. Even my dad's 00' Windstar has it.
3. Auto-off headlights and no auto-on, how cheap can they get.
4. Rattle from the passenger side middle row is driving me nuts. Can't figure out what it is and I checked everything.
5. Had the Auto Day/Night Mirrow w/Compass installed when we bought the van. The drivers side plastic moulding for the side air bag was taken off and not installed correctly. There was a large gap between the dash and the moulding. The passenger side plastic piece under the door was taken off also and they broke 2 of the plastic pins holding it on. The plastic piece was sticking up on one end. Took it back to the dealer and they fixed it right away. They should have put it back together right in the first place. Not sure how it made it past their pre-delivery check.
6. The outside temperature guage got stuck at 24C one day and it was 31C outside. I drove for over 4.5 hours and it didn't change. Parked it in the garage overnight and the next day it was fine. Strange, haven't had a problem with it since. Normal temp changes to outside temperature after a few minutes of driving.
7. Helicopter buffetting noise effect from one of the middle windows opened slightly is unbearable at 30-60 km/hr. Kind of useless to have them if you can't use them. I would rather have the rear quarter pivoting vent window like the old model.
8. Daytime running lamp light in the dash is blue but is so dim you can barely see it.
9. When passenger side window is lowered about 1-2 inches I get a constant rattling sound from the door or glass. Has anybody else noticed this?
Bottom line, still a good quality van but wish there weren't so many little problem with it.
However, now when I shut off the van and open the driver's side front door (keys out of ignition) I get a series of 5, somewhat high pitched beeps. It doesn't happen until I open the driver's side door. And this all started after I jump-started the van that one morning. It had never happened before.
Any ideas? Thanks.
Yes, it is a nice van, but minor niggles abound. If you can live with them and ignore the little things like rattles, minor electrical, etc., it's a great driver with nice looks. If you can't or don't want to, like me, the Sienna IMO is more satisfying to live with and seems more thoughfully engineered, but lacks some of the fun factor of the Ody. To me, your Ody sounds pretty normal. We had some ill fitting panels in ours, too. Rattles, yes - not like a GM, but always there in the background, and especially when you roll windows down or turn up the radio. I am surprised the new ones don't have auto on headlights though (mine is an '04). Minor electrical issues have always been around with ours too.
This happened a few times on our '04 as well. It's best to simply drive to the dealer next time it happens, while the door is still partially closed. Unfortunately this means you have to listen to the annoying buzzer the entire time, but there will be no question when you get to the dealer. With ours the dealer had to adjust the cable. Good luck.
Thanks, I've learned much from your many posts!
Last night I took out the fuse for the automatic door locks, thinking that if the doors couldn't lock themselves then the alarm wouldn't set itself - that worked - but it meant that the car was unlocked all night.
The price that Honda quoted me to 'try to find' the fault was ridiculous.
I bought my '02 Odyssey new in 2001 with the intention of keeping it for ten years. This problem is only one of many that I've had with this truly awful car. I will be getting rid of it sometime this year and I will never buy another Honda.
If anyone has any ideas about how I can disable the alarm but still be able to lock the car I would be very grateful (as would my neighbors).
Has anyone else experience this and is it normal?
Seems there are no knockouts like the 2004 had
Has anyone found a way to do this without drilling a hole
Obviously, we should turn the lights off, but you get to the parking, turn the lights on to look for something that slipped under the seat (anybody with 3 kids knows what I am talking about), collect all your junk and before you know it, you have totally forgotten about the lights.
On my 2001 Honda Odyssey EX, the driver's seat electric recliner does not work properly. Once reclined (towards the back seat passenger), the seat back raises up slowly and then stops. I must wait a while (a few minutes to a few hours) to get it to raise up some more. Getting it back to vertical can require extra force from behind. It is as if the power seat battery inside the seat is dead. Does this seat have a battery? Can this be possible for it to die? If so, can this be fixed/replaced easily by a lay-person (non-shop techie)? Please let me know. Thanks!
- Chris S.
It is strange how it moves about. Sometimes the interior lights won't come on, then sometimes they will flicker when one of the side doors is being opened. I have had the driver power window work when the engine is off and the keys are not in the ignition, and I've been able to pull the key from the ignition when the car is running!! There are several other instances, but this gives you a rough idea. Any ideas on what it could be?
Also, the ignition has recently started to reject the keys! I mean, you can put them in, but you can't move them. Then you turn the key around and it works fine! Any ideas on that one??
i did a carfax and it came out to be no trouble at all and one owner for this car and it was for personal used only.
i purchased it when it was 69,000 miles.
i have quesiton about my engine light being on. light show on 10-27-08 and i had reset the car and it had turn off eversent today. the light came back on and i don't know what to do.
i took it to a local auto zone store to do a free engine check and it define it as
Electrical load detector curcuit high input
Probable causes
1. open or short circuit condition
2. failed ECM
do anyone know what it exectly what it is telling me. i don't want to waist money to go the dealership to disnosg. it and if someone could get me some answer to this question.
if it dones't help, maybe it'll be best to take it to the dealership.
i have another question.
when my car is put into reverse(front is facing down the hill) it seem to be reversing it, if i don't put enough gas paddle on the car. i goes down and then when i put gas on it, then it'll reverse.
same thing when the car is going up the hill; and when i stop and then go, it'll roll down and i have to put gas on it so it won't roll down.
is that normal or is there something wrong with the van?
It is considered to be normal by Honda though ... I used to have 2007 Odyssey (traded for 2008 Pilot) did the same thing as you described ... Since I am aware of it (car will roll backward when car is in "D" when car front facing uphill in slope & car will roll forward when car is in "R" as car front facing downhill in slope.), put into gear "D" or "R", my left foot will be stepping on the brake, then right foot gives a little puch on gas before releasing the brake.
So my question to you is what did you find out it was? Or did you ever?
Also when I park and take the key out it make a dull whinning sound.
Monica
please help solve this mystery!
thanks!
I took my van to a nearby dealership but guess what! It didn't happen when the service adviser tried several times on the spot. The van worked fine without any issues. It was embarrasing but my can still has the same issue from time to time. I don't know what to do.
