Ford Expedition Liftgate and Door Problems
2007_eb_exp
Member Posts: 1
in Ford
I have a 2007 EB Exp EL with the power liftgate option. Recently (and intermittantly) it has had problems opening and closing. It acts like a garage door opener with sensor problems and refuses to open or close. Just had it in to the dealer on two occasions for this problem. They could get it to replicate only once, but we have it on video and showed them. I believe it is some sort sensor problem as dashboard control cluster tells me that my liftgat/window is ajar. They (dealership) seem perplexed, but ordered a new liftgate handle..?? Any other owners out there with the same problem (or with a solution)?
Thanks for your help....
2) Pull to the right or left? Out of alignment?
3) Rear hatch(metal) squeak? Won't close tightly?
Mark.
I've had a used 2004 Expedition for almost a year, and I can report that my locks DO NOT unlock automatically when I put the car in park or take the key out. However, when I go to open the driver's door, whether or not it locks, it opens when I pull up the handle.
I'd have to pull my manual out to see if there's anything in there about automatic unlocking, but I don't think there is. I know you can program whether or not you want the doors to lock when you get over 8 MPH, but I don't think auto unlocking is an option.
one being a relay relay but know nothing about relays. My expedition has the door ajar on the message center but no doors are ajar. This in turn causes the lights to not go out and the door locks to not lock automatically and when you take the key out of the ignition the radio goes off instead of staying on until you open the door.
Secondly, we also have problems with the cruise control not working.
Thirdly, the foot pedal that moves the pedals forward or backward.
Last the cd player keeps the cd and will not release it I push the eject but it shows no cd but I know for a fact there is a cd in area 1 and a cd in area 2.
any help would be appreciated.
My 2003 Expedition EB does the exact same thing and the WD40 tip did not work for me. Did you ever get this problem resolved? Any other tips?
Thanks in advance
Did you guys figure out what to do to resolve this? Our 03 Expedition door ajar light comes and goes, beeps like mad all the time and if we leave the interior lights on, it sets the alarm off
I have a 99 EB Expedition, had the same problem today.
I sprayed WD40 really well in all door latches, and the one that seemed to finish her off, was the rear window latch.
I had noticed recently that I had to close it kinda hard, for the door ajar light to go off, but when I tested today, it 'caught' so I didn't pay it any more mind.
but Alas, that was it...at least I think....the lights didn't go out until I sprayed that one, and when I closed it, it 'latched' easier, and the lights went out.
Good Luck, orale.
Any suggestions, would be appreciated. I do home inspections and retrieving ladder thru hatch window is cumbersome!
Thanks-Jack
You will need to get the trim off the panel from the inside to fix it.
Sylvia, "Forums Discussion Finder: Get Directions Here" #1383, 17 Mar 2003 10:36 am
1. Remove the interior plastic handle. (attached with two security screws under handle at center of panel)
2. Remove the two Phillips screws behind the window which holds the interior cover over the rear window wiper blade actuator motor. (plastic screws be gentle getting them out, also remove the plastic grommet they screw into).
3. Pry with two flathead screwdrivers to remove the lower interior trim from under the upper trim.
Caution: There is a plastic sheet between interior panel and door frame. Try not to put holes in this, it is to keep sound from the road reaching the interior cabin.
4. There is approximately 8 clips attached to the lower trim which holds the trim in place. Gently with your hand between the trim and interior door frame pry outward and pull the clips off the door frame. Once all clips are removed the panel can be pulled out.
cable cost: $35 approx.
I own a 04 Exedition eddie bauer and I bought it brand new. The locks auto locked when truck is in drive but never unlocked when parked and shut off.
